  #1
Old 11-08-2017, 09:12 AM
tsd_billy tsd_billy is offline
Default over haul @ 120k miles?
Anyone who follows my build on here knows i put a vgt turbo in my junk but today i decided to take on a different task. The spare motor of my truck has been well neglected in the corner of my barn for 3 years time until my hsp block came back im once again looking into rebuilding my spare to have as a backup. This Engine has 100% stock parts and internals. And had bad fuel knock before the engine was pulled. Confirmed bad injectors but no blowby when Pulled
Am i looking at block machining or just new bearings and oil pump? This motor will likely be a strictly stock /towing build. Turbo will be s366 , ppe manifolds , socal flexplate. New seals new oil cooler etc. just trying to get an idea of how far into this in going since its all stock? arp will also be in it top to bottom
__________________
Vgt swapped lb7, street block built by bobby at Mikes performance engine
  #2
Old 11-08-2017, 11:05 AM
TheBac's Avatar
TheBac TheBac is offline
Default
First things first. You've got to tear it down and see what you have.
If the cylinders and crank are good, Id simply dingleberry hone it, new rings and bearings. Balance the rotating assy....I highly recommend it.
If you're going bigger turbo, Id imagine you're going bigger sticks too? Id cut the bowls on the pistons if thats the case.
No to rods? You could put LBZ/LMM in it for a small margin of safety.
Put some money into the heads...new springs/pushrods and a good valvejob.
New waterpump would be smart, too.
That would make for an "inexpensive" build. With injector cost, you might have $5000 in it. Less if you have connections for the machine work.
My build like this is still on the road and running fine.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #3
Old 11-08-2017, 11:16 AM
Default
Ive already got brand new stock injectors. Its gonna be in the 450hp range so nowheres rear stressing the stock fueling of the sticks. Will never spin above factory as its going into a service body truck. Heads are good. But as far as bearing clearance and ring size i just dont want to order the wrong ones. Im mainly concerned about brands and what sizes i need Since its only 120k miles and was never really beat on.
__________________
  #4
Old 11-08-2017, 11:18 AM
Default
I have a friend who does big block chevys whos let me do all my machine work for the cost of his equipment and supplies so that will likely knock a chunk out
__________________
  #5
Old 11-08-2017, 11:43 AM
aashton1206 aashton1206 is offline
Default
If upgrading the turbo and installing stock stick do yourself a favor and grad a set of sac nozzles 45. Last so much longer
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, PPE Race Valve, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Platinum AGM Duralast, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
  #6
Old 11-08-2017, 11:44 AM
Default
Will do!
__________________
  #7
Old 11-13-2017, 07:21 PM
Default
Got rods with some dots on em
__________________
  #8
Old 11-20-2017, 07:39 AM
Default
What does everyone suggest as far as flexplates go. Seceral options and im not sure what is better tbh
__________________
  #9
Old 11-20-2017, 07:50 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
For a budget build with moderate horsepower goals the bd flex plate is a good option.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #10
Old 11-20-2017, 08:14 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
Am I the only idiot running a stock 325,000 mile flexplate on a built motor?
I figured a flexplate is one part that can be changed "easily" if needed,so why spend money prematurely? I have almost 30k miles on it now, all of which are at 660 RWHP or higher. This flexplate has survived 3 transmissions so far lol
__________________
  #11
Old 11-20-2017, 09:22 AM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
Stock flexplate on mine. Trans has been out twice, no cracks and I wasn't going to replace it until there was.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #12
Old 11-20-2017, 10:20 AM
SickLL7Crenshaw's Avatar
SickLL7Crenshaw SickLL7Crenshaw is offline
Billy The Kid
Default
We been running stock flex plate on my old LLY for awhile now and it's around ~825rwhp. All is good still lol
__________________
Blake
SOLD: 05 LLY CC/SB 140k 11.18@123.7 stock/480
01 LB7 EC/SB 308k 11.31@119.8 69sxe stock motor
Tuned by Unleashed Duramax Tuning
Crenshaw Ranch, LLC. 8LB7s, 7LLYs, 1LBZ , 2LMMs, 1L5P
Thanks to Evan@Limitless, yellowchevy, and Henry@COTNP
  #13
Old 11-20-2017, 10:26 AM
Default
Mine is cracked and the internals are getting balanced thursday. I just donít wanna let it eat and have to tear it back down again
I may buy a new stock one
__________________
  #14
Old 11-20-2017, 10:31 AM
lmmcbrown0917's Avatar
lmmcbrown0917 lmmcbrown0917 is offline
Default
I’m running the stock flex plate/flywheel on my lb7, been making over 1000hp for a year or so now with no issues yet.
__________________
08 LMM, tuned by Mark, built trans by DTS, Danville 68Stg2R, Airdog 165, Snow Performance W/M. 1/8 8.13
02 Lb7 Single cab shop truck, Died 1/3/16.
6.69@103mph 1/8
8/4/16 it's alive...
Fully built lb7, carrillos, 20 over cast fingers, empire stage 2 af cam, valve springs, push rods, stock heads, studs everywhere, Etc...
Stock 250k mile Lb7 crank... Lol
Dual pumps 1 10mm 1 stock, S&S injectors, single billet s476
Trans from Evan at limitless, and tuning from Mark.
  #15
Old 12-18-2017, 12:55 PM
Default
What are the best bearings for the bottom end. I notice they all cost about the same and there are about 5 different options
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
