  #1
Old 02-28-2018, 05:17 PM
t.watts1340's Avatar
t.watts1340 t.watts1340 is offline
FNG
Default 2005 2500 puzzle
Posted a little info on this in my introduction post, but if ya missed it here it is. Iím putting together a 2005 gmc 2500 dmax. Got two of these trucks that were already taken apart when I picked them up so Iíve got no clue how they go back together. Just gonna try and figure it out, how hard could it be? Hahah
Luckily the service truck I get to drive home everyday is a 2005 Chevy 3500 dmax. Hopefully I can reference this some putting the gmc back together?
Donít know anything about these trucks really so bare with me, Iíll try and search the little things I run into.
Hereís where Iím at now after a week...
so the mechanic that was swapping the lly for an lbz got locked up in the process. So far Iíve pulled the lbz, trans, and transfer case all at once (pretty nerve racking without an extra hand).
So I guess the next step is putting the original lly back into the truck? Is there anything Iíll want to do/replace before I stick it back in?
Any general words of advice are appreciated as well!
Hereís pics of what Iíve got going on
Truck when I first pushed it in the shop
Pulling out
Pretty sketchy, but it all went smooth
Taking up too much room in the shop....
Iíve got more pics of the engine/trans. Not sure if anyone wants to look at all this stuff though 🤷🏻*♂️
Thanks guys!
  #2
Old 03-05-2018, 04:42 PM
Kriesel Kriesel is offline
FNG
Default
I pulled my LBZ drivetrain in once piece as well. The cherry picker is capable of the weight. But it sure is scary! I bought new chains and everything just to make sure.
Why are you putting the lly back in? why not figure out the lbz?
With them out, in my case, I had to replace the oil pan gaskets. So, I would look for leaks, and do things like that with the engine out...
  #3
Old 03-05-2018, 06:11 PM
FNG
Default
The lbz is actually going in a 89 v3500! Gotta get this truck put back together so I can have something to drive once that project gets rolling!
Definitely gonna have to replace those along with the pan, got a little dented up during the whole shipping procedure. Gonna go ahead and replace the fuel filter, the seal at the end of the transfer case, gotta replace the transmission fluid dipstick tube too. It looks like a press in fit?
Any recommendations on a good quality fuel filter?
  #4
Old 03-05-2018, 06:25 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
Get a lift pump and do your filters in the frame and delete the factory housing.
__________________
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #5
Old 03-05-2018, 06:36 PM
FNG
Default
Iíll have to look into that, changing the filter while itís jammed in there looks like a pain.
  #6
Old 03-05-2018, 07:05 PM
zakkb787's Avatar
<thatís not me...
Default
Factory heads are known to leak and cause issues. Bypass the FICM and delete the factory filter head. Lift pump like an air dog or fass will give you your priming and filtering.
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #7
Old 03-06-2018, 07:14 AM
FNG
Default
Did some searching around, is it okay to bypass the FICM on an lly?
  #8
Old 03-06-2018, 07:23 AM
TheBac's Avatar
TheBac TheBac is offline
Default
I think what he means is to not run the fuel thru the FICM. I personally would not do that on a DD truck.
I would use another style filter setup on the swap truck, but not on your DD.
I would use the factory filter head along with a Kennedy lift pump on the DD.
If your filter head is leaking, you can buy a new one for a decent price. That would be the easiest way to go about it.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #9
Old 03-06-2018, 01:12 PM
FNG
Default
Quote:
Well that's a good reason... haha
I had to replace my dipstick also, bought it from the dealer... It is just pushed in there. I broke the original one when trying to remove it, and so had to get a new one. My oil pans were leaking so I re-did the gaskets with rtv. With my engine out, I also tapped the exhaust temp sensor, removed my egr, and changed the downpipe to a better model.
I just use the stock filter head on my LBZ, and bout a Wix filter for it.
__________________
Kriesel's Diesel Suburban
  #10
Old 04-06-2018, 12:41 PM
FNG
Default
Made a little bit of progress on the truck so far, not much but enough to keep me motivated haha.
Should of took more before pics, but Iíve got the interior of the truck put back together. Luckily he hadnít started tearing into the wiring too much from the swap he was trying.
Put on some new motor mounts and found some frame brackets for the mounts from a local pull apart. Going off of this website for torque specs, hopefully theyíre credible
http://longhornfabshop.com/templates...ue%20Specs.pdf
Got a transmission mount on the way. Trying to get this thing ready to put back into the frame.
Iím going to replace the output shaft seal before I put it back in.
My biggest question to any of you guys out there, is there anything I want to make sure I do before I put it in? Wiring, brackets, etc? Iím new at this so anything helps haha
Thanks
  #11
Old 04-06-2018, 08:51 PM
FNG
Default
Jumped the gun, put in the new seal.
Couple beers with the boys and it went in smooth, motor trans and transfer case
I guess bolt up all the brackets next? Then maybe figure out all the plumbing shit in
  #12
Old 04-06-2018, 10:40 PM
frankenstien's Avatar
frankenstien frankenstien is offline
Default
Looks like its coming along, any progress is better than no progress.
Merchant auto has an app that has a bunch of torque specs, not sure that it has all of them, but it can be handy, has a ton of other info as well
__________________
2005 ECSB LLY
Danville Tuned
5'' exhuast
Fass 150
Built Trans w/SC1058
Bumpers built by me
  #13
Old 04-07-2018, 12:05 PM
FNG
Default
Awesome, thanks for the info. Iíll check that out!
  #14
Old 04-08-2018, 11:35 AM
FNG
Default
Mounted the cross member and transmission mount. Bolted in the motor mounts and torqued to specs. Gonna have to find some hardware to mount up the front diff.
Put on the drivers side front clip, to start messing with the electrical. This isnít gonna screw me down the road is it?
This tube broke off, I think itís part of the egr? The treads that a stud went into are toast to I guess Iíll either drill and tap it a size up or helicoil it.
  #15
Old 04-08-2018, 08:57 PM
FNG
Default
My big thing was oil leaks. I re-did the gasket on the oil pans while the engine was out, as they were leaking quite a bit.
Cover the leaks while the engine is out would my my suggestion.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
