Old 04-17-2017, 08:47 PM
Yuptown_lly Yuptown_lly is offline
FNG
Default Lowered lly ride quality
I have a 2005 cc sb lly with 2" lowering shackles and the keys cranked to where the cvs sit flat. Truck is on 16"x10" mickey thompson classic 2s with 285/75/16 toyo a/t. Within the last year ive installed moog idler and pitman arm, moog tie rods, moog hub assemblies, just installed moog upper control arm and lower ball joints as well as blistein 5100 up front (the rancho rs5000 from last year were shot im sure the rear are to theyre junk). The ride is still stiff as hell, I also installed z71 style bump stops which im thinking about changing or removing maybe even. Id love some air bags for the rear and definetly plan to do blisteins in the rear soon. Ive been running 60psi front tires 55 rear and thinking about changing that to 50 all round? Whats yals input? Anybody else sitting at my height have a super stiff and bumpy ride?
2005 2500hd crew cab short bed lt
5" mbrp exhaust, 3" mbrp downpipe, s&b intake, Rudy's diesel turbo inlet, egr delete, profab economy flow intake tube, pcv reroute, fass titanium 150 lift pump, removed stock fuel filter assembly, lbz fuel pressure regulator, glowshift gauges, 2" lowering shackles, duramax tuner efi live[/I][/B]
Old 04-17-2017, 09:00 PM
c5fourj's Avatar
c5fourj c5fourj is offline
I run about 45 psi in my tires when just driving around. Ride is still very stiff, but it helps a bunch.
2006 GMC cc/sb
S&B intake, pcv reroute, sdp egr delete w/ ppe up pipes, AFE intercooler w/ AFE 3" hot side, 3" downpipe to 4" MBRP, fass 150, 72" trac bars
Overloads pulled, 2" drop shackles, torsion key bolts pulled, on 285/55/20
All Rare Parts front end
EFI live and built trans by Diesel Day Dreams
Old 04-17-2017, 09:16 PM
WVRigrat05's Avatar
Wound for sound
Mine had 40 when I checked today, I'm running 32 again in the rear and 35 in the front, it def helped. Dropping the front end, and new shocks next days off hopefully.
Reger
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB
Built trans, tunes, leveled, 35's, big bumper, lots of work.
Leaving it alone
Old 04-17-2017, 10:09 PM
whitetrash21's Avatar
whitetrash21 whitetrash21 is offline
put on da damn helmet day
May or may not make a difference, but the 5100s have always stiffened up the ride on any Duramax I've owned. Much better handling when loaded but with no weight on them, the ride is definitely stiffer than with factory shocks.
Tires I keep at 55 front and rear since i'm loaded 90% of the time.
Old 04-17-2017, 10:24 PM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
Aren't the 5100's for stock ride height? If your lower then that up front the shocks could be part of the problem.
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Tuned by Aaron Wiebe
Custom 80" Trac Bars by MBS Diesel
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to: Scott@ SDP, Aaron Wiebe @ All In Truck Performance, Lyle & Clay @ Bama Offroad, and Justin Goode @ MBS Diesel
Old 04-18-2017, 04:02 AM
SoCalMike's Avatar
SoCalMike SoCalMike is offline
Pictures of the front end setup would help. You could be sitting on the jounce bumper too much. Unloaded tire pressure should be around 50 psi front 40 psi rear. To really know what psi you can run, find the load inflation chart for you tires.
I have a 285/70/17 E tires and run 47 front 38 rear unloaded. With my tires I can go lower but things get squishy and mpg goes to crap.
Sent from my XT1635-01 using Tapatalk
2007 LBZ Crew Cab 4x4
Transmission built by inglewoodtransmission.com
atptrucks.com
Old 04-20-2017, 08:54 AM
SierraDuramax SierraDuramax is offline
FNG
im thinking about lowering my duramax this week. I want to go 3 inch shackles in the rear and then just take the bolts out of the torsion bars, just nervous about the ride quality cause right now my truck drivers pretty good right now!!
Old 04-20-2017, 09:46 AM
1TRIKHD's Avatar
Country boy Limo.
I have 3" drop shackles and bolts out and mine rides pretty damn good for a CCLB
ADII 165
  #9
Old 04-20-2017, 06:50 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Have you pulled the overload?
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #10
Old 04-20-2017, 08:38 PM
1TRIKHD's Avatar
Country boy Limo.
Overload is still in.
ADII 165
  #11
Old 04-21-2017, 12:04 AM
henery97's Avatar
henery97 henery97 is offline
FWIW i pulled the overload on my LBZ & it still rides like crap. Rancho 9000s & bags.
15 High Country LML
stock and staying that way
07 LBZ/alli cc/sb
s475/stock, race casts, exergy 60s
12.5@108mph
99 Trans Am LS1
Heads, cam, intake, built auto
  #12
Old 04-21-2017, 06:15 AM
FNG
My blistein 5100s are stock height shocks which should be about right because at factory setting my truck sat pretty low up front. My torsion bolts arent all the way out my cvs sit about flat, id like to go lower i just have to trim some more to clear the tires at a lower height. Im running about 50 psi front and 45 rear now it has helped the ride some but still very stiff, you hit a bump or pot hole brace yourself. Oh and railroad crossings can be a bit rough to.
  #13
Old 04-21-2017, 08:30 AM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
My lb7 rides like crap lowered.
2016 Denali
Limitless Diesel converter
HSP egr delete and IC piping
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless and Mark@Danville Performance
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
