Old 10-06-2017, 06:10 AM
elliottw's Avatar
elliottw elliottw is offline
Default Where to buy Tech 2?
Where are you guys getting your trusty cheaper tech 2s from? I see a lot of them on google searches for 2-300 dollars but that seems cheap even for the Chinese knock offs? Or have they gotten cheaper in recent years?
2009 LMM- DSP5 by ATP, supporting mods SOLD
2005 LLY- DSP5, built tranny, supporting mods SOLD
2007 LBZ- Moonshine DSP5, supporting mods
Old 10-06-2017, 06:20 AM
wilsondiesel's Avatar
wilsondiesel wilsondiesel is offline
I paid $300 for mine, lasted right at a year before I fried it...
2002 LB7 the fun truck
2001 LB7 the beater with wide hips
DD-2001 VW Jetta TDI 5 speed
Old 10-06-2017, 09:41 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
My brother and I each bought one for $360 from eBay. My brother's worked perfect, but I had to go through 3 of them before I got one that worked right. (Seller covered all shipping, can't complain too much.)
Jury's still out on how long they will last, but you can get one for $300-ish that will work, at least for a while. I figure when mine craps out, I will just take it apart and fix it, but that's not something everyone can do.
Old 10-06-2017, 09:48 AM
Mine doesn't power up at all when plugged into obd2 port, is there an internal fuse?
Old 10-06-2017, 03:05 PM
DAVe3283's Avatar
The power supply could have failed, or the OBD port itself could be dead. Do other scan tools power off that OBD port, and does the Tech2 work off the AC adapter?
Sent from my S60 using Tapatalk
Old 10-06-2017, 08:36 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
The knock off tech 2's have a known issue with the power supply. It normally causes them to shut off during cranking, but they can completely fail. If you search, theres a page that gives info and pics on how to repair the common failures in them.
Old 11-08-2017, 09:13 PM
48548 48548 is offline
Gearhead
I bought a tech 2 knock off and 2 mdi versions... I prefer the mdi. New gm mdi2 versions are only 700-800 from gm with a warranty... just saying.. I do like the mdi.
