  #16
Old 01-08-2017, 09:25 PM
Kblazer87 Kblazer87 is offline
FNG
Originally Posted by Dsword View Post
Should add that 40' container weighs 8300 and trailer is 1500, truck a little over 8000, so just under 18000 total.
You have a 40 foot deck gooseneck trailer that weghs 1500 pounds? That doesnt seem correct.
  #17
Old 01-08-2017, 10:05 PM
07keo02's Avatar
07keo02 07keo02 is offline
Originally Posted by Blackmax123 View Post
My lml dually lifted with 295/70 r 17's averages about 7.2-8.5 towing 18k up and down the hills of central pa. Running 70-75.. problem is now they've raised all our highway speed limits to 70 mph. And I'm not gonna be the idiot riding in the right lane doing 60 mph that all the truckers have to swerve so they don't run over you.. so I don't pay attention to my milage, I just put the fuel range on the display and I stop about every 200 miles and get fuel.
What are the truckers running that they have to "swerve" out of the way to keep from running over a pickup/trailer combo doing (what I would consider) a very reasonable 60 MPH?
On another note, these mileage claims dont have me overly anxious to get out of my 6.0 (gas) and back into a duramax.
2017 Ram 2500 Tradesman CCSB 4x4 6.7
2002 Silverado 2500LS CCSB 4x4 Auto (Sold)
2003 Silverado 2500LS CCSB 4x4 ZF6 (Sold)
  #18
Old 01-08-2017, 10:53 PM
DangerousDuramax's Avatar
DangerousDuramax DangerousDuramax is offline
Your 6.0 cant tow what a Duramax can and your unloaded fuel mileage is much worse as well. So if your pulling light loads and that's what the truck spends most of its time doing then your golden. Otherwise you're loosing money by driving the gasser and have a weight and speed limitation compared to a Duramax or any other diesel for that matter. If you load up your truck and an identical truck with a Duramax and the same heavy load behind them your gasser will suffer far worse mileage.
05 2500HD CC/SB, LT, 2WD, Black
AFE Stage II w/Pro-Gaurd 7; E/J w/A;
4" MotoBlue straight piped no CAT; EGR blocked and Fingered; PCV Bypass; TranSynd; Low beam/fog light mod; High idle mod; UC6/LUX
US Navy EOD (Desert Storm)
Jer 33:3 Cry out to me and I will show you GREAT and MIGHTY things that you do not know.
Do everything on purpose for a purpose lest it be a thorn in someone's side and waste of everyone's time.
  #19
Old 01-08-2017, 10:57 PM
Awenta's Avatar
Awenta Awenta is online now
Can't knock the six.oh it's a great engine. If you don't pull heavy all the time then there is no reason to switch.
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
  #20
Old 01-08-2017, 11:06 PM
bmc1025 bmc1025 is offline
Agreed, not to mention if you blow it up your only out 2k.
98 C3500HD 6.5TD
03 Chevy 3500 CC Dually
06 GMC 3500 CC Dually
  #21
Old 01-09-2017, 07:56 AM
07keo02's Avatar
Won't argue with that, but I don't tow for a living, just my 7600 pound max loaded camper once in a while. If I dont need to move something, I drive my car. I would have to take my camper to work with me everyday to lose money, I virtually stole the 6.0.
I never used either of my duramax's to their potential, and put more money in parts (mostly because of desire, not need) than what I picked up this 6.0 for. That said, it's hard not to miss them.
It took me a long time not to worry too much about mileage compared to cost invested in the vehicle, parts etc. It is something that still bugs me, but now I remind myself, x amount invested in vehicle, x amount invested in parts, x amount invested in etc. That is finally what matters more to me than the instant gratification of mpg for a trip. Again, if I towed for a living, or even a whole lot of personal, the deciding factor may be very different.
  #22
Old 01-09-2017, 07:59 AM
Won't argue with that, but I don't tow for a living, just my 7600 pound max loaded camper and onve in a while. If I dont need to move something, I drive my car. I would have to take my camper to work with me everyday to lose money, I virtually stole the 6.0.
Sounds like you're good with the 6.0 then.
Sent from my SAMSUNG-SM-G870A using Tapatalk
  #23
Old 01-09-2017, 08:15 AM
07keo02's Avatar
Yes, for now. The most important point was in the 3rd paragraph, but I don't even know where I was going with that. More than anything, it's justification that I don't need another diesel until I get the home addition, pond, and shop done. Truth be told, there will likely be another duramax in the driveway one day. I may never need one, but sure do like them. I just don't have that same urge to spend much on the 6.0. I mean, it's not like I have been looking at 408 kits and twin turbos, but those urges pass.
  #24
Old 01-09-2017, 08:27 AM
c20elephant's Avatar
c20elephant c20elephant is offline
C20ELEPHANT
I had a 2007 NBS 2500HD, 6.0 with a 6 speed, what a pain in the ass to drive on the freeway slow and go. The engine did not come to life till around 4000rpm, at 2000rpm where the engine is detuned to pass emission it was a sloth. The Duramax has all I need it to do and then some below 4000rpm. Don't need the Duramax but it sure is a lot fun to drive with a few minor modifications...
Not aimed at you, guys complaining about fuel mileage driving a 7500lbs.+ truck with a 6.6 liter turbocharged engine is like pissing in the wind, what did you expect towing or not...
~Mike~
2006 2500HD EXTENDED CAB LONGBED
  #25
Old 01-09-2017, 08:38 AM
07keo02's Avatar
Must have been a Monday truck. Mine was a Friday one, or maybe hump day? 233,xxx miles CCSB 4x4 and doesn't have problems getting on the highway or n passing. I might tune it to remove some torque management, but again, i am being very cautious on cost vs reward at this time. I'm derailing the thread, I'm sorry. It all started with the truckers running people over who are doing 60 towing.
  #26
Old 01-19-2017, 06:49 PM
lawnboy01's Avatar
lawnboy01 lawnboy01 is offline
Yep, the LML's are bad. My 01 would get 15 mpg towing. Now my LML does the 8 to 8.5 mpg. Love the truck hate the mileage. About time to get a semi
2015 High Country
2002 GMC Limited Prostock Diesel "Backwoods Evolution "
  #27
Old 01-27-2017, 08:39 AM
Passin Thru Passin Thru is offline
FNG
My 06 gets 9.7 towing at 67 MPH from Va to Ok with 19,000 lb GVW. I don't worry about trucks swerving, almost 3/4 of the trucks in the US are geared at 63 MPH.
