  #1
Old 11-06-2017, 10:57 AM
jpowel29's Avatar
jpowel29 jpowel29 is offline
Default LLY tear down
Bought a complete running motor and selling off what is no longer needed. Truck had 130k miles on it - not sure of the hours on it. No spun bearings or cracked pistons. Below is a listing of what is available for sale:
LLY turbo w/vane sensor - $400
LLY crankshaft - $300
LLY rods/pistons - $250
New GM standard bore piston ring set - PN 97250331 (GM 97386951) - $285
Factory balancer, oil cooler, water pump/housing also available
Prices are obo and do not include shipping or PP fees.
__________________
Trying some new things...
  #2
Old 11-08-2017, 04:02 PM
jpowel29's Avatar
Default
Sale pending on the pistons.
__________________
  #3
Old 11-09-2017, 09:00 AM
jpowel29's Avatar
Default
LLY rods - $150
Factory balancer
Should have a core stock LBZ shortblock (cracked piston), CP3, rails and hardlines - in a few weeks for tear down. Will post up as soon as parts are disassembled, cleaned, and inspected.
__________________
  #4
Old 11-13-2017, 03:40 PM
jpowel29's Avatar
Default
Also available:
LBZ Upper/Lower Valve covers - $100 each side
LBZ Y-Bridge - $40
LBZ Rear Cover - $100
Coolant Crossover Bridge and Thermostat HSG - $45
LBZ Crank - $300
LBZ Rods - $175
LBZ Flexplate - $40
LBZ Balancer - $40
LBZ Fuel Rails, Rail Pressure Sensor, and Hardlines - $375
LBZ CP3 w/regulator - $300
__________________
  #5
Old 11-17-2017, 12:40 PM
jpowel29's Avatar
Default
LLY rods - $150
LLY Cam - $125
LLY Balancer - $40
LLY Std Bore Block - $600
LBZ Y-Bridge - $40
LBZ Crank - $300
LBZ Rods - $150
LBZ Cam - $125
LBZ Flexplate - $40
LBZ Balancer - $40
LBZ Lower Oil Pan - $50
LBZ Std Bore Block - $600
__________________
  #6
Old 11-17-2017, 01:03 PM
weazel's Avatar
weazel weazel is offline
Default
Where are you located?
__________________
88 Chevy 1/2 ton- LB7 conversion project
93 Chevy K3500- CR Cummins conversion project
05 Chevy LLY 5" ex, EFI DSP5
  #7
Old 11-17-2017, 01:49 PM
jpowel29's Avatar
Default
Bentonville, Arkansas 72712
__________________
  #8
Old 12-02-2017, 06:06 AM
jpowel29's Avatar
Default
LLY rods - $150
LLY Balancer - $40
LBZ Y-Bridge - $40
LBZ Rods - $150
LBZ Cam - $125
LBZ Flexplate - $40
LBZ Balancer - $40
__________________
  #9
Old 12-02-2017, 12:23 PM
1FastBrick 1FastBrick is offline
Default
Pistons sold?
  #10
Old 12-02-2017, 01:45 PM
jpowel29's Avatar
Default
yes all the stock pistons have been sold.
__________________
  #11
Old 12-03-2017, 01:03 PM
jpowel29's Avatar
Default
Bump
__________________
  #12
Old 12-03-2017, 02:02 PM
bmc1025 bmc1025 is offline
Default
Will the piston rings fit lb7?
__________________
98 C3500HD 6.5TD
03 Chevy 3500 CC Dually
06 GMC 3500 CC Dually
  #13
Old 12-03-2017, 06:05 PM
jpowel29's Avatar
Default
Quote:
Yes rings will work
__________________
  #14
Old 12-28-2017, 09:42 AM
jpowel29's Avatar
Default
bump
__________________
  #15
Old 12-28-2017, 09:26 PM
weazel's Avatar
Default
Pm sent
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
