  #1
Old 01-29-2016, 07:27 AM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default Lml brake life
Has anyone had any weird issues with brake life being extremely short on their lml?
Just had a 2015 denali come in this morning with 30,000 miles on it and the front brakes into the metal. Right front caliper is pushed out so far it's started leaking.
Just thought it was odd considering the older trucks would run 100k with no issues on original pads.
__________________
17 GMC all terrain L5P, stock with dark windows
07 crew long classic- stolen
  #2
Old 01-29-2016, 08:06 AM
melms23's Avatar
melms23 melms23 is offline
Default
Ours seemed to warp the rotors right away. The wheel shakes if you get in the brakes real hard and the brakes are warm.
Our's is loaded down often but I too thought the brake life was awfully short.
__________________
2002 ccsb
2002 ecsb lbz zf6
Sold: '15 Denali
Sold: '04 rclb lly zf6
Sold: '07 rclb lmm
SDP s475/stock Twisted Tuned
12.1@111 1.79 60ft
  #3
Old 01-29-2016, 08:08 AM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
Default
My 11' has 76k on it with original brakes and still lots of pad life left. I do pull with it often also.
__________________
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #4
Old 01-29-2016, 08:11 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
Here in the salt, brake pad life isn't the problem. The caliper pins freeze in their bores and you normally cannot get em loose at all. End up replacing entire assembly, caliper, pins, and bracket. Obviously new rotor & pads too. Rear are worse too. Every single time. Super expensive too because there are no aftermarket calipers avail yet. All Ac delco. $$ Just when I thought they couldn't get worse than the older trucks...
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #5
Old 01-29-2016, 09:19 AM
clrussell's Avatar
pro-procrastinator
Default
Quote:
Where does a guy find a caliper? My gm sources say back order with no production date set..
__________________
  #6
Old 01-29-2016, 10:14 AM
ikeG's Avatar
Oughta Know Better
Default
Hmm, I have no problem. Just about 1 set per week.
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #7
Old 01-29-2016, 10:35 AM
clrussell's Avatar
pro-procrastinator
Default
Call your supplier if you would and check. I'd much rather put a gm one one..
__________________
  #8
Old 01-29-2016, 11:06 AM
ikeG's Avatar
Oughta Know Better
Default
Quote:
Srw?
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #9
Old 01-29-2016, 11:09 AM
clrussell's Avatar
pro-procrastinator
Default
Srw?
Yessir, right front caliper
__________________
  #10
Old 01-29-2016, 11:24 AM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
Quote:
Yup. 109k my truck does the same thing, original brakes as far as I know.
Its weird because the wheel shaking comes and goes. Maybe with how hot the brakes are? Sometimes I can get on the brakes hard at highway speed and its totally fine...other times I get on the brakes at highway speed and the steering wheel feels like full-on death-wobble, 2nd gen Dodge style...
Ben
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #11
Old 01-29-2016, 11:44 AM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
Ben
Yes^^ I believe the rotors get warm and warp causing the shaking, then after they cool down and straighten back up the shaking is gone.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #12
Old 01-29-2016, 12:17 PM
ikeG's Avatar
Oughta Know Better
Default
My local has one in stock, no problem getting more either. 107.68 my cost. OEM one's only come with caliper, no bracket or pins like aftermarket.
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #13
Old 01-29-2016, 12:18 PM
clrussell's Avatar
pro-procrastinator
Default
Cool.. I'll get with you after lunch
__________________
  #14
Old 01-29-2016, 12:41 PM
kiwilml's Avatar
kiwilml kiwilml is offline
Default
I've got 160k miles and haven't touched my brakes. Still feel perfect as far as I can tell.
__________________
2016 Chevy CCSB.. Currently stock except for EZ Lynk tuning by PPEI with a 5" flo-pro exhaust..
  #15
Old 01-29-2016, 02:06 PM
chrisuns's Avatar
chrisuns chrisuns is offline
Default
Have y'all check to see if you're suffering from uneven brake pad deposits (those experiencing high temp vibrations?
__________________
2007 LBZ - Few go fast and handling parts.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
