  #61
Old 12-02-2017, 04:53 PM
RPM Motorsports's Avatar
smokinum
Originally Posted by S Phinney View Post
No tune?
Looks identical to mine stock, I was 2wd non boosted.
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #62
Old 12-03-2017, 05:38 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is online now
<<<Future tuna killer
What does a stock LML run?
  #63
Old 12-03-2017, 06:01 PM
S Phinney's Avatar
S Phinney S Phinney is offline
Mid 15 second quarter is what Iím hearing.
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #64
Old 12-04-2017, 08:27 PM
gmduramax's Avatar
Shits broke
Well the truck threw some codes and went into reduced engine power. Threw map correlation and a fuel pressure code. Cleared them and immediately came back on.
10.98@124mph
Tailgate Crew Member #1
  #65
Old 12-05-2017, 12:47 PM
diesel-max's Avatar
diesel-max diesel-max is offline
Haisley Never heard of her
STEINBAUER is currently testing their L5P module.
1996 F-250 LLY Pullin truck....... 3.0 Smoothbore "Dirty Secret"
Huge thanks to: Wagler Competition Products, and Mark B. @Danville performance!
'15.5 Denali HD LML.
Exhaust,Tuned, Ratio Tec, twin Kennedy lift pumps.
'05 Twin turbo LLY.
LBZ Block, LBZ S&S 150% overs, LBZ heads, Callies CompStar, Wagler Street rods, Wagler Comp Stg. 2 Camshaft, Hamilton springs, Smith bro. Pushrods, ARP head/main/rockershafts, Dual CP3's, Michiana Diesel built Allison/ 1074-3D Suncoast converter, twins/DP VGT and StainlessDiesel S485/96/1.10 5Blade
  #66
Old 12-06-2017, 04:36 PM
gmduramax's Avatar
Shits broke
Left the module plugged in and put it on the stock setting. Truck doesn’t throw codes any more. Going to try running it on level 1
10.98@124mph
  #67
Old 12-06-2017, 05:12 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Your cold air intake might be causing that instead of the module.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #68
Old 12-06-2017, 05:56 PM
gmduramax's Avatar
Shits broke
Rail pressure and map? But it was on the truck a week before the intake and was fine. Might throw the stock intake back on.
10.98@124mph
  #69
Old 12-07-2017, 05:20 AM
S Phinney's Avatar
The codes would come from the ecm seeing something outside of its limit ranges.
  #70
Old 12-07-2017, 03:58 PM
gmduramax's Avatar
Shits broke
But if itís fooling the rail and map. The truck shouldnít know itís there, unless the vein position and regulator are out of range.
10.98@124mph
  #71
Old 12-07-2017, 04:02 PM
S Phinney's Avatar
It may can give the hard parts a different number to work from but I doubt that it will changes the high and low range for differences before it sets a code. The veins are electronic with a motor now instead of hydraulic on previous versions.
  #72
Old 12-07-2017, 04:16 PM
gmduramax's Avatar
Shits broke
I wonder if getting the injectors done 15% over would freak the truck out.
10.98@124mph
  #73
Old 12-07-2017, 06:29 PM
Chevy1925's Avatar
I doubt it but it will learn around them. The moment it sees more power from an outside source, it will probably pull power back or throw a code. If the egt sensors are like the lml, the ecm can monitor that and pull fuel back just based on those temps. Itís a good way to make a tow tune keep a certain temp while you run flat out in a lml though lol
James
best time to date: 12.39
Tailgate Crew Member #4
  #74
Old 12-07-2017, 06:32 PM
gmduramax's Avatar
Shits broke
Iím running it on level 1 and it seems fine so far. But it only picked up 2-3mph on level one so not so much of a difference. I do plan on logging it within the week to see if the ECM is pulling power. Sounds like I might need to fool the egt sensors.
10.98@124mph
  #75
Old 12-07-2017, 07:26 PM
Chevy1925's Avatar
I was meaning towards doing the 15% over injectors. I would think the afe is fooling the correct sensors but who knows how fast they ďrushed it outĒ and just sorta made it work
James
