  #16
Old 10-24-2014, 06:06 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
I am not sure if it is a symptom or a contributor.
The actual push-pull on the cam gear and thus the crank is about 200 lbs. I will need to put a crank on the press to see what the deflection is under axial load.
__________________
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #17
Old 10-28-2014, 11:13 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
just thought of this but what about the added load of the water pump and CP3 connected to the cam gear?
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #18
Old 10-29-2014, 04:01 AM
Fingers's Avatar
Village Idiot
Default
Those are loads that would not contribute to the shearing of the cam pin, but are loads on the cam gear itself. So they would be in addition.
__________________
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
  #19
Old 10-29-2014, 05:23 AM
rickaveryjr's Avatar
rickaveryjr rickaveryjr is offline
Gearhead
Default
This is pretty interesting. Typically straight gears are weaker than helical simply due to the fact that there is less contact area for the same size gear. They are also much louder than helical gears at higher speeds. The problem with helical gears is the axial force (thrust) when loaded. There is also a force trying to separate the gears at that point. Could the uneven loading/unloading from the cam have something to do with resonation at a certain frequency? I don't know. Maybe that was a thought for the CRANKS thread
__________________
2007 GMC SLT Classic EC/SB
HSP Twins
  #20
Old 10-29-2014, 11:36 AM
Fingers's Avatar
Village Idiot
Default
Quote:
Actually, spur are stronger. Especially stub spur. Helical only have a small portion of the gear faces in contact at any given moment. Helical are quieter however because the gradual engagement along the gear face.
The axial thrust from the helical depends on the angle of the helix. In the case of the cam gear, it is about 10% of the loading on the gear teeth.
I think the loading on the cam gear is a clue to the axial loads being applied to the crank. Whereas the crank can easily handle 50,000 lbs of radial force from the connecting rods and the resultant torque. The failure and fatigue point from axial loads is much smaller.
__________________
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
  #21
Old 04-14-2015, 01:58 PM
CurtisEmery's Avatar
CurtisEmery CurtisEmery is offline
Default
Have you come across any issues with the thrust collar galling and cracking from cam gear thrust. I help out with a pulling truck that had these issues. We ended up intalling a torrington bearing between the cover and cam bolt to end the problem.
__________________
The Puller: 2003 Red Chevy CCSB LB7 "Locomotive Breath" -SOLD!
Socal Diesel-Profab Performance-Turbo Re-Source-Pressurized Solutions-Ridgerunner diesel-Inferno Diesel-Inglewood Transmission-Precision Convertor-Schaeffers Specialized Lubricants
  #22
Old 04-15-2015, 08:09 AM
Fingers's Avatar
Village Idiot
Default
I've seen several, but have not made a correlation between cam design, hp or anything.
__________________
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
  #23
Old 04-15-2015, 10:15 AM
Default
Me neither. My puller never had issues with thrust yet his did.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
