  #5716
Old 02-12-2018, 08:31 AM
minerigger's Avatar
minerigger minerigger is offline
Was it your 1058 chris
Sent from my SM-G930V using Tapatalk
Brock
06 LBZ ECLB
Gauges, Danville Tunes, 5" Dumped, Trans by Evan, DP Stg2r, Sleeved/Braced and some other odds and ends crap that we all have
  #5717
Old 02-12-2018, 07:44 PM
minerigger's Avatar
Started it for first time in 6 weeks. Hit high idle...man I love that sound. Then went to store with the boys. Then went to the interstate. 0-110 with alot of on ramp left. This thing is such much more responsive than this 15 work truck is. I'd have to see an equally done up lml or l5p to even think about switching
Brock
06 LBZ ECLB
  #5718
Old 02-12-2018, 08:58 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
Deleted max effort with solenoid mod they are quite nasty...
  #5719
Old 02-12-2018, 10:03 PM
AZlml's Avatar
AZlml AZlml is offline
Will the trans actually hold with the solenoid mod on a max effort tune? Or is this like a "once in a blue moon run it on a max effort tune and pray for the best" type of scenario?
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
  #5720
Old 02-12-2018, 11:31 PM
rcr1978's Avatar
rcr1978 rcr1978 is offline
I think mines hurt and I have the solenoid mod, mines not even max effort. It's max on the factory fuel system with no lift pump. 2nd-4th lots of rpm with not a whole lot of go anymore and that's in tow haul with the converter locked, at least I think I need to get some logs to double check maybe the converters hurt to .
Without tow haul it blasts through the converter high revy no go
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #5721
Old 02-13-2018, 02:59 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Here we go again
That blows... Literally... It come apart and clog everything up?
No. I caught it early. It started acting strange on high idle a few days ago. Then I noticed it wanting to load up after it’s warm when you’re on the brakes. It still drives and locks up fine.
Yep. 55k miles on it. I think all the highidle this year didn’t help.
06 Chevy LBZOlympic White • Built Motor/Trans • Bullseye s375 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance 11.76@115.12
08 BMW 528xi
Alpine White • Brown Dakota Leather • Premium/Cold/Smoker Pkg • LED AEs • MTec D1S • 50% tint
2000 Buick Regal GS
Bright White • Lowered • Homemade CAI • 4500K HIDs • Supercharged • Beater
  #5722
Old 02-13-2018, 05:44 AM
My 15 did fine, no issues in the 58k I had it. It was deleted at 5k I think, I set it on max effort and took it off it a few times to pull boats to Florida. I had a lift pump, full deletes and solenoid mod, truck was solid and very strong, I haven't deleted my 16 yet only bc I like how quiet it is. The deleted LML's seem extra loud to me compared to the LMM or lbz...
  #5723
Old 02-13-2018, 06:31 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
The solenoid mod is a short term bandaid.
2003 GMC CCSB LLY
Built by me, tuned by me.
  #5724
Old 02-13-2018, 07:18 AM
Chevy1925's Avatar
the c3's will get full main line pressure now instead of control pressure like the older years and the solenoid helps give you all that pressure but at the end of the day, you still are on 4 clutches in there and these clutches are not meant for abuse. the LML also wont limp as easy as the older trucks as it will instead start pulling power back if it senses slight slip. the trans and ecm will work well together to keep you from killing it quickly but this means you leave alot of power left on the table with the stock trans.
James
best time to date: 12.39
Tailgate Crew Member #4
  #5725
Old 02-16-2018, 05:26 AM
Nathan.'s Avatar
Nathan. Nathan. is online now
Removed my fender flares. There was all kinds of stuff that fell out of them upon removal!
2005 Sierra CC LLY
2006 Jetta TDI BRM
2014 Harley Davidson Street Glide Special
  #5726
Old 02-16-2018, 07:06 PM
countrycorey's Avatar
countrycorey countrycorey is offline
Trust Me I'm an Engineer
Changed the oil and rain-x'ed the windshield
Sent from my SAMSUNG-SM-G930A using Tapatalk
2007 Chevy Classic CCSB LS 4x4 w/ LBZ & 6 Spd Ally
Graystone Metallic
295/70/17 Nitto Trail Grapplers on Chrome H2s w/ LMM Centers
Custom CamLocker Toolbox
Grizzly Nerf Bars
Pioneer 4100 Head Unit
JL Audio Components
Sportsman Max4 Seat Covers
MPI GT4202/Stock
HSP Coolant Tank
Tinted Windows
MBRP 5"
PCV Rerouted
EGR Blocker & Fingerstick
Nicktane 1 Micron Filter & Adapter
Banks Hot Side Intercooler Tube
ProFab Y-Bridge and 3" Cold Side Boost Tube
AutoMeter Phantom II Boost and EGT on A-Pillar
Hammerhead Armor Replacement Front Bumper
EFILive from IdahoRob
Fleece All On Mod
  #5727
Old 02-21-2018, 02:52 PM
M.A.M.'s Avatar
M.A.M. M.A.M. is online now
Getting close to dropping it back in... still got the harness to run, acc brackets, and drill/tap the upper oil pan for the oil drain...
  #5728
Old 02-21-2018, 08:44 PM
Gotboost06 Gotboost06 is offline
FNG
Lost steering again..
  #5729
Old 02-24-2018, 11:51 AM
SoCalMike's Avatar
SoCalMike SoCalMike is online now
Trucks getting new tires (nitto ridge graplers) and black chrome lugnuts installed.
  #5730
Old 02-24-2018, 01:03 PM
TheBac's Avatar
TheBac TheBac is offline
Oh my god.....
I actually DROVE my truck today. First time in well over a month?
I think it was more shocked than I was.
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
From mufflerguy on yb,
HTML code is On
