Old 01-10-2018, 10:55 PM
mishlenn1986 mishlenn1986 is offline
FNG
Default duramax swap
Good evening guys
* please tell me if there is such an opportunity who can help me to make a wiring for connecting LML
I have the engine and the transmission ALLISON
If I understand correctly, I need to do this,
* all wiring including wiring for the transmission, unlocking the immobilizer (pinout of the control unit)
* gas pedal
* I would like everything to work without USR and DFP
I apologize in advance for my not very good grammar
Old 01-10-2018, 11:33 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
If you are outside the US (sounds like you might be), than you can delete emissions with EFILive, I am told.
I don't think there is a standalone / theft delete tune for the LML yet, so you'll need a bunch of body modules to make it run.
Sadly, I haven't heard much about swapping with LMLs, but I know it has been done. Do you have access to the full donor vehicle?
Old 01-11-2018, 07:47 AM
rfletes79's Avatar
rfletes79 rfletes79 is offline
The only company I know of that can do a LML standalone is dmaxswap.com. Speak to Adam, he will get you setup. I’ve seen their standalone LML running on a stand and in a swapped truck. There is a bunch involved making this happen.
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, S475/factory IHI, 65% inj, 10 mil pump, SoCal AF cam, Valve springs, Push Rods, LBZ rods..... 10 sec cruzer :-)
2002 2500HD LLY swap 5-24-15.
Old 01-11-2018, 10:12 PM
FNG
good evening
I'm in California and with a friend we want to install this motor in his car, but on the Internet I have not found a detailed description of such projects. I'll try to contact these guys dmaxswap
but really here on the forum no one did anything like this
Old 01-11-2018, 10:32 PM
RPM Motorsports's Avatar
smokinum
Originally Posted by mishlenn1986 View Post
good evening
Going to be a fun project with many new curse words learned.. do you already have the LML? If not, itís much less work to use the LMM and older platform.
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
Old 01-12-2018, 03:44 PM
FNG
Yes, I already realized that this is not enough simply)) but the difficulties are not particularly frightening to find the main practice and people who have already done so.
The only thing I found is a Hummer hi https://www.youtube.com/watch?v=mbiBmPMbXAk
or it's not that motor
Old 01-12-2018, 03:52 PM
FNG
Yes i have LML:смущенный:
Old 01-12-2018, 03:57 PM
FNG
Hi
No I do not have access to the vehicle from which this engine was removed (I understand that this would facilitate the task) A motor was purchased separately and a separate transmission electronic control unit as well
what other blocks do I need
  #9
Old 01-12-2018, 07:59 PM
FNG
I learned the details
LGH motor
GMC Savanna 2013
Transmission 4l80e
As I understand this motor is deformed and therefore goes with this transmission, I would be glad to receive the same
  #10
Old 01-12-2018, 11:43 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
LGH motor
GMC Savanna 2013
Transmission 4l80e
Should be a 6l90e behind the lgh. I believe 08 was the last year for a 4l85e.
  #11
Old 01-13-2018, 12:30 AM
heathgu heathgu is offline
Default LML Duramax swap.
LML swaps are a lot of work like everyone has said. We had the complete wiring harness when we start our conversions.
PPE are the only ones i know of that have a VATs module on the market. Check them out might help.
But you should listen to the above people. We spend over 2 weeks extra doing the LML (electrical/modules/programming) then we normally do for the 01-10 range of duramax engines.
What vehicle are you putting the LML into? We have few LML/Allisons into some vehicles here in Australia and we advise them of the extra $$$ involved and the extra time is not worth the future pain.. Plus we have not got the cruise control work as yet. If anyone here has got a lead on the cruise send me a pm (sorry for off topic)
Cheers Heath
Nissan GU patrol ute,
LBZ SOCAL Built Stroker Motor, MAHLE, CARRILLOS, STAGE 2 Heads, CAM, 14mm head studs, 100% sticks, etc.
6 speed/Allison
MIKE.L. Converter, COOLER, OILER, and other goodies.
  #12
Old 01-13-2018, 12:45 AM
FNG
Cheers Heath
Hummer h1
  #13
Old 01-13-2018, 09:37 AM
rfletes79's Avatar
Cheers Heath
Dmaxswap.com has the VATS module as well. I've seen their LML standalone setup and speak to their harness guy weekly. I don't know if they got the cruise control working but would be worth talking to them since they are doing the LML standalone successfully.
j
  #14
Old 01-13-2018, 07:30 PM
Cheers rfletes79, ill give them a call.
6 speed/Allison
