  #31
Old 09-21-2017, 11:50 AM
danzick's Avatar
danzick danzick is offline
playing with fire
I never understood the reasoning behind that. No matter where you dump the oil, it will still flow to the static oil level. But, it wasn't going to gamble my only oil pan, so I went the tried and true method. My local diesel shop dumps the oil somewhere in the valve cover.
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #32
Old 09-21-2017, 01:48 PM
dirtymax36's Avatar
dirtymax36 dirtymax36 is online now
2nd place is last
The valve cover? That's something new I suppose haha
04.5 LLY CCSB Built Motor/trans. Some fast spinny things.
  #33
Old 09-21-2017, 03:00 PM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
I think Trent Nell did some kits that way,it works if you mount the turbo high enough. Thats how I want to do mine when/if I get that far, the other option is the front of the upper oil pan.
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #34
Old 09-21-2017, 06:13 PM
S Phinney's Avatar
S Phinney S Phinney is offline
I think the upper front oil pan is by far the best location. Easy access and the best drain position.
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #35
Old 11-19-2017, 07:47 PM
dirtymax36's Avatar
2nd place is last
Got all the piping fabbed up and on. Currently fighting fitment for the intake and MAF. Waiting on a silicone boot elbow and should be complete besides oil drain sndbpowder coating the piping once I test run it to make sure there's no leaks. I'll try to upload some pictures from the process.
Secondly, what's everyone using to clean the inside of the pipe before you run the Truck? As far as welding slag, welding wire that may have fallen inside and stuck, etc. I got most of it all clean, just paranoid to ruin $3k in chargers. Thanks in advance
  #36
Old 11-19-2017, 07:51 PM
danzick's Avatar
playing with fire
I'm guessing you used a mig welder instead of a Tig. Die grider with a carbide or flapper sander would be the best bet.
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #37
Old 11-19-2017, 07:53 PM
dirtymax36's Avatar
2nd place is last
Mig correct. I'll have to do that
  #38
Old 11-26-2017, 07:53 PM
dirtymax36's Avatar
2nd place is last
I finished it all up and is running. Waiting on Starlite to get it tuned this week and let it rip. Right now it wont do much due to the MAF not scaled correctly. So far, knock on wood, no leaks or weird noises.
I have pictures but cannot upload them for some reason, if someone on here would allow me to text them to them to upload, that would be great.
I have also considered picking up a billet 7 (or maybe 6?) blade wheel from Bullseye during the Cyber Monday sales, although does anyone on here have experience with upgrading a cast 80 to billet 80? as far as sound, spool, and performance? Just asking due to the fact I would have to send it off to somewhere to be balanced and cost of the wheel alone ($350).
Thanks to all have contributed!
  #39
Old 12-31-2017, 02:37 PM
dirtymax36's Avatar
2nd place is last
  #40
Old 12-31-2017, 02:42 PM
dirtymax36's Avatar
2nd place is last
Here's a few pictures throughout the assembly process. took lots of time and patients but overall wasnt bad.
-Huge thanks to Starlite diesel tuning for the help and fine tuning. This thing rips and spools near instantly. The truck will be put on a dyno with a drive pressure guage soon to record data and make sure i wont need to Plumb in a wastegate. If it doesn't tow a trailer well, Ill be switching either the valley charger housing from a 1.0 to a .91 or on the atmo 1.32 to a 1.10 to keep it going without hurting my overall goal of 900hp
-Also will be doing a 6 speed swap on the truck here soon with one of the new soon to be released kits to use a unlocked TCM.
Overall its a blast to drive and drives like a gas truck with a punch. Once its off idle it is extremely quiet and cruises down the highway as quiet as a stock exhaust truck. Anyone looking to do a similar setup feel free to ask questions.
  #41
Old 12-31-2017, 03:10 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Looks really nice. All that wrap on your DP is going to make it rust faster. Maybe remove that last 1'-2' of it? Everything below the exhaust manifolds that was wrapped on my truck was starting to pit badly after a few years and I just vacation into areas that get winter weather and salt.
06 GMC 2500 CCSB SLT LBZ 4X4
  #42
Old 12-31-2017, 03:13 PM
dirtymax36's Avatar
2nd place is last
Thanks! And I thought about that also, forgot to include the truck doesn’t get drove in the winter and once I can get some miles on it to prove it doesn’t leak or need any other fan work, the piping and turbo covers are coming off for powder coating along with the down pipe
  #43
Old 02-18-2018, 03:22 PM
dirtymax36's Avatar
2nd place is last
Alright looking for some advice again...truck is very fun to drive, although it’s still a little on the laggy side and once the converter locks, especially in 5th at highway speeds, it still acts and spools like a big single. Multiple logs and revisions have helped out a lot although it just isn’t cutting it. Hardly and low end torque for towing. I’ve thrown around the idea of going down to a .88 or .91 housing in the valley and if that doesn’t help go down to a 1.15 on the 480, although I believe this will hurt my overal top HP a lot down to the 800 max range. My tuner also says going smaller on the valley housing will make drive and cyl pressure skyrocket.
My other option is to step back into a per day 65mm 3794 or a 68r in the valley to gain some spook and low end power.
Running a goerend R 2400 stall converter BTW.
  #44
Old 02-18-2018, 04:42 PM
rcr1978's Avatar
rcr1978 rcr1978 is offline
What did you end up with on the valley charger? I got that you went with a SXE 64.5 was it the big turbine and 1.0 housing?
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #45
Old 02-18-2018, 07:44 PM
dirtymax36's Avatar
2nd place is last
Final setup is a sxe364.5/74/1.0 with a billet 6 blade 480/96/1.32 t6. Wagler stage 1 cam and head job. 20over bore
