  #1
Old 11-13-2017, 05:44 PM
danzick's Avatar
danzick danzick is offline
playing with fire
Default hard starts
This has been an issue for a couple years now, but it has gotten much worse. When I start the truck at 45 degrees or under, it knocks like crazy, idles like crap and smokes the shop completely out in a few seconds. Once It warms up for a minute or so, the idle smooths out and it runs fine. Truck runs great, balance rates when warm are all great, I just replaced all 8 glow plugs last year in hopes of solving the issue but it didn't help at all. When I replaced the glow plugs, I verified the relay was working via a test light. About 5 seconds after the light expires I can hear my lift pump ramp way up and the volt meter goes up, so I'm assuming the relay is still working.
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #2
Old 11-13-2017, 05:53 PM
danzick's Avatar
playing with fire
Default
My old rattly 94 12 valve cummins daily driver with 270,000 miles starts with ease, smooth and hardly smokes at 10 degrees. really confused why this common rail is so horrible.
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #3
Old 11-13-2017, 06:00 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
I have a 325,000 mile LB7 with lowered compression, no intake air heater, +75% race injectors, and mine starts clean at 13įF with no rattle or smoke.
I really don't know why these common rails are so horrible. LOL
There is clearly something wrong with your specific truck. What all has been done to the truck? If it is tuned, that's probably the issue.
Edit: signature says PPEI tuning. Try flashing it back to stock and try a cold start.
Sent from my Cat S60 using Tapatalk
__________________
  #4
Old 11-13-2017, 06:18 PM
danzick's Avatar
playing with fire
Default
I do have the intake heater deleted. I don't have the stock file for the truck anymore. Long story, but it involves my original ECM being bricked. running it on 1 or 5 on the dsp doesn't seem to make a difference. It has 81,000 on the clock. I believe I replaced the injectors at 68,000. It seems to start fine when its warm, so I don't think its a leaking injector.
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #5
Old 11-13-2017, 06:21 PM
DAVe3283's Avatar
Default
I bet it is tuning. If you know someone nearby that you could borrow a stock ECU from, you could do that. Just do the 30-minute anti-theft relearn, then let it get cold and see what happens.
You could also try and get a dealer to flash a stock file on, or find one online. This assumes you have the ability to put your PPEI tune back on. Also, you might be able to contact PPEI and see if they kept the stock tune.
__________________
  #6
Old 11-13-2017, 06:24 PM
danzick's Avatar
playing with fire
Default
I do still have the stock file, but I don't think it will work in the new ecm?
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #7
DAVe3283's Avatar
Default
Quote:
It should work just fine. Just do a full flash to remove the DSP5 code, or it will get angry. And do a full flash to put the DSP5 tune back when you're done testing.
__________________
  #8
Old 11-13-2017, 06:29 PM
danzick's Avatar
playing with fire
Default
thanks, I will give it a try. I also emailed Kory a copy of my dsp5 file to double check everything.
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #9
Old 11-13-2017, 07:12 PM
Josh154's Avatar
Josh154 Josh154 is offline
Default
What glow plugs did you use? I replaced mine with 8 Diesel rx plugs and didnít get any codes for a couple weeks but truck was knocking and smoking and shaking real bad. The codes finally showed up and had 6 bad plugs. Replaced them all with 8 ac delcos and the truck fires right up now no smoke or nothing. This is how bad it was and still didnít throw codes for 2 weeks lol.
__________________
08 CCSB LMM - HSP 369sxe kit, 10mm S&S cp3, built trans with suncoast 1058, supporting mods and Danville tuned
Best 1/4 mile
12.86 - 104.92mph
  #10
Old 11-13-2017, 07:53 PM
danzick's Avatar
playing with fire
Default
All new acdelco
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #11
Old 11-13-2017, 07:55 PM
danzick's Avatar
playing with fire
Default
That video it's pretty dang accurate. But more on a colder say. Say 20 degrees or lower.
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #12
Old 11-13-2017, 08:45 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Thats been my life for a long time. I joke that my truck acts like an old Detroit when the temps get below 35*. I know my problem stems from poor injectors.
__________________
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- in progress
2014 Chevy Cruze Diesel -- the DD
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
From mufflerguy on yb,
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!"
  #13
Old 11-13-2017, 11:05 PM
DAVe3283's Avatar
Default
It could be injectors, but with how low the miles on them are, unless they were junk injectors, it is probably tuning. Not many tuners alter the cold start tables (and there are a lot of them), so it can get cranky as tunes get more aggressive. And honestly, even GM's stock cold start tuning was kind of crap. I made improvements to that when my motor was stock even.
With some effort (OK, a lot of effort), you can even have a built motor with big injectors start and run clean in the cold:
__________________
  #14
Old 11-14-2017, 06:59 AM
danzick's Avatar
playing with fire
Default
interesting. I will have to see what Kory says. They were LDS injectors.
__________________
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
