  #1
Old 06-02-2009, 02:02 PM
Turbo Buick 6's Avatar
Turbo Buick 6 Turbo Buick 6 is offline
Default Stick welding numbers
Ever wonder what the numbers on a welding electrode mean?
All mild steel welding electrodes are designated by a code thatís printed on them. This code takes the form EXXXX, or EXXXXX. So what do they mean?
EXXX, EXXXXX
The letter E designates that is it an electrode
ENNXX, or ENNNXX
The next two numbers (n) represent the tensile strength in 1000ís of psi. For example, an E7018 would have a minimum strength of 70000 psi. There are also high strength steel rods that have five numbers. In this case, the first three numbers represent the strength. An example of this would be 11018. This particular rod would have a minimum weld strength of 110000 psi.
EXXNX, EXXXNX
The next number designates the position that the rod is suitable for use in. It can be either 1,2,or 3
1 means that itís an all position electrode.
2 means that itís only for use in horizontal or flat positions
3 means that itís a flat position only electrode.
EXXXN, EXXXXN
The last number indicates several things such as polarity, type of current, and chemical composition. and is often combined with the third number to designate a special type of electrode.
(1) Cellulose-sodium (EXX10). Electrodes of this type cellulosic material in the form of wood flour or reprocessed low alloy electrodes have up to 30 percent paper. The gas shield contains carbon dioxide and hydrogen, which are reducing agents. These gases tend to produce a digging arc that provides deep penetration. The weld deposit is somewhat rough, and the spatter is at a higher level than other electrodes. It does provide extremely good mechanical properties, particularly after aging. This is one of the earliest types of electrodes developed, and is widely used for cross country pipe lines using the downhill welding technique. It is normally used with direct current with the electrode positive (reverse polarity).
(2) Cellulose-potassium (EXX11). This electrode is very similar to the cellulose-sodium electrode, except more potassium is used than sodium. This provides ionization of the arc and makes the electrode suitable for welding with alternating current. The arc action, the penetration, and the weld results are very similar. In both E6010 and E6011 electrodes, small amounts of iron powder may be added. This assists in arc stabilization and will slightly increase the deposition rate.
(3) Rutile-sodium (EXX12). When rutile or titanium dioxide content is relatively high with respect to the other components, the electrode will be especially appealing to the welder. Electrodes with this coating have a quiet arc, an easily controlled slag, and a low level of spatter. The weld deposit will have a smooth surface and the penetration will be less than with the cellulose electrode. The weld metal properties will be slightly lower than the cellulosic types. This type of electrode provides a fairly high rate of deposition. It has a relatively low arc voltage, and can be used with alternating current or with direct current with electrode negative (straight polarity).
(4) Rutile-potassium (EXX13). This electrode coating is very similar to the rutile-sodium type, except that potassium is used to provide for arc ionization. This makes it more suitable for welding with alternating current. It can also be used with direct current with either polarity. It produces a very quiet, smooth running arc.
(5) Rutile-iron powder (EXXX4). This coating is very similar to the rutile coatings mentioned above, except that iron powder is added. If iron content is 25 to 40 percent, the electrode is EXX14. If iron content is 50 percent or more, the electrode is EXX24. With the lower percentage of iron powder, the electrode can be used in all positions. With the higher percentage of iron powder, it can only be used in the flat position or for making horizontal fillet welds. In both cases, the deposition rate is increased, based on the amount of iron powder in the coating.
(6) Low hydrogen-sodium (EXXX5). Coatings that contain a high proportion of calcium carbonate or calcium fluoride are called low hydrogen, lime ferritic, or basic type electrodes. In this class of coating, cellulose, clays, asbestos, and other minerals that contain combined water are not used. This is to ensure the lowest possible hydrogen content in the arc atmosphere. These electrode coatings are baked at a higher temperature. The low hydrogen electrode family has superior weld metal properties. They provide the highest ductility of any of the deposits. These electrodes have a medium arc with medium or moderate penetration. They have a medium speed of deposition, but require special welding techniques for best results. Low hydrogen electrodes must be stored under controlled conditions. This type is normally used with direct current with electrode positive (reverse polarity).
(7) Low hydrogen-potassium (EXXX6). This type of coating is similar to the low hydrogen-sodium, except for the substitution of potassium for sodium to provide arc ionization. This electrode is used with alternating current and can be used with direct current, electrode positive (reverse polarity). The arc action is smother, but the penetration of the two electrodes is similar.
(8) Low hydrogen-potassium (EXXX6). The coatings in this class of electrodes are similar to the low-hydrogen type mentioned above. However, iron powder is added to the electrode, and if the content is higher than 35 to 40 percent, the electrode is classified as an (EXX18).
(9) Low hydrogen-iron powder (EXX28). This electrode is similar to the (EXX18), but has 50 percent or more iron powder in the coating. It is usable only when welding in the flat position or for making horizontal fillet welds. The deposition rate is higher than (EXX18). Low hydrogen coatings are used for all of the higher-alloy electrodes. By additions of specific metals in the coatings, these electrodes become the alloy types where suffix letters are used to indicate weld metal compositions. Electrodes for welding stainless steel are also the low-hydrogen type.
(10) Iron oxide-sodium (EXX20). Coatings with high iron oxide content produce a weld deposit with a large amount of slag. This can be difficult to control. This coating type produces high-speed deposition, and provides medium penetration with low spatter level. The resulting weld has a very smooth finish. The electrode is usable only with flat position welding and for making horizontal fillet welds. The electrode can be used with alternating current or direct current with either polarity.
