  #16
Old 07-08-2017, 11:44 AM
JRein JRein is offline
Aircraft Mechanic's Hero
Default
Quote:
Originally Posted by aashton1206 View Post
Brent hooked me up with the same thing. Six blade two tier wheel so it lights faster and has a larger bore. Can't wait to install after I get the truck back from my trans builder.
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, DSP 5 on v2 by Rick Fletes, 33x12.5 nittos at on 20 inch American Racing wheels, modded factory air box, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust, 10mm lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Contol arms, Drilled and Slotted Rotors on all four Corners, Custom Y Bridge.
for about $170 you can replace seals and bushings in the turbo as well. Then it will basically be brand new. It's not hard yellowchevy has a write up that's easy to follow but might be on another forum.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
__________________
-J.R.-
_______________________________________________
2004 LB7 2500HD 4X4 CCSB
Mods: LDS 63.5mm turbo, 45% SAC injectors, Built Allison, Mishimoto IC piping, EFI Live, Modded stock intake, Modded intake horn, Intake heater Deleted, Water separator/10 micron/Lift Pump, CAT Filter, 3" down pipe, MBRP 4", Incognito tie rods, High Idle, MA pump rub kit
Tunes by Idaho Rob
Trans Kit from Evan @ Limitless Diesel
  #17
Old 07-08-2017, 11:49 AM
aashton1206 aashton1206 is offline
Default
Already have it torn down in my shop. Just waiting to reassemble it
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
