  #1
Old 01-05-2017, 01:45 PM
pharoah95's Avatar
pharoah95 pharoah95 is offline
FNG
Default can't decide on turbocharger for build
alright so i've been upgrading my truck its my DD and i use it to tow, the turbos i've been looking at are the stealth 64, and been told about the bd supermax and i've heard about some other options, my goals are the truck that its currently going in i'm only looking to get around 5-600 hp and maybe get over 1000ftlbs but i have another engine i'm building up to swap into it that i want to get atleast 800 out of maybe reach 1000hp and still be able to daily driver and tow with it, so i would like to use the turbo i get for the first engine to be able to swap over and be the valley turbo and i would still like quick spool up being fairly important, the silver bullet 66m seems tempting to anyone have experience with any of these turbos
  #2
Old 01-05-2017, 05:42 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Moved to Turbo Talk section. Id give Mark at Danville a call and ask his opinion.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #3
Old 01-05-2017, 06:49 PM
dordtrecht5's Avatar
dordtrecht5 dordtrecht5 is offline
Regular Cabs Rock
Default
Compound it with an S475. Or...have your turbo worked by Russ (yellowchevy). He's a vendor here.
Later if you want to go big and get more power in a build, go with an S362 (or up to a 64) high pressure and a 480ish atmo.
These setups have been reliable platforms for quite a while now. Two of the things that you'll run into with a single is drive pressure and egts, especially if you pull in the hills.
I'm in the process of working through my build with the same max effort power goals as yourself. One of the things I've learned over the years Is "go with a proven Platform" unless you have bottomless pockets and a money tree. Builders know what they are talking about because they have seen most everything that's a failure and a proven system.
I'm going to go with a 362sxe or so (maybe up to a 64) and an 478, or up to an 83. Probably a little more cam and heads to get to 850 max effort, but be a very reliable towing truck in the 550 range. I haven't decided what make of turbos to go with yet, but you'll find the BW turbos are less expensive and more readily available. Garretts are proven, but you pay more for the technology and name.
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
Super High Flow EGR delete kit and Centerlink support by AllSeason
GMAX6 & ML-G HD
BT DieselWorks Lock-up
12.59 @ 105
SOLD
02 CCSB LB7 EFI Big tie rods/PacBrake bags/DVD Pioneer head unit Rockford Fosgate speakers/110-120voltAC inverter/Mastercraft MTR
Thanks go out to 770JOHNNYW and blk smoke lb7
International Association of Bridge, Structural, Reinforcing and Ornamental Ironworkers Local 21 Omaha, NE
United Steel Workers Local 1343 South Milwaukee, WI
  #4
Old 01-05-2017, 06:58 PM
Regular Cabs Rock
Default
I will not consider a Silver Bullet 66 as a high pressure turbo. FWIW
Adtermarket Up pipes on a stock or modified stock turbo would decrease drive pressure with good tuning and you'd get close to your immediate goal of 600. You could then go with a 478 with more fuel to get close to 800later.
I've seen this set up and it made 794 at the wheels.
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
GMAX6 & ML-G HD
12.59 @ 105
SOLD
  #5
Old 01-05-2017, 07:22 PM
Awenta's Avatar
Awenta Awenta is offline
Default
This for a Colorado?
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #6
Old 01-05-2017, 07:45 PM
pharoah95's Avatar
FNG
Default
nope its for a 2003 chevy 2500HD and i have done quite a bit of research for the big engine build currently have another 2003 lb7 i`m taking apart for that but am trying to save a little money on parts that will crossover to the other engine. the one big thing i`m having problems with is the turbos, and you would`t go with the silver bullet as the high pressure? why is that? and yea i've been seeing the yellowchevy guy alot on these forums alot of people seem to suggest him, so would you think the stealth 64 or modified stock?
__________________
lb7 duramax,stock injectors, 10mm stroker cp3, built transmission, sxe366turbo 165gph air dog2 pump, alternate firing Cam, efilive by idaho rob, trans tuning a team performance. and more go fast goodies
  #7
Old 01-05-2017, 07:58 PM
DangerousDuramax's Avatar
DangerousDuramax DangerousDuramax is offline
Default
Go with a S480 BatMo or S488SX-E over stock which will take care of all your power and EGT needs now and give you plenty of room to upgrade the valley charger later for the 1000+hp build.
__________________
05 2500HD CC/SB, LT, 2WD, Black
AFE Stage II w/Pro-Gaurd 7; E/J w/A;
4" MotoBlue straight piped no CAT; EGR blocked and Fingered; PCV Bypass; TranSynd; Low beam/fog light mod; High idle mod; UC6/LUX
US Navy EOD (Desert Storm)
Jer 33:3 Cry out to me and I will show you GREAT and MIGHTY things that you do not know.
Do everything on purpose for a purpose lest it be a thorn in someone's side and waste of everyone's time.
  #8
Old 01-05-2017, 08:08 PM
boostwhore's Avatar
boostwhore boostwhore is online now
Drag racer wannabe
Default
If it were me I would do a 480 over the stocker, then when you get engine built throw a bigger high pressure charger over it.
__________________
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, tuning from Arron at All in trucks.
Best 1/4 to date: 11.35 in the chase for 10ís.
  #9
Old 01-05-2017, 08:20 PM
pharoah95's Avatar
FNG
Default
well i got a stock turbo right now with a big head wastegate and the ppe boost valve, it seems like alot of people are saying to twin it would it have alot of lag with the stock turbo or should it be fine for towing
__________________
  #10
Old 01-05-2017, 08:36 PM
Default
Quote:
Plenty of combinations that will let a twin setup spool close to stock. If you're towing the twins really shine because they drop your EGT's. If you plan to make 1000+hp you will have to have twins anyway.
__________________
  #11
Old 01-05-2017, 08:37 PM
Default
Quote:
I just realized why you asked that. Tom this thread is in the wrong place.
__________________
  #12
Old 01-05-2017, 08:42 PM
pharoah95's Avatar
FNG
Default
i did plan on running twins always wanted to on my truck my biggest problem is just trying to decide which turbos to use
__________________
  #13
Old 01-05-2017, 08:56 PM
Awenta's Avatar
Default
Nothing will spool as fast as the stock turbo. Twins will take advantage of that. A stealth 64 or Danville 2.5 state 2 would be great too.
HTT made a nice drop in turbo too
Quote:
It was throwing me off some
__________________
Arek
EFI by Kory
  #14
Old 01-05-2017, 08:57 PM
Awenta's Avatar
Also a 64 in the valley is capable of making over 1000rwhp when twinned
__________________
Arek
EFI by Kory
  #15
Old 01-05-2017, 09:59 PM
roxyfever roxyfever is offline
Default
Stealth 64 with a s488sxe with enough fuel makes 1000hp. Duramaxtuner has this in a burb. With a 14mm cp3 and 150 overs. Very streetable
__________________
2003 v6 explorer
Wifes ride
2009 cclb srw 4x4
6.4 powerstroke
stock 140k miles
Previous rides
03 lb7
99 cummins
07 lbz
04 lb7
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
