Old 04-16-2018, 03:18 PM
Yuptown_lly Yuptown_lly is offline
FNG
Default Lly headgaskets
Does anybody know of a good write up, book, video, etc. for reassembly after installing headgaskets? I had no issues getting the heads on and torqued and setting the valve lash and installing the valve covers but now that I am at all the small stuff like wire harnesses and fuel lines I have realized I didnt take nearly enough pictures before hand. I can get the job done but I would really like to have something better to go by if it's out there. Thanks
2005 2500hd crew cab short bed lt
5" mbrp exhaust, 3" mbrp downpipe, s&b intake, Rudy's diesel turbo inlet, egr delete, profab economy flow intake tube, pcv reroute, fass titanium 150 lift pump, removed stock fuel filter assembly, lbz fuel pressure regulator, glowshift gauges, 2" lowering shackles, duramax tuner efi live[/I][/B]
Old 04-16-2018, 03:39 PM
WVRigrat05's Avatar
Wound for sound
Throw the harness over the motor and use your head, I took 50+ pics but once the harness is across the motor it’ll come easier. Just make sure you have the oil level sensor ran to the top of the motor before you put the power steering and ac bracket on, the wire runs behind it. Other than that it’s pretty straight forward. And run the body harness across the frame before putting the cooling stack back in.
Reger
100k miles. Piston eater.
Old 04-16-2018, 04:14 PM
duramax on fire duramax on fire is offline
If this helps. Here's some pics taken as we tore down an lly last week. As stated above it's not hard. Wires kind of lay back in original spots. Lines should be easy.
Old 04-16-2018, 04:15 PM
More pics
Old 04-16-2018, 04:18 PM
Pic
Old 04-16-2018, 04:19 PM
Pics pics
Old 04-16-2018, 04:20 PM
And last but not least. More pics.
Old 04-16-2018, 05:01 PM
FNG
Sweet thanks for the tips and pictures that will help a ton.
  #9
Old 04-16-2018, 05:16 PM
I hope you bought new low pressure rubber lines. Ours was starting show there age.
  #10
Old 04-16-2018, 05:23 PM
FNG
I have replaced all the rubber fuel lines I just bought a big roll of line and replaced them as I go, good or bad they looked dry rotted and I wasnt going through all that work to have a fuel leak later on.
  #11
Old 04-16-2018, 06:28 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
You might want to get those small collage hoses too. The one next to the oil fill tube got me on the first drive.
06 GMC 2500 CCSB SLT LBZ 4X4
  #12
Old 04-17-2018, 09:34 AM
FNG
I'm sure you meant coolant, autocorrect is a pain sometimes�� I replaced the small one already I can't remember if I got any others or not I'll have to look
  #13
Old 04-17-2018, 04:57 PM
Dozerboy's Avatar
Ya coolant damn autocorrect got me
  #14
Old 04-17-2018, 06:23 PM
TheBac's Avatar
TheBac TheBac is offline
If it would've changed "hoses" to "houses" too, you'd have been very confuzzled.
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
From mufflerguy on yb,
