  #16
Old 01-05-2017, 10:28 PM
pharoah95's Avatar
pharoah95 pharoah95 is offline
FNG
Default
have any of you guys ever ran the stealth 64 cause it seems like a good option from what you have been saying
__________________
lb7 duramax,stock injectors, 10mm stroker cp3, built transmission, sxe366turbo 165gph air dog2 pump, alternate firing Cam, efilive by idaho rob, trans tuning a team performance. and more go fast goodies
  #17
Old 01-05-2017, 10:41 PM
dordtrecht5's Avatar
dordtrecht5 dordtrecht5 is offline
Regular Cabs Rock
Default
My opinion: I would do Russ's 63.5 modded IHI before a Stealth 64. The Stealth, IIRC is a 63.5 anyway. Plus, Russ will port and polish and (I think) you can select the wheel you'd prefer. I'd go with Wetzel. And, the Danville 2.5 is also a 63.5mm.
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
Super High Flow EGR delete kit and Centerlink support by AllSeason
GMAX6 & ML-G HD
BT DieselWorks Lock-up
12.59 @ 105
SOLD
02 CCSB LB7 EFI Big tie rods/PacBrake bags/DVD Pioneer head unit Rockford Fosgate speakers/110-120voltAC inverter/Mastercraft MTR
Thanks go out to 770JOHNNYW and blk smoke lb7
International Association of Bridge, Structural, Reinforcing and Ornamental Ironworkers Local 21 Omaha, NE
United Steel Workers Local 1343 South Milwaukee, WI
  #18
Old 01-05-2017, 10:50 PM
Regular Cabs Rock
Default
The Fleece IHI 63 is another option. Its machined for an S300 cartridge. Not sure if Danville's 2.5 is an S300 cartridge, but the others are a stock IHI cartridge and turbine.
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
GMAX6 & ML-G HD
12.59 @ 105
SOLD
  #19
Old 01-05-2017, 11:10 PM
BlkMax's Avatar
BlkMax BlkMax is offline
Default
I like the s366 as a primary. I have a gated HTT T3 S366 with a SS hot side, and an ungated S366 T4 on 2 different LB7's. The gated one is tripled on BlkMax.... bent rods and all. I have the ungated on Emma, and like how it works.
If $$ is your main issue, I would go with a T4 S366 74, 0.91 and get a gated pedestal with a block off plate until you want more HP.
I cannot speak to the SX-E's, never had one, but they sound cool...
For me, I had to go to something else besides stock at the time because I had smoked my IHI.
__________________
Black Max....
Black Max, the fun truck:
'03 2500 4x4 CC/LB
Bent Rods, now under construction, its time to put all the saved up parts in....
Special thanks to Pat & Kat McSwain, MikeL, Guy, Trent, and others from here-thank you for the great ideas!
EPR triples
Emma, my DD:
'04 2500 4x4 EC/SB
HTT T4 366 74 .91, 65% SAC's from LDS, Trans Kit from Evan, tunes by Zach at Starlite
  #20
Old 01-05-2017, 11:13 PM
BlkMax's Avatar
Default
I can tell you for certain that an S300 primary works well for towing. I have never had an S400 as a primary.
__________________
Black Max....
'03 2500 4x4 CC/LB
EPR triples
Emma, my DD:
'04 2500 4x4 EC/SB
  #21
Old 01-06-2017, 09:48 AM
pharoah95's Avatar
FNG
Default
well i do have an extra stock turbo i could send out to get to get machined possibly from russ wonder what the cost would be? probably have to send him a message, and/or what 366 turbo would you use.
__________________
  #22
Old 01-06-2017, 10:35 AM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
Quote:
Use the Sxe 366. Best for the dollar for what you are wanting to do.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #23
Old 01-06-2017, 11:39 AM
Regular Cabs Rock
Default
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
GMAX6 & ML-G HD
12.59 @ 105
SOLD
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
