Old 06-11-2018, 07:10 AM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Default Ball bearing turbos?
Time to upgrade my s366 and I'm wanting a ball bearing Garrett turbo. Anyone on here running one? Or have one for sale? The gt4294r is what I was looking at. I have dual pumps and 75 percent overs.
Sent from my SM-G955U using Tapatalk
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
Old 06-12-2018, 01:53 PM
Honey Badger
Found a PPE 40942 kit for a good price. If I can sell my S366 kit I'm gonna try it out
Old 06-13-2018, 09:44 AM
nwpadmax's Avatar
nwpadmax nwpadmax is offline
comlpete diphsit
The only thing BB turbos hate is shitty, dirty oil. Keep them fed with clean good lube and the durability should be great.
Old 06-13-2018, 07:08 PM
WisconsinHick1's Avatar
WisconsinHick1 WisconsinHick1 is offline
I have been impressed with how fast a ball bearing turbo spool. I am looking at going ball bearing in the near future.
Green Bean Out
The Rag In
Old 06-13-2018, 07:14 PM
Honey Badger
I want a gtx4088r but my wallet is opposed the the idea. Gonna give this 4094r a try.
Old 06-13-2018, 07:19 PM
malibu795's Avatar
malibu795 malibu795 is offline
I'd offer my GT4088R but that's a step back in HP potential..
I did kill one with coolant in the oil..
Definitely like them alot
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
smooth seas never made a skillfull salior
Old 06-13-2018, 07:25 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
4094 runs hotttttt...
Old 06-13-2018, 07:53 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
X2. My gtx4508r 80mm valley turbo spools way nicer then my old s472. But it also sucks when a turbo grenades and sends pieces into the Garrett. Could not buy just the compressor wheel.
2006 ccsb Lbz Tow rig
2006 rclb 6.6
  #9
Old 06-13-2018, 08:02 PM
Honey Badger
Hot as in egt wise or hot as in good? It only flows a couple lbs per minute more than my 366 and way less than a S369sxe. Not sure if I'm making a wise choice but then again I have dual pumps and 75% overs on a stock bottom end lb7 so wise choices is not my forte
  #10
Old 06-14-2018, 03:55 AM
High EGTS, you have to drive it really hard...
  #11
Old 06-14-2018, 04:34 AM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
Ran a 4094R for a few years with +50 sticks and stock pump. Spools quick, but as mentioned, it's a bit tight on AR and runs hotter than a stock VNT.
In my application it was holding things back at 3600r and 700hp. I'd rate it at arround 600hp max. Shaft end play is substantially greater on thee roller bearing units, but never effected anything that I could tell.
  #12
Old 06-14-2018, 04:54 AM
Honey Badger
This one has a .95 AR exhaust housing, my 366 has a. 91?
  #13
Old 06-14-2018, 07:01 PM
Yeah that is the bad part is you can't get parts and no one else but Garrett can work on them.
Green Bean Out
The Rag In
  #14
Old 06-14-2018, 07:11 PM
Something to do with compressor map if I remember, you have to push the shit out of them. 1600 plus at the end of a 1/4 mile run is totally normal with one.
  #15
Old 06-14-2018, 07:47 PM
Ne-max's Avatar
I like turtles
A stocker with max effort tuning will be hotter then that. Can't be scared. Lol
2006 rclb 6.6
