Old 07-16-2017, 09:50 AM
jonathancasey19's Avatar
jonathancasey19 jonathancasey19 is offline
yepppp
Default Help deciding on new wheels for 02' 2500HD w/4-6" Lift
Need help deciding on replacement rims. I've had 20x8.5 Rockstars on 35x12.50's since 2008. They are ruined from years of salt exposure. Contemplating a 20x12 deep dish rim. Not sure if I'd like it or if it would work with a Cognito 4-6" NTBD lift. Open to all suggestions. Thanks!
2002 LB7 ECSB Summit White
S366/74 .91 billet 6-blade race cover 360 thrust bearing, S&S 65% injectors w/BMS SAC nozzles, Exergy 10mm cp3, Cognito NTBD 4-6", EFI Live dsp5, Airdog 150, RDL's uppipes, SC IV w/1056, 6" stacks, Wherli Fab S366 intake, all custom led lighting & quad morimoto HID's, x2 12" subs, pillar gauges, debadged, Cognito brace kit & HD tie rods, Bilstein 5100's, 35x12.50 m/t atz's w/ 20" chrome rockstars
12.67 @ 105 w/ stock fuel system
Old 07-16-2017, 10:50 AM
blue09dmaxx's Avatar
blue09dmaxx blue09dmaxx is offline
Too broke for this shit
Stay 9 or 10 wide. I had 12s and wasn't a fan, have to run a smaller tire to clear
2007.5 CCSB LMM 4x4
EFI Live by PPEI, built trans
Sold: Too many
Owned 2-lb7,1-lbz,6-lmm,1-lml no lly
Old 07-16-2017, 11:54 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
It's actually Zach
I personally love my 22x12s. 20s just aren't big enough for me and I like the width. If I had to do it again I may go with 10s. But no smaller than 22. Nice wheel to tire ratio with 35s. Probably get flogged for that but hey whatever
2002 Chevy EC/SB LT 4x4. S&B intake. 5" Magnaflow SP. LML manifold. PPE stage 5 tranny. 30% over Bosch injectors. LBZ SuperSport pump. Studs. All powder coated. EFI by Ridge Runner. Twin Kennedy pumps & pickup. Glowshift gauges. Edge insight cts. Gear 22x12s and 305/40 Proxes ST
Other toys:
"Tank" 1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inches of lift and 35s. Slow and indestructible
2011 Yamaha YFZ450X
1992 Yamaha Waverunner 3
Old 07-16-2017, 11:57 AM
yepppp
I plan to use the existing 35x12.50 Toyo MT's. I bet tires for 22's are $$$.
Old 07-16-2017, 12:00 PM
If you plan to stay your suspension height and same tires go 9 or 10. 12 wide will run
2007.5 CCSB LMM 4x4
Sold: Too many
Old 07-16-2017, 01:24 PM
WVRigrat05's Avatar
Wound for sound
I'd run 17x9 or 20x10.
I'm old school, I like 17's. And I love the durability of the fuels.
Reger
100k miles-FOR SALE
Wife's ride- 2016 Pearl white Legacy limited 3.6R 15k miles, garage ornament
Rig ride/patience tester-02' Black Eddie Bauer exploder 4.6, -180k, still sporting original trans (for now)
Old 07-16-2017, 03:08 PM
ChrisPerry's Avatar
I like my moto-metals. 20x10's and 35 12.50's. 6" lift cranked a little.
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 260 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
Old 07-16-2017, 03:27 PM
zakkb787's Avatar
It's actually Zach
With a 4-6 you probably wanna stick with a 0 offset. If you wanna keep your cv angles as flat as possible that is
Other toys:
2011 Yamaha YFZ450X
  #9
Old 07-16-2017, 03:45 PM
yepppp
I'm running 20x8.5 right now with +10mm offset and 5.14" BS. If I went with 20x10, Lift kit specs says it will allow up to 5.15" BS. What is the maximum negative offset I could run?
  #10
Old 07-16-2017, 03:55 PM
zakkb787's Avatar
It's actually Zach
From what I'm seeing online, anything more than a -12 offset in a 20x10 of going to have too much backspacing for you. But that means they will stick out more and more trimming. You might be better off staying with a 9, but ultimately it's up to you. I might would get 10s or 12s and crank it up till your tires wear out then step down to a 33 and lower down. From the pic in your sig you don't look trimmed much at all. Anything 10 or wider youll probably need to. Not much. But some.
Other toys:
2011 Yamaha YFZ450X
  #11
Old 07-17-2017, 09:09 PM
2008lmmchopper 2008lmmchopper is offline
That's tough one. Whatever you heart desires buddy. I never did like the deep dish look. I like -22 at most but that's me. Surprised you put chrome rims on in the first place. They look good tho. It's not even real chrome anymore. Just a layer of it.
Sent from my STV100-2 using Tapatalk
  #12
Old 07-18-2017, 02:52 AM
yepppp
Chrome began pitting after one year too. I'm actually tossing around the idea of going with new style 20" GM wheels polished for 8x165.1 if I can find them.
  #13
Old 07-18-2017, 03:58 AM
Oewheelsllc.com
2007.5 CCSB LMM 4x4
Sold: Too many
  #14
Old 07-18-2017, 05:51 AM
That would look awesome no one does that. I liker that idea. Ya I got told once by a guy at les schwab that the chrome rims now days are fake or they are only a layer or two of actual chrome. I love the new brushed metal look some rims have now too. I wonder if you could custom order a set of GM look alike but with offset lol now that would be savage.
  #15
Old 07-18-2017, 05:59 AM
yepppp
I'm finding some new body style LTZ replicas that fit 2001-2010 8 lug trucks in a polished 20" wheel 8.5" wide...+12mm offset 5.25" BS. They look great! Not sure if they can be trusted though. A little nervous..
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
