  #1
Old 05-12-2015, 04:54 PM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default tct wheel stock lly charger\twinned
Just curious about future plans. Has anyone ran the tct wheel in in the stock lly charger and have any kind of review on the subject? And if so has anyone twinned over it. Was wondering if I redid my ar and turbine on my tct 75mm, how it would do over a tct stocker?
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
  #2
Old 05-12-2015, 05:07 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Got ya to thinking huh...
__________________
17 GMC all terrain L5P, stock with dark windows
07 crew long classic- stolen
  #3
Old 05-12-2015, 05:26 PM
zf>allison's Avatar
Default
Quote:
Oh yeah when the trucks down its all I do
__________________
best
Instagram-636zf6
  #4
Old 05-12-2015, 05:46 PM
zf>allison's Avatar
Default
Has anyone run one just as a single in the stock charger?
__________________
best
Instagram-636zf6
  #5
Old 05-12-2015, 05:49 PM
clrussell's Avatar
pro-procrastinator
Default
Quote:
I've not done a tct, however I did put a batmo in one and wasn't really impressed with results vs effort..
__________________
  #6
Old 05-12-2015, 05:53 PM
Moneywellspent's Avatar
Moneywellspent Moneywellspent is offline
Default
I've done a batmo. As far as what I think if your doing extra stuff while your in go for it. Just make sure you have it balanced. And it did provide gains as far as spool up goes. You could tell the difference. If you know how to pull the charger quick and easy than I'd say go for it but don't expect marginal gains.
__________________
Low and slow built LBZ | Big single| SSDT Dsp5
  #7
Old 05-12-2015, 05:54 PM
zf>allison's Avatar
Default
I've read that they move alot of air at a slow shaft speed. Being on the stock vgt turbo might be what I need for this manual. Then if I drop my biggen on there?? But i don't know how the big one would want to push through it and what not
__________________
best
Instagram-636zf6
  #8
Old 05-12-2015, 05:57 PM
zf>allison's Avatar
Default
Quote:
like a batmo or double bat or the tct? Not expecting a miracle just something different and that would work well for me. I don't know what the hype is on what it will do in a stock charger maybe I can try to see what that will do alone, just wanted some reviews
__________________
best
Instagram-636zf6
  #9
Old 05-12-2015, 06:16 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
If your going to that trouble it would be best to have Russell port that sucker as well. I think you would see more gains with a port job and the wheel. In fact he was doing some tests and posting results.
As far as working good twinned. The fastest spooling my truck ever was is when I ran the stocker and GT4202R (75mm). It was a lot of fun on the street and pulled trailers like a dream. What I'm running now spools much slower but has way more power potential for the future.
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #10
Old 05-12-2015, 06:27 PM
zf>allison's Avatar
Default
Might be worth doing, wonder what a port job costs. Probably would be fun on the street, I don't know if it's worth the money and trouble for what I do in it. A 75 alone was fun on the crew for a very short time. I'm thinking maybe go with 3.42 gears and twins. But in the way early stages lol. I think the taller gears would help it come alive a little more in the lower gears. And help calm the launch down, I think 3.42s would help. I wish I had a 2 1\2th gear lol just to launch in.
__________________
best
Instagram-636zf6
  #11
Old 05-12-2015, 07:01 PM
02greysixer's Avatar
02greysixer 02greysixer is offline
Default
I'm going to keep an eye on this. I'll be ready to do something with mine in the next couple years. Been wondering in my head what the best twin setup for a manual was.
__________________
2010 LMM CCSB LT
4" Flo-Pro
FASS 150
Beans Sump
Leveled w/ drop shackles
RidgeRunner Tunes
More to come
Rip zf6 swapped lly
  #12
Old 05-12-2015, 07:12 PM
zf>allison's Avatar
Default
I'm gonna go back and watch vids. I dont think my stock turbo does much til half way through 3rd which happends fast. But i don't think a big single will be ideal for getting of the line under no boost. But I'm on 285's there like 30 inches tall, so gearing and setup I do should work well with drag radials the same height. I half to hit third so quick after 2nd on a launch, 2nd needs longer legs. With taller gears I hope I can get a good hit with whatever turbo setup I have pretty early in third.
__________________
best
Instagram-636zf6
  #13
Old 05-12-2015, 07:22 PM
zf>allison's Avatar
Default
Looks like 20 psi max in second and third, then mid to upper 30s in 4th 5th and 6th. That's powershifting. It's alot lazier recovering from a normal shift. I would honestly probably throw the 75 over the stocker first and just see what's up. Then mod the stocker if it's not what I'm going for.
__________________
best
Instagram-636zf6
  #14
Old 05-12-2015, 08:56 PM
countrycorey's Avatar
countrycorey countrycorey is offline
Trust Me I'm an Engineer
Default
Talk to mark at Danville about the TCT wheel.
Corey
__________________
2007 Chevy Classic CCSB LS 4x4 w/ LBZ & 6 Spd Ally
Graystone Metallic
295/70/17 Nitto Trail Grapplers on Chrome H2s w/ LMM Centers
Custom CamLocker Toolbox
Grizzly Nerf Bars
Pioneer 4100 Head Unit
JL Audio Components
Sportsman Max4 Seat Covers
MPI GT4202/Stock
HSP Coolant Tank
Tinted Windows
MBRP 5"
PCV Rerouted
EGR Blocker & Fingerstick
Nicktane 1 Micron Filter & Adapter
Banks Hot Side Intercooler Tube
ProFab Y-Bridge and 3" Cold Side Boost Tube
AutoMeter Phantom II Boost and EGT on A-Pillar
Hammerhead Armor Replacement Front Bumper
EFILive from IdahoRob
Fleece All On Mod
  #15
Old 05-13-2015, 10:21 AM
zf>allison's Avatar
Default
Bump for review on tct wheel in a stock charger as a single
__________________
best
Instagram-636zf6
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
