  #1
Old 10-03-2007, 10:29 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default Injector Nozzle R&R:
Put injector in a vise and grip on the .375" wide slots in the injector body. Do not over-tighten, just snug. Use a 6-pt high quality deep socket (15mm) to LOOSEN the retaining cap. It is Mucho Tighto.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #2
Old 10-03-2007, 10:44 AM
McRat's Avatar
Diesel Hotrodder
Default
Now you will hold the injector vertical in a clean area and unscrew the retaining cap. The injector nozzle will stay put on the end since it's sitting on two locator pins.
Sometimes the needle will want to stay on the injector body. LET IT. If the injector nozzle and needle do not lift together as a pair without the sleeve coming with it, get tweezers and hold the needle in place while lifting the nozzle body.
__________________
Pat and Kat McSwain
  #3
Old 10-03-2007, 11:04 AM
McRat's Avatar
Diesel Hotrodder
Default
Here's the problem, there is a little shim that rides between the actuator shaft in the injector body and the nozzle needle and is captured by a sleeve that rides halfway in the injector body and the nozzle.
Normally this shim just sits on the actuator shaft inside the sleeve and stays with the injector body, then life is simple.
But when the sleeve sticks to the needle or the shim sticks to the needle, you need to be very careful. The goal is to just remove the needle and nozzle ONLY from the top of the injector.
__________________
Pat and Kat McSwain
  #4
Old 10-03-2007, 11:09 AM
McRat's Avatar
Diesel Hotrodder
Default
When reassembling, you will notice that the two locating pins are offset. Line up the nozzle/needle to these and put in on. It will "float" about .06" above the body if the shim is in correctly. It will be under spring tension of the actuator for that .06".
Screw cap on finger tight, you should not see threads if done right. Put it back in the vice and grab the .375" flats again. I do not have a torque spec, but they stop rotating at about 50ftlb, which is what I used.
__________________
Pat and Kat McSwain
  #5
Old 10-03-2007, 11:15 AM
McRat's Avatar
Diesel Hotrodder
Default
Do not "mix and match" injector needles and nozzles.
PN for the Bosch nozzle/needle assy is:
0 433 171 860 -0B0
DLLA 158 P 1385
This is for LLY, NOT LBZ.
__________________
Pat and Kat McSwain
  #6
Old 10-03-2007, 11:37 AM
MAXLLY's Avatar
MAXLLY MAXLLY is offline
No Lemming Here
Smile
Very Cool, I just went to school. I love information.
Thanks Pat.
__________________
LLY/CCSB 4X4 SOCAL DIESEL-MIKE L-PPE-DPR-3 STG NX-II-ENGINEERED DIESEL-EATON-MAC RACING-BAYER 4 LINK-PW PERFORMANCE-ALSTON CHASSISWORKS-BOV-DUAL GATES.
Still tuned by a REDNECK TEXAN
  #7
Old 10-03-2007, 01:13 PM
duramaxin14's Avatar
duramaxin14 duramaxin14 is offline
Just Keeping Up
Default
Thank u pat.
__________________
2016 crew cab f150 4x4 5.0
  #8
Old 02-06-2009, 02:52 PM
McRat's Avatar
Diesel Hotrodder
Default
ttt...
__________________
Pat and Kat McSwain
  #9
Old 02-06-2009, 04:09 PM
dieselson's Avatar
dieselson dieselson is offline
Default
Is this just for injector maintanence?
__________________
My Truck: 02' Chevrolet EC/SB Auto, Mods: EFI Live, PPE Boost increase Valve, PPE Steering Parts, LBZ CP3
Best Time: 8.59@78.2 1/8th
  #10
Old 02-06-2009, 04:12 PM
McRat's Avatar
Diesel Hotrodder
Default
No, for those who want to put in different/bigger nozzles.
__________________
Pat and Kat McSwain
  #11
Old 02-06-2009, 06:05 PM
Alligator Alligator is offline
Default
What ever you do, do not lose that shim... All in all, swapping tips is a easy job, 5 out of 10 job for skill level. Make sure you have a super clean work area, a good can of carb cleaner to clean out the tip nut and do not have any distractions while you are exchanging them. We also torque to 50 ft/lbs.
We use a Dynomite Diesel tool to hold the injector body in place. If you order from Dynomite or a Dynomite Dealer, they will send this tool with the nozzels.
__________________
2006 CC/SB 4x4 LBZ Built - 900hp tow rig
2006 SC/LB LBZ Built - Caged
2002 SC/LB LB7 - 500hp parts getter
Team Borrowed Time #15
  #12
Old 02-06-2009, 07:20 PM
dmaxlover's Avatar
dmaxlover dmaxlover is offline
Default
Nice use for a set of parallels Pat!
  #13
Old 02-06-2009, 07:40 PM
turbo-max's Avatar
turbo-max turbo-max is offline
WaaaZaaaa
Default
a couple years ago, i took some LBZ injectors..and lost that stupid shim, BUT the good news, the injectors where screwed and going in for cores anyhow! LOL
__________________
Jeff ~turbo-max
Turbo Lag is a courteous head start.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
02 GMC Sierra 2500HD CCSB 2x4 6.0L gas
05 silver-a-do 2500 HD ext cab 4x4 * gone *
96 dodge ram 2500 ext cab 2x4 cummins gone...got the HELL outta dodge
"team salad" and defender of the McRat Universe
to the McSwains
  #14
Old 02-06-2009, 07:53 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
Timely resurrection for this thread. I need to disassemble mine to fix the leaks.
  #15
Old 02-07-2009, 12:40 PM
MMLMM's Avatar
MMLMM MMLMM is offline
Default
Why not
__________________
2002 LB7 EC/SB
Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles,
Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
