  #16
Old 07-31-2017, 04:22 PM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
Default
I think this is the only pic I habe to show it but it's very simple to do.
Sent from my SM-G930V using Tapatalk
__________________
2015 Denali CC/SB LML, Farm Truck
2013 EC/SB LML, The Test Rig
2013 RC/LB LML, The Beater
2006 RC/LB LBZ, Tow Mirror Killer. Under the knife again and looking for more horsepuppies.
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
Performance Fueled
www.Facebook.com/PerformanceFueled
  #17
Old 08-02-2017, 11:49 AM
dirtymax36 dirtymax36 is offline
2nd place is last
Default
Ive got most clamps and flanges ordered, down to a battery relocate bracket to mount underneath the radiator and then picking my pipe out.
Whats everyone using as far as thickness goes? As of now its going to be made out of mild steel or stainless. Been looking at using 3 inch for my hot pipe betweeen charger exhausts, wasnt sure what guage of steel to use. 16 guage seems to be most common, although i want to do this the correct way and never have any pipe blowouts
__________________
04.5 LLY CCSB Built Motor/trans. Some fast spinny things.
  #18
Old 08-11-2017, 04:15 PM
Kunz111 Kunz111 is offline
Gearhead
Default
I thought a single 369sxe was good for about the 800 range?
  #19
Old 08-14-2017, 03:02 PM
2nd place is last
Default
it is. just dynoed last weekend making 789/1243. just looking to have a quicker spooling setup, not so outrageously loud exhaust, and better low end torque for towing.
__________________
  #20
Old 08-14-2017, 05:50 PM
Badheartbull Badheartbull is offline
Gearhead
Default
Quote:
Originally Posted by coker6365 View Post
A cheap canton aluminum tank from summit on the firewall works very well. Just weld a bung I to it for the low coolant sensor.
I have a used one for sale. $75 with a bracket I got it from a member on here
__________________
"Charlize the Goldigger"
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #21
Old 08-19-2017, 06:05 PM
2nd place is last
Default
Thanks for the offer, although I am going to use the factory bottle just moved next to the firewall.
Ive also changed my mind, i believe im going to go ahead and wastegate the kit just for added security. Who has experience with gates and possibly the stainless diesel's Gate Plate? Thinking that gate plate will be the most effective and easiest way to plumb in a 38mm gate without buying a 800 dollar turbonetics pedestal. Any opinions would be greatly appreciated!
__________________
  #22
Old 08-24-2017, 11:08 AM
coker6365's Avatar
Default
I may be selling my 50mm synapse gate here shortly. Depends on how it does with the new setup being non gated.
__________________
Performance Fueled
  #23
Old 09-01-2017, 12:58 PM
2nd place is last
Default
Received a 38mm turbosmart wastegate, flanges, and a t6 mount today. Although i spoke with Calibrated power and said wastegates for my setup are not needed at all. Currently getting my act together for plumbing oil lines. Where does everyone pull oil from for the s4 feed ?without pulling away oil from the front of the crank that is..
Also have a s480/96/1.32 on the way.
__________________
  #24
Old 09-19-2017, 10:42 AM
nmband13's Avatar
nmband13 nmband13 is offline
Gearhead
Default
I run a non gated sxe369 0.9 housing/billet s484 1.32. no drive pressure issues. boost is 75 and drive at its peak is 120psi, 4300rpm. 1.6:1 ratio. Dyno made over 1k hp, track times say 1070hp+/- Just referencing my air setup.
oil galley on the RF, in front of the motor mount, remove plug and install oil port fitting.
__________________
'01 Duramax CCSB 550hp daily
'02 Duramax RCLB LBY7 Hybrid
Air, Fuel, Traction and 10.22@136mph
  #25
Old 09-19-2017, 06:30 PM
coker6365's Avatar
Default
Where are you measuring drive pressure and what kind of gauge? Reason I ask is I couldn't push more than 60psi and 750hp before drive pressure got extremely high without gating on my 369/488 setup. Had to gate heavily to keep it to 120psi drive pressure on the big tune. Swapping to a non gated 472sxe now.
__________________
Performance Fueled
  #26
Old 09-21-2017, 06:28 AM
danzick's Avatar
danzick danzick is offline
playing with fire
Default
Another vote for Columbia River mandrel. That's where I got a lot of my bends.
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #27
Old 09-21-2017, 09:10 AM
2nd place is last
Default
Thanks for the votes, I purchased all of my 4 inch mandrel and 3 inch mandrel bends from there. In search for a 364.5 and will start the build here in the next month or so ! Fabricated my own battery relocation bracket to go down by the ABS module and got a PPE coolant tank in. Passenger side engine bay is now open and ready for lift off.
__________________
  #28
Old 09-21-2017, 09:24 AM
2nd place is last
Default
Also, if i have mild steel 10-an drain for the turbo and a mild steel weldable 10an bung, can i weld that into the lower pan up higher near the rim? Since i have 2 extra pans here it would make life much easier. Thanks in advance
__________________
  #29
Old 09-21-2017, 11:39 AM
danzick's Avatar
playing with fire
Default
When I was building mine, I went to the upper aluminum pan. People seem to frown on the drain being that low.
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #30
Old 09-21-2017, 11:42 AM
2nd place is last
Default
Not being a smart here, but what's the negative effects of having it that low? I figured it would be way easier that way because I have PPE manifolds on mine and can't really get a drill in there
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
