  #16
Old 07-12-2018, 08:05 AM
Bdsankey Bdsankey is offline
Originally Posted by RobsDmax View Post
Unfortunately I agree. Really bad that you cannot trust anyone these days. I am at the same point however neither seller is doing anything for me unless I send the pistons back, so I will likely end up running it. Will not see many miles however thats probably a null point now.
So you are saying they won't do anything unless you send the pistons back to them?
If that is the case send the pistons back and then re balance the rotating assy. It isn't horrible to do.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp R75", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #17
Old 07-12-2018, 08:15 AM
RobsDmax's Avatar
RobsDmax RobsDmax is offline
He is offering me back $1000 if I give him these pistons back, would have to buy at least 3 new Fingers, and have him weight them all properly, so realistically I will not be any further ahead money wise.
2003 Chevy LB7 RC/LB
EFI By Kory
2003 Chevy LB7 CC/SB "Cheap Hooker"
EFI By Kory - S400 HSP Kit - 2.5" Billet Charger - 2.8" Puller
2008 GMC LMM CC/SB
EFI By Kory - Magnaflow Exhaust
  #18
Old 07-12-2018, 08:30 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Ne-max has a set of fingers for sale just FYI
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #19
Old 07-12-2018, 08:35 AM
Personally, at that point, I would be sending the guy the complete short block back.
You bought it at his word that it was "good" and it is far from in terms of the damage to the pistons. For $10k you can build a complete short block to mirror it, all you did was save time by purchasing it completed.
Current Rides:
Past Rides:
  #20
Old 07-12-2018, 09:48 AM
TheBac's Avatar
TheBac TheBac is offline
Both sellers need to be hung from their scrotums until they take the short block and heads back and give you all your money back, including any shipping costs/additional costs you incurred. I hate f-ing thieves.
Then you can start over.
Tom
  #21
Old 07-12-2018, 10:01 AM
Chevy1925's Avatar
I would tear deeper into it like looking at rings and bearings. who knows how hurt those are. looks like the engine had it rough.
was this dealing done through here or by a fellow member here?
James
best time to date: 12.39
Tailgate Crew Member #4
  #22
Old 07-13-2018, 07:50 AM
RobsDmax's Avatar
Both bought through members but not through the site.
EFI By Kory
2008 GMC LMM CC/SB
  #23
Old 07-13-2018, 08:42 AM
Will they both take the items back for a full refund? Did you use paypal hopefully?
Current Rides:
Past Rides:
  #24
Old 07-13-2018, 09:16 AM
Burn Down's Avatar
I would give that crap back... If they won’t take the junk back then we need to know who they are so others don’t get cheated.
04.5í CCSB ole blue, built trans, mpi twins
03í Reg Cab ZF 6
05í CCSB ole crappy, built eng, built trans, mpi twins
  #25
Old 07-13-2018, 10:04 AM
Chevy1925's Avatar
Originally Posted by Burn Down View Post
I would give that crap back... If they wonít take the junk back then we need to know who they are so others donít get cheated.
thats some bull shit. be curious to hear what they come up with though for an explanation
James
  #26
Old 07-13-2018, 10:20 AM
TheBac's Avatar
We need to know so we can remove their garage sale privileges permanently. Enough is enough with this members-ripping-members-off garbage.
Tom
  #27
Old 07-13-2018, 01:04 PM
S Phinney's Avatar
S Phinney S Phinney is offline
Heads can be confirmed by numbers Guy puts on them. He will tell you everything he did to them by the number he puts on the front head casting. I would not use this block period. You spent too much for a piece of crap for a engine.
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #28
Old 07-16-2018, 10:39 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
I agree get your money back. You are taking a big risk keeping these parts.
06 GMC 2500 CCSB SLT LBZ 4X4
