  #1
Old 12-04-2017, 08:16 PM
gil8686 gil8686 is offline
FNG
Question How to remove engine from transmission with a seized engine
Hey guys i hope to get some help from you, so i bought this 06 3500 with a seized engine with a good engine as part of the deal but the engine thats on the truck is seized how can i remove the torque converter bolts? So i can get this engine out of the truck.
Any help would be apreciated.
  #2
Old 12-04-2017, 08:28 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
Pull the engine out with the converter. Be careful not to damage the input shaft.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #3
Old 12-05-2017, 03:19 AM
jlawles2 jlawles2 is offline
Default
Might be easier to take cab off, support engine then pull trans.
Have you tried pulling the glow plugs or injectors and spraying the cylinders with some type of penetrant? Let it soak for a while then try turning the crank both directions?
__________________
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #4
Old 12-05-2017, 07:43 AM
firefighter08 firefighter08 is offline
Jacob
Default
How is it seized? Ran it out of oil? If so drop the oil pan and unbolt the rods from the crank. Then you can turn it.
__________________
Jacob
08 LMM plated and routed to ground. Trans built and EFI tuned by Josh Harris @Top Notch Garage.
  #5
Old 12-05-2017, 09:08 AM
boominator's Avatar
boominator boominator is offline
Default
Quote:
you can't pull the pan without removing the trans.
  #6
Old 12-06-2017, 08:20 PM
FNG
Default
It seems the previews owner overheated the fing thing the was water on the pan and th oil is like gum lol. The turbo its stuck and it seems as the turbo blew was feeding the topend with oil so it might have gonne wild.
For that reason we are just going to take it apart completely. the top end gets removed on the truck hoping we can see more clearly why its stuck.
The other engine i got for it its going to be refreshed with bearings rings and cilinder sleves as they are a lot cheaper than new pistons ( im in chile south america) and this way we keep the engine std.
  #7
Old 12-07-2017, 05:42 PM
Default
You may be better off pulling the engine with the torque converter attached and buying a new torque converter.
__________________
  #8
Old 12-07-2017, 05:43 PM
prostreeter600's Avatar
prostreeter600 prostreeter600 is offline
Street rodder
Default
Remove the transmission first , then pull the motor out with torque convertor
__________________
06! GMC Sierra RC Full built motor, carillos, 14/1 Arias W/total seal rings, 9100 AF, SCalTit retainers,SCalsprings,ported heads, SCal pushrods, ARP 625 head studs, O-ringed block, keyed oil pump ,Billet Aluminum Lifters, Harland Sharp Aluminum roller rockers, studded rocker shafts, studded & girdled mains, socal balancer, socal flywheel, PPE Dual Fuelers with twin Fleece 10 mm CP3s , FASS Titanium 260 , 3" bridge, , TrRIPLES----2---S369SXEs .88ARs over a Hybrid GTX 4202R--72mm/87mm 1.0 AR ,coilovers at 4 corners, 36" ladder bars, BD cooler, Exergys w/185% MS 8 hole nozzles ,FF Dynamics fans, PPE mans & ups , MA mounts & TC Brace ,NOS, Full Billet Trans, Suncoast 10531-3D , 3.42 Gears, BT lockup box, 18x9 Raceline Assualts Hooiser Drag Radials 325/45/18s . TUNED by MARK@DANVILLE. Engine by Jason Walker San Marcus Tx Best 60'---1.44. Best 1/8---6.39@105.92. Best 1/4---9.978@136.39
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
