  #1
Old 11-11-2017, 08:30 PM
slowlb7's Avatar
slowlb7 slowlb7 is offline
Default Rail pressure is more then 3k lower and no code
My rail pressure at wot is 66mpa desired is 174 mpa I don't get a code and truck is way down on power it has new fuel filters and a 175gph lift pump set at 14psi at idle it drops to around 11-12 at wot any help would be great
__________________
2002 Idaho robs built trans tunes,suncoast converter/trans,downpipe,5" exhaust ,3500 springs, dmaxstore motor mounts,gauges,lift pump,tank sump,intake heater delete,ppe cooler/ppe deep pan,lift keys alot of cutting and 35"tires
  #2
Old 11-11-2017, 09:15 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
Could be injectors, CP3 pump, or fprv.
My bet is injectors.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #3
Old 11-11-2017, 09:19 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
[QUOTE=IOWA LLY;1085273]Could be injectors, CP3 pump, or fprv.
X2
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #4
Old 11-13-2017, 06:33 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
The last lb7 I fixed it was the pump. But it would set the code. Only on the owner, though. I apparently couldnt drive it hard enough to set it but I could see it struggling on the scan tool
Sent from my XT1585 using Tapatalk
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #5
Old 11-13-2017, 08:10 AM
Brent@LDS's Avatar
Brent@LDS Brent@LDS is offline
Default
Doing a return rate test on your injectors will show you if your problem is injectors or a Pump.
__________________
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-361-7700
  #6
Old 11-13-2017, 10:30 AM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Mine was a cp3. 02 OS's don't tend to code for low rail pressure in my experience. I had desired up around 25K, but could only hold 13K on mine when my cp3 went. Thought for certain it was injectors, but they didn't return 10ml on a return rate test, same was not said for my cp3's return.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #7
Old 11-13-2017, 07:38 PM
slowlb7's Avatar
Default
I hope it's the pump but still need to do more testing. I did the return test I pulled the return line off at the tank and disabled my lift pump and cranked for 15secs and only got a few drips of fuel which didn't seem right should it return more then a few drips? Also how do I do just a cp3 return test
__________________
  #8
Old 11-14-2017, 12:43 PM
dieselson's Avatar
dieselson dieselson is offline
Default
My 2002 wouldn't set a low rail code until it was down below 10k rail pressure at WOT. I replaced the FPRV with a race valve, and replaced the CP3 and my problem was fixed. It could also be caused by high injector return rates as others have said.
__________________
My Truck: 02' Chevrolet EC/SB Auto, Mods: EFI Live, PPE Boost increase Valve, PPE Steering Parts, LBZ CP3
Best Time: 8.59@78.2 1/8th
  #9
Old 11-14-2017, 07:25 PM
ironmax's Avatar
ironmax ironmax is offline
chock full of goodies
Default
mine was pump related , and I experienced the same issues with rail pressure
__________________
air intake
Genuine tornados
4inch turbo back exhaust
bosh remans from lincoln diesel, 290k
Stage 3 purple palace
Updated transfer case
EFI dsp5, currently flashed all stock
fass 150
19.5 american eagle alloys, wrapped in 245 goodyears
2 inch leveling keys
cognito upper a-arms
western 8' plow
cody 35,000# gooseneck hitch
Quote:
Your freedom to be you,includes my freedom to be free from you....
  #10
Old 11-14-2017, 07:53 PM
slowlb7's Avatar
Default
went to do a return test but the cp3 will not draw fuel I thought the lift pump was keeping it from sucking fuel so I pulled the inlet line off the fuel filter housing and ran it to a 2.5gallon jug of diesel and primed it tell j was blue in the face and it just keep going out the return line so I cranked the piss out of the truck and it wouldn't suck anymore fuel out of the jug then the primer would so I tried to start it and it won't start if I hook the lift pump back up the truck starts I'm at a loss
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
