  #1
Old 05-17-2017, 08:36 AM
colfmas97's Avatar
colfmas97 colfmas97 is offline
Gearhead
Default Break in oils
What type of oil should I use to break in my built engine?
__________________
White Lbz cc/lb, 111k, efi live dsp 5 by Craig at infinity diesel, 5 inch straight, mbrp DP, SDP y bridge, full egr delete, S&B intake, 66mm Danville drop-in, Airdog 165, PPE stage 4 trans, stock engine, stock injectors, stock cp3, 610 rwhp 1197 lbs, leveled, fuel maverick 20x10 -24, federal couragias 33x12.5. Cognito supports and tie rod sleeves.
Lbz died 3/31/17
over fueling stock pistons
  #2
Old 05-17-2017, 10:12 AM
TROJAN366's Avatar
TROJAN366 TROJAN366 is offline
Gold Rush
Default
I just used delo400 in both of mine. The first motor came apart and looked flawless
__________________
05 LLY CC/SB
Roderiques ATV Built Motor, HSP Twins, NLX88/Danville72R,
S&S 200s, S&S 10mm & LBZ, Tuned by Danville Performance
Suncoast Competition trans and Goerend Converter
1125hp/1628lbft 10.52@132
Thanks to
Chris @ Roderiques ATV in Westport MA
Mark Broviak @ Danville
Joe and Dave @ HSPdiesel
  #3
Old 05-17-2017, 10:42 AM
colfmas97's Avatar
Gearhead
Default
What kind of break in process did you do? I got wagler rods mahle pistons in mine idk if it really matters
White Lbz cc/lb, 111k, efi live dsp 5 by Craig at infinity diesel, 5 inch straight, mbrp DP, SDP y bridge, egr delete, S&B intake, 66mm Danville drop-in, Airdog 165, PPE stage 4 trans, stock engine, stock injectors, stock cp3, Ppe rail fittings, 610 rwhp 1197 lbs, leveled, fuel maverick 20x10 -24, federal couragias 33x12.5. Cognito supports and tie rod sleeves.
Lbz died 3/31/17
__________________
Lbz died 3/31/17
  #4
Old 05-17-2017, 10:49 AM
TROJAN366's Avatar
Gold Rush
Default
Lbz died 3/31/17
Just drive it. Don't beat it too hard and try and fluctuate throttle position. I changed my oil at 500 and 1000 miles.
__________________
05 LLY CC/SB
Thanks to
  #5
Old 05-17-2017, 10:56 AM
Awenta's Avatar
Awenta Awenta is offline
Default
Whatever oil you're going to use later and after 500 miles change the oil and giver her hell. Break it in how you're going to drive it. Then change again at 1000 more. Get it nice and hot to seat the rings
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #6
Old 05-17-2017, 11:10 AM
colfmas97's Avatar
Gearhead
Default
Right on. When you guys filled your engine first how did you guys push oil to the crankcase and through all ports? Just put a socket on an impact and spin the pump by the shaft till I get oil in the crankcase?
Lbz died 3/31/17
__________________
Lbz died 3/31/17
  #7
Old 05-17-2017, 04:21 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
Hit the starter with the FICM unplugged on my LB7
I changed the oil 5 times in 500 miles then every 1000 miles after.
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #8
Old 05-17-2017, 06:01 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Id use an oil with a higher % of zinc in it for initial break-in.
Can you figure out why your sig shows within your posts? Its something you have set in Tapatalk on your phone...
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #9
Old 05-17-2017, 06:02 PM
colfmas97's Avatar
Gearhead
Default
Shoot I didn't even think about that @hondarider552
Lbz died 3/31/17
__________________
Lbz died 3/31/17
  #10
Old 05-17-2017, 10:04 PM
SickLL7Crenshaw's Avatar
SickLL7Crenshaw SickLL7Crenshaw is offline
Billy The Kid
Default
I used delo 400, 600 miles on the motor went to the track and busted off a 11.1@123 that should have seated the rings
__________________
Blake
SOLD: 05 LLY CC/SB 140k 11.18@123.7 stock/480
01 LB7 EC/SB 308k 11.31@119.8 69sxe stock motor
Tuned by Unleashed Duramax Tuning
Crenshaw Ranch, LLC. 8LB7s, 7LLYs, 1LBZ , 2LMMs, 1L5P
Thanks to Evan@Limitless, yellowchevy, and Henry@COTNP
  #11
Old 05-18-2017, 03:21 AM
Duramax racer 8 Duramax racer 8 is offline
Gearhead
Default
Quote:
I used Mobil delvac in both your motors Steve
  #12
Old 05-18-2017, 05:48 AM
TROJAN366's Avatar
Gold Rush
Default
Quote:
Well then lol
__________________
05 LLY CC/SB
Thanks to
  #13
Old 05-18-2017, 08:25 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Lbz died 3/31/17
You don't have a FICM... You need something like thishttps://www.summitracing.com/parts/m...FRB0fgodfVEBvQ
Or build one out of heavy PVC pipe.
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #14
Old 05-18-2017, 08:30 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Here we go again
Default
Mobil then Rotella after 500 miles, didn't prime it, had it on a 2,000 mile road trip after the first oil change, motor hasn't been under 700rwhp in 5 years now has 55k
__________________
06 Chevy LBZOlympic White Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76@115.12 sold
08 BMW 528xi
Alpine White Brown Dakota Leather Premium/Cold/Smoker Pkg LED AEs MTec D1S 50% tint
2000 Buick Regal GS
Bright White Lowered Homemade CAI 4500K HIDs Supercharged Beater
  #15
Old 05-18-2017, 09:12 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Delo 400 reg dino oil in each engine on first start up. i crank till a mechanical gauge at the last main port shows pressure, the start it.
engine is then ran and checked for leaks till it reaches operating temp. If a new cam is put in, its broke in via the instructions that came with. after that, let it cool and then take it for a drive. let everything warm up and give it a couple WOT runs on a decent sized good tune. it doesnt bother me one bit cause i know the exact specs inside that motor and i want those damn rings to seat!
go 500 miles, change oil and cut open oil filter looking for sparkly things. if all is good, new oil and off ya go!
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
