  #1
Old 04-08-2018, 01:54 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default Raising LMM compression
I bumped the compression up in the LMM to 17.5:1 and itís like a free 50 horse, also Iíve burnt a half tank of fuel in 100 miles. What needs adjusted in the tuning so I know for my knowledge so itís not back in the garage next week.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles. Piston eater.
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #2
Old 04-08-2018, 03:25 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
Quote:
Not tuning related, but how did you bump compression? What pistons did you use? And did you change the rods?
Sent from my Pixel 2 using Tapatalk
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #3
Old 04-08-2018, 03:31 PM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
pistons...
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #4
Old 04-08-2018, 03:35 PM
Yngdmax92's Avatar
Default
Quote:
Originally Posted by paint94979 View Post
pistons...
Okay..... Lol. Maybe I should of been more specific as I'm interested in what he used to rebuild this engine as I know he's not too awfully nice on things and like watching the longevity of the build. So.
Did you use lb7/lly pistons with a thinner gasket?
Or an actual aftermarket piston for the achieved 17.5 ratio?
__________________
  #5
Old 04-08-2018, 03:48 PM
paint94979's Avatar
Beer Nazi
Default
he'll have to answer as to what his specs are
__________________
LLY's are COOL
11.84 @ 115
  #6
Old 04-08-2018, 04:18 PM
malibu795's Avatar
malibu795 malibu795 is offline
Default
Increase CR is free HP increase, throttle response will go up as well
Usually playing with timing map to get the most out of it... If it's sharp rattling need to pull timing.. usually 2-3į will make it stop..
I've found more adjustment was need in part throttle area vs WOT
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #7
Old 04-08-2018, 04:33 PM
WVRigrat05's Avatar
Wound for sound
Default
Mines just snappy around 2200 and drinks fuel, a lot of it. Definitely runs better, it’ll blow the tires off over half throttle on tune 3, don’t like that.
And no rattle, it’s quieter than it was before, just likes fuel and at 2200 rpms it’s like a power band on a dirt bike, something needs cut back for sure.
__________________
Reger
  #8
Old 04-08-2018, 06:16 PM
WVRigrat05's Avatar
Wound for sound
Default
Scratch the fuel, just filled up again and at 1/4 tank it only took 12 gallons, gauge is off worse than before, so I averaged 14.6 mpg on a 7 month old tank of fuel.
__________________
Reger
  #9
Old 04-09-2018, 03:18 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Well that worked out...
__________________
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc...
2015 Corvette Stingray Z 51 < Stock...
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #10
Old 04-09-2018, 06:23 PM
malibu795's Avatar
Default
Mines just snappy around 2200 and drinks fuel, a lot of it. Definitely runs better, itíll blow the tires off over half throttle on tune 3, donít like that.
And no rattle, itís quieter than it was before, just likes fuel and at 2200 rpms itís like a power band on a dirt bike, something needs cut back for sure.
What's tune 3 supposed to be at the re tires... If you picked up ~"50hp" on base tune it will be more on the higher tunes
Maybe you're not used to the extra HP and need to recalibrate your right foot?
__________________
Adam
  #11
Old 04-09-2018, 08:51 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
I seriously doubt it bumped your HP much. It will change the character of your engine's response.
At 17.5 :1 , Mine runs like a raped ape above 2200. Loves to spin. Pulls hard all the way to the 4500 limiter.
But, if I ever have cause to do it over again, I'll go with 16.5 : 1.
__________________
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #12
Old 04-10-2018, 03:31 AM
Default
Why John?
__________________
  #13
Old 04-10-2018, 06:27 AM
Bdsankey Bdsankey is offline
Default
Quote:
Originally Posted by NC-smokinlmm View Post
Why John?
Curious as well. My new motor is 16.5:1
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp 75R", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #14
Old 04-10-2018, 08:25 AM
WVRigrat05's Avatar
Wound for sound
Default
No, I know it didnít, but itís very responsive, gonna have to make some changes so the throttle isnít so touchy, Iím curious how much I need to lower the timing now to keep things happier.
__________________
Reger
  #15
Old 04-10-2018, 09:37 AM
Fingers's Avatar
Village Idiot
Default
Several personal reasons for wanting lower CR. I've had the chance to compare them side by side.
First, and most important to me, the lower CR engines are much quieter and smoother power.
The "bump" in response at 2200 is a pain in the butt with the higher CR engine. I've tuned most of it out, but it has been a struggle. I think the cam is playing a role here on my engine, but have seen the same thing on stock cam engines with higher CR.
I personally have not seen any increase in MPG. Actually the opposite. That is comparing ovals to ovals. But the pistons were not the only mod. So the comparison is not worth much.
I don't think the ring package on the Duramax is up to the task of higher CR. I have not looked into it much other than some chamber pressure observations. Whereas a 16.5 CR piston would show an effective 16.4-16.5 ratio on the pressure graphs, The 17:5 pistons would be more like 17.3-17.4 effective CR. I attribute the drop in effective CR to blow by and have not chased it beyond that.
Lastly, a Higher CR is harder on parts. A jump from 16.5 to 17.5 is about 7% more strain on all the parts just in increased pressure at any load.
Just my opinions. Each to their own. When customers ask, I recommend 16.5 for a Daily Driver, 16.0 if you are running a lot of boost such as with twins.
__________________
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
