  #16
Old 02-19-2017, 03:11 PM
TheBac's Avatar
TheBac TheBac is offline
Thanks Rick.
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- in progress
From mufflerguy on yb,
  #17
Old 02-19-2017, 03:47 PM
oscyjack's Avatar
oscyjack oscyjack is offline
Sub. Great thread and look forward to more
'08 LMM CCSB
Limitless trans
EFIlive - PPEI
Built front end
All the bolt ons
33x11.5 on 17x9 -12
HB/brake upgrades
  #18
Old 02-19-2017, 10:34 PM
WisconsinHick1's Avatar
WisconsinHick1 WisconsinHick1 is offline
Hey Rick do you make remote mount up pipe setups? I have ATS manifolds and am looking to do a remote mount system.
Green Bean Out
The Rag In
  #19
Old 02-20-2017, 08:07 AM
RickDLance's Avatar
RickDLance RickDLance is offline
I have but they are usually on a one off basis. See Joshh's thread for one of the latest.
www.ProFabPerformance.com
If it doesn't say Made in USA then look the other way!!
We also handle S & B filters, Air Dog lift pumps, American Eagle wheels, and Kraftwerks Superchargers.
On my 20th Duramax & still Loving them!
  #20
Old 02-20-2017, 08:36 AM
Chevy1925's Avatar
Rick, just out of curiosity, ive seen on facebook how "Steed Speed" had shown a video of their new duramax exhaust manifolds. basically blowing air into one end with cardboard flaps over each open end of the manifold to show how air is directed. is there really any merit to that to "show improvement" or is it just bs to make you think you are getting an improvement? do you guys do any testing like that if it does have merit to it?
here is a link to the fb video (if you have a fb account)
https://www.facebook.com/leen.steed/...type=2&theater
Also, on a separate note. On the towflow up pipes, being that stock manifolds arent perfect, whats the likely hood of the uppipes lining up with the exhaust manifold outlet or are they relatively consistant in placement across the board so its not much of an issue?
James
best time to date: 12.39
Tailgate Crew Member #4
  #21
Old 02-20-2017, 10:11 AM
RickDLance's Avatar
Neat little video, but IMHO doesn't prove much. What you would ideally like to see is a small vacuum on the other ports to help scavenge the cylinders.
Inherently a couple of brand manifolds would fail both those tests and if I get around to making a thread on the manifolds I will try to explain why.
As far as the up pipes, we always make our manifold outlets slightly smaller diameter and the up pipes slightly larger. We have checked about 20 - 30 manifolds and they seem to be pretty consistent. That being said checking them with a gasket would be the best idea.
  #22
Old 02-20-2017, 10:23 AM
Chevy1925's Avatar
10-4, thank you for the info
James
  #23
Old 04-09-2017, 10:23 AM
830king's Avatar
830king 830king is offline
Sent you a pm Rick.
Sent from my SM-G930V using Tapatalk
2005 2500hd ccsb 4x4 automatic, atp trans safe tuning, cts insight with egt probe, arp head studs, welded water pump, lml drivers side exhaust manifold, manga flow down pipe, silver line 5" exhaust, s&b cai, s&b turbo mouthpiece, fass titanium 150, beans sump, profab egr delete, MA pump rub plate, alligator trans lines, Kryptonite ss centerlink/tie rods, Kryptonite lower ball joints, Kryptonite sway bar end links, rare parts idler and pitman arms, dhd steering brace, 285/75r16 duratracs on stock py0's, b&w turnover gooseneck rancho 9000 shocks
  #24
Old 04-09-2017, 11:14 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
I just saw this. I don't think it proves anything. Couldn't you do the same test with a stock manifold and get the same results?
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #25
Old 04-09-2017, 12:39 PM
830king's Avatar
Just got a set of these tow flows ordered with the black ceramic coating. Im gonna swap them when i swap trans....should be alot easier to do then.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
