  #16
Old 05-18-2017, 09:44 AM
colfmas97's Avatar
colfmas97 colfmas97 is offline
Gearhead
@dmaxchris didnt prime it? Just filled it up with Mobil and started it?
White Lbz cc/lb, 111k, efi live dsp 5 by Craig at infinity diesel, 5 inch straight, mbrp DP, SDP y bridge, full egr delete, S&B intake, 66mm Danville drop-in, Airdog 165, PPE stage 4 trans, stock engine, stock injectors, stock cp3, 610 rwhp 1197 lbs, leveled, fuel maverick 20x10 -24, federal couragias 33x12.5. Cognito supports and tie rod sleeves.
Lbz died 3/31/17
over fueling stock pistons
  #17
Old 05-18-2017, 09:45 AM
colfmas97's Avatar
Gearhead
I'm pretty sure I can crank the melting pump manually to prime right?
Lbz died 3/31/17
  #18
Old 05-18-2017, 09:46 AM
colfmas97's Avatar
Gearhead
Melling*
Lbz died 3/31/17
  #19
Old 05-18-2017, 09:51 AM
Chevy1925's Avatar
not unless you have the front cover off, crank gear off and plug the left side oil galley.
James
best time to date: 12.39
Tailgate Crew Member #4
  #20
Old 05-18-2017, 09:55 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Here we go again
Correct. The motor will turn over for a solid 2-3 minutes before firing. Use a copious amount of assembly lube and it'll be fine.
06 Chevy LBZOlympic White Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76@115.12 sold
08 BMW 528xi
Alpine White Brown Dakota Leather Premium/Cold/Smoker Pkg LED AEs MTec D1S 50% tint
2000 Buick Regal GS
Bright White Lowered Homemade CAI 4500K HIDs Supercharged Beater
  #21
Old 05-18-2017, 10:12 AM
colfmas97's Avatar
Gearhead
How do I crank my starter without delivering fuel?
Lbz died 3/31/17
  #22
Old 05-18-2017, 10:32 AM
DMAXchris's Avatar
Here we go again
There wont be any fuel in the rails and it will take a few minutes to build enough pressure to fire the injectors.
08 BMW 528xi
2000 Buick Regal GS
  #23
Old 05-18-2017, 10:59 AM
colfmas97's Avatar
Gearhead
Awesome that's just as good as any other way..I'll do that and drive it for an hour with mobile take a sample an drop the oil and filter then go 500,1000,3000 taking samples each time. Then I'll run hydrotex 15w40.
Lbz died 3/31/17
  #24
Old 05-18-2017, 11:11 AM
Chevy1925's Avatar
leave the bail connectors off at the engine if you are worried about the engine firing. you can still crank and no injectors will fire
James
  #25
Old 05-18-2017, 12:47 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
I used delvac and a bottle of Lucas Break In oil. I made a adaptor that went to my turbo feed line (s400) and got a 2.5 gallon sprayer from home depot. Pumped in all the oil with that. Worked well.
2006 ccsb Lbz Tow rig
2006 rclb 6.6
  #26
Old 05-18-2017, 06:33 PM
Wikid's Avatar
Wikid Wikid is offline
Machinist and Know things
I run Shaffers oil and Custom Auto recommended Rev-X for the breakin. Little pricey but whats another 60$. Mine cranked a full cycle then forces you to stop. then fired about 2/3 into the start second cycle made 60PSI instantly. shes got about 600 miles on her and about to change the oil out and cut open the filter.
LBZ Block, LML Crank, Carrilo Rods, Fingers Pistons 16.5, AF 6480 Cam, ATI damper, Socal Flexplate, Stock Heads, Socal Springs. Exergy 12mm CP3, Exergy 100% injectors, SDP 3" Y Bridge, SDP 3794 68mm Billet, SDP S480 Billet. Mishimoto Intercooler. Tuned by ATP
  #27
Old 05-18-2017, 06:57 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
With the recent change to CK-4 from CJ-4 and the reduction in ZDDP from 1200/1260 to 800/830, I would look seriously at adding in a bottle of COMP CAMS break in additive or LUCAS break in additive. ZDDP is the zinc and phosphourus which are the 2 high impact wear inhibitors in your oil. The EPA specs recently changed as of January 1st, 2017(Shell changed Rotella dino oils as ov November/16, but they didn't change the label to reflect until January 1st, 2017). The verdict is still out, but FORD has shunned the new specs, and came out with there own saying the lowered ZINC content does not provide adequite wear protection for the valve train. FORD MOTORCRAFT diesel oils still have higher zinc contents in them, or if you can luck out and find some old stock of CJ-4 oil made before November of 2016 it will still have the higher zinc content. Otherwise run some zinc additive in it like the gasser guys do with flat tappet cams for break in just to be safe.
  #28
Old 05-19-2017, 03:54 AM
DMAXchris's Avatar
Here we go again
Now that yinz mentioned it I remember adding some ZDDP for the first oil cycle.
08 BMW 528xi
2000 Buick Regal GS
  #29
Old 05-19-2017, 09:37 AM
770JOHNNYW 770JOHNNYW is offline
Add 2 Or 3 quarts of Lucas stabilizer its full of zinc. Then your rings will seat in no time. Non synthetic Lucas stabilizer
