Go Back   Duramax Diesels Forum > Duramax/Diesel Technical > Duramax Engine Building
View Poll Results: Reusable Filter or Standard Canister
Reusable Filter 1 8.33%
Standard Canister 11 91.67%
Voters: 12. You may not vote on this poll
Reply
Thread Tools Display Modes
  #1
Old 02-06-2018, 12:46 PM
Bdsankey Bdsankey is offline
FNG
Default Engine Oil Filter: Reusable (HUBB) or Standard Canister?
I have been seeing the Cummins guys taking a liking to the reusable stainless steel type filters (HUBB for example) for engine oil.
I am in the process of building my engine and am wondering if the reusable engine oil filters are worth their price or worth it in terms of protection?
I do not doubt the flow rate is higher than a canister filter.
I personally run AmsOil EAO52 filters on my truck now. Unless I can find proof that a reusable/cleanable filter is a truly better option then I will stick with that route and Cen-Pe-Co 20w50.
__________________
2005 LLY EC/SB, Leather, Sunroof
-Built motor, Billet S476/87, Dual 10mm pumps, Exergy 60% overs, Goerend "J" converter, Built trans, AD2 165, Beans sump, E-Locker, TrueTrac, Yukon 4340 shafts, Traction bars, DHD center link brace, DHD lower cross member support
1999 Dodge 2500, Cummins, EC/SB
-Tow Rig, Stock
  #2
Old 02-06-2018, 12:56 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
I donít see the point in a Duramax. They are so easy on oil and have such low wear numbers. Anything more then stock filtering isnt really needed. I have a bypass oil filter and wouldnít of bought it if I could do it all over again. I have single digit wear numbers running Dino oil up to 16k. I could keep running the oil if I wanted, but the additives are starting to wear out at that point.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #3
Old 02-06-2018, 01:50 PM
FNG
Default
Quote:
I am not so much concerned with the filtering as they all provide great filtering. My thoughts were more so on pure oil flow #s for higher rpm engines used in pulling.
__________________
-Tow Rig, Stock
  #4
Old 02-06-2018, 02:59 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
No duramax is easy on oil. We run the hottest overall engine oil temps...
I don't care for the reusable stuff personally.
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 10.12 @140 815rwhp
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #5
Old 02-06-2018, 05:09 PM
Dozerboy's Avatar
Default
Temperature isn't everything and there are thousands UOAs out there that would disagree with you. Built engines and comp only vehicals changes things.
__________________
  #6
Old 02-06-2018, 05:32 PM
Getting faster
Default
Smallest oil cooler between the 3, less oil capacity compared to the rest etc.
__________________
"OldManTan"
  #7
Old 02-06-2018, 05:36 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Just like a large pan on an Allison, more capacity wonít help temps. You know this... oil cooler isnít the issue when coolant temps stay 20-30* within oil temp. The cooling stack becomes the issue
__________________
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #8
Old 02-06-2018, 08:10 PM
Getting faster
Default
Point made.
Why is the dmax crowd the ones only worried about oil temps then?
I've never seen a Cummins with an added engine oil cooler, and a 6.0 liter needs one just to stay alive.in stock form
__________________
"OldManTan"
  #9
Old 02-06-2018, 10:05 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
Point made.
The 6.0 crowd is concerned with oil temperature for sure. So not just Duramaxes.
And there are the odd nuts out there (me, at least) that tow with 660 HP and don't even monitor oil temp. So I don't think the engine has any particular issue with oil temps.
Not that any type of filter would change that. Honestly, the filter is only there to catch the really big metal parts when something goes really badly. Motorcycles use washable filters just fine. But I'm not sure it is worth the hassle when you can get an ACDelco PF2232 for $7 all day long.
Sent from my Cat S60 using Tapatalk
__________________
  #10
Old 02-07-2018, 03:33 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Default
The hubb cost to much money to get/ maintain
You have to drive your filter to a napa or someone with a sonic cleaner and they take about an hour-2 to clean depending on how dirty it is... I then asked how are they even selling any and he told me mostly ford guys and Jeep guys are buying them lol
To answer your question though on flow a dirty filter no matter what it is will only flow a certain % so if your worried of flow just change it every 5k or 500
A built motor shouldn’t be putting out any more material than a stock on (once broke in)
So your concern should be more on oil life
__________________
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #11
Old 02-07-2018, 07:26 AM
Chevy1925's Avatar
Default
Point made.
i dont think you have looked around enough. its not like there are very many guys doing what the few of us do with 500-600 actual rwhp and towing heavy loads. for one, the 68 wont hold up to shit towing those loads even built. 2, ive seen 2 dodge trucks come through fred/marks shop with oil coolers on them for towing. 3, i have two buddies with 6.7 fords, we were all monitoring oil temps one trip to moab. The 6.7 was running the same temp as my dads 15.5 LML while they all had about 8k on the back. this was 230* oil temps/210* coolant pulling grades out of phx and flagstaff in 85-90* weather. the L5P runs even cooler on oil temps now, josh has the data to go with it. only issue with the fords were we couldnt pass a fuel station without having to stop. my god did they get shitty mpg.
__________________
James
  #12
Old 02-08-2018, 07:51 AM
FNG
Default
A built motor shouldnít be putting out any more material than a stock on (once broke in)
It is going to be getting 2500mi/10 pull change intervals with Cen-Pe-Co 20W50 Racing oil
__________________
-Tow Rig, Stock
  #13
Old 02-08-2018, 07:54 AM
FNG
Default
Quote:
How are you monitoring oil temp on the duramax, which port are you using?
__________________
-Tow Rig, Stock
  #14
Old 02-08-2018, 07:58 AM
Chevy1925's Avatar
Default
Quote:
what are your main/rod bearing clearances. there is some interesting info on running a thicker oil if the clearances were not designed for it. oil will get hotter than thinner oil and eventually pressure drops to the same as the thinner oil but at a hotter temp
autometer oil temp gauge that is threaded into the top port on the oil cooler housing. this is "pre cooler" so you see close to the hottest temp the oil will be.
__________________
James
  #15
Old 02-08-2018, 08:04 AM
FNG
Default
1) I have not even dropped the block off at the machine shop. I don't know what the clearance should be but they said they could make sure the clearances are right. They are doing the machining and measuring it for bearings.
2) Good to know, I will have to add that to my sensor array on the CTS 2.
__________________
-Tow Rig, Stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
