Old 03-02-2016, 06:35 PM
patricksnow1 patricksnow1 is offline
Default Help
I need help with a relearn on a 95 6.5ltd
Sent from my SM-G920P using Tapatalk
Old 03-02-2016, 08:36 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Try the diesel page. We know nothing about these old things.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Old 03-02-2016, 09:18 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Moved here
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
Old 03-02-2016, 09:30 PM
Cougar281's Avatar
Cougar281 Cougar281 is offline
What relearn are you referring to? There's not much to relearn on a 95 6.5. All I could find was this:
Driveability problems may occur during the relearn stage. Depending on the vehicle and how it is equipped, the
following driveability problems may exist:
Rough or unstable idle.
Hesitation or stumble.
Rich or lean running.
Poor fuel mileage.
Harsh or poor transmission shift quality.
To accelerate relearn process after battery removal and installation, vehicle should be road tested in the
following manner:
Vehicle at normal operating temperature (cooling fan cycles).
Accelerate at normal throttle position (20-50%).
Cruise at light to medium throttle.
Decelerate to a stop, downshifting and using brakes normally.
General Motors does not provide a specific procedure for driveability relearn. If a vehicle battery was
disconnected for facilitating repairs or a Powertrain Control Module (PCM) was replaced, driving the vehicle
will enable the PCM to relearn driveability. Inform your customer that he/she may experience driveability
different from what they are accustomed to until the PCM completes it's relearn function.
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
Old 03-11-2016, 10:57 AM
I was running data on it at idle and the top dead center offset is 0.00. So the timming between the pcm and the ip so that i may adjust injection timming by shifting the ip
Old 04-02-2016, 09:02 PM
Ok so update... i bought a tech1 today and it this thing looks brand new it has every paper and booklet it comes with originally! The timing relearn is basically a number that is stored in the computer of the vehicle that the ip can be timed. Not sure if i can take a pic but in one of the booklets that came with the tool it explains how u use the tech1 to relearn the tdco. Also it can delete the from what i just read! Alot harder to understand than i thought it would be. I was confused about the tdco myself. I have a code 88 so i put my modus on it and ran data scan and my tdc degrees off is 0.00? After thinking about it i figured i should be firing before tdc so i did research on it and couldnt find anything that worked.KOKO was what i read but no luck and eventually i learned that a tech1 will do it so here i am. Tomm i will read some more and then do it! One dealer quoted me 350 and the other quoted me 200 as long as nothing broke! So they scared me away lol
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