(11) Iron-oxide-iron power (EXX27). This type of electrode is very similar to the iron oxide-sodium type, except it contains 50 percent or more iron powder. The increased amount of iron powder greatly increases the deposition rate. It may be used with alternating direct current of either polarity.
Occasionally youíll see a suffix after the first set, EXXXX-XX These are used to indicate the alloy materials and their proportions. As per the AWS:
-H4, H8, and H16 Indicates the maximum diffusible hydrogen limit measured in millimeters per 100 grams. H4 =4 ml, H8 = 8 ml, H16 = 16 ml
-A1 Carbon-Molybdenum 0.40 - 0.65 Mo
-B1 Chromium-Molybdenum 0.40 - 0.65 Cr 0.40 - 0.65 Mo
-B2 Chromium-Molybdenum 1.00 - 1.50 Cr 0.40 - 0.65 Mo
-B2L Chromium-Molybdenum Lower Carbon B2
-B3 Chromium-Molybdenum 2.00 - 2.50 Cr 0.90 - 1.20 Mo
-B3L Chromium-Molybdenum Lower Carbon B3
-B4L Chromium-Molybdenum 1.75 - 2.25 Cr 0.40 - 0.65 Mo
-B5 Chromium-Molybdenum 0.40 - 0.60 Cr 1.00 - 1.25 Mo
-B6 was E502 4.6 - 6.0 Cr 0.45 - 0.65 Mo
-B8 was E505 8.0 - 10.5 Cr 0.8 - 1.2 Mo
-C1 Nickel Steel 2.00 - 2.75 Ni
-C1L Nickel Steel Lower Carbon C1
-C2 Nickel Steel 3.00 - 3.75 Ni
-C2L Nickel Steel Lower Carbon C2
-C3 Nickel Steel 0.80 - 1.10 Ni
-NM Nickel-Molybdenum 0.80 - 1.10 Ni 0.40 - 0.65 Mo
-D1 Manganese-Molybdenum 1.00 - 1.75 Mn 0.25 - 0.45 Mo
-D2 Manganese-Molybdenum 1.65 - 2.00 Mn 0.25 - 0.45 Mo
-D3 Manganese-Molybdenum 1.00 - 1.80 Mn 0.40 - 0.65 Mo
-W Weathering Steel Ni, Cr, Mo, Cu
-G No required chemistry
-M Military grade May have more requirements
Source: TC 9-237
http://stickweld.com/electrode/what-...ding-rod-mean/
__________________
4.5 CLUB
Member #2
06 2500HD LLY reg cab 4wd
Ever feel like lying, down inside a grave
Listen to the elegy, a buyer of the hate
Ever dance beside the devil, taste the barrel of a gauge,
Ever pull the trigger, the light begins to fade
Feel like slipping away
  #2
Old 06-02-2009, 02:16 PM
maxaholic maxaholic is offline
Default
Nice info.
__________________
Shane
Gone but not forgotten 06 GMC RCLB 3/4 ton 4x4 Duramax ZF6
Now pimpin a '08 Dodge 3500 Mega Cab.
  #3
Old 06-02-2009, 02:18 PM
Default
I was asked a few questions and figured this should cover it and anyone else that was wondering the same thing.
__________________
4.5 CLUB
Member #2
  #4
Old 06-02-2009, 02:19 PM
03 D-max's Avatar
03 D-max 03 D-max is offline
Honorary "Tosser"
Default
Thanks Paul
__________________
JACOB
Post Whore want to be#1
Easter Whore Member#2
Team Borrowed Time Member#23
Quote:
Originally Posted by The Neens View Post
I don't spray much...Usually only after Mexican food
03 2500hd Efi Live, SD, PPE, FASS, MBRP, K&N
  #5
Old 06-02-2009, 02:24 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
time to dig up my lincoln tombstone..
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #6
Old 06-02-2009, 06:31 PM
calabria69's Avatar
calabria69 calabria69 is offline
Beerstud1
Default
in my buisiness we do alot stick welding, but wire welding in the field has become very popular......thats definitely some good info......
__________________
2007 LMM
12.55@106xx
2003 LB7
Sport comp II gauges
EFI
5 inch mbrp
  #7
Old 06-02-2009, 06:34 PM
Default
FYI 99% of welding most people do should be done with either XX18 or XX10 or a combo of both
__________________
4.5 CLUB
Member #2
  #8
Old 06-02-2009, 06:44 PM
MadMooseEngineering's Avatar
MadMooseEngineering MadMooseEngineering is offline
Default
The last time i stick welded i was welding a fuel tank on the side of a locomotive and I ran 7018 1/8th stick and let me tell you it was hair raising to be welding on the fuel tank.
__________________
Owner and Driver of Mallicous Intentions
2004.5 Dodge Ram 2500 qcsb sport.
2005 Chevy Silverado Gone.
Thanx to Big Twin Diesel!!
  #9
Old 06-15-2009, 07:35 PM
countryredneck countryredneck is offline
Gearhead
Default
Quote:
i agree. most days i use 7018/8018 or 6010/6011, unless a start playin with other things like stainless or cast
__________________
'06 duramax, 8" fabtech lift, dirt logic shocks, 24" akuza rims, 38" kuhmos (summer) 20" moto metals, 37" nitto mud grapplers (winter), airaid intake, EFI Live by WALLS ROD AND CUSTOM, TTS lift pumps, FPRV shim, stage 4 trans by PATC, upgraded transfer case by MA, BD manifold, EGR blcoker plate, straight piped stacks
'01 chevy ZR2 s-10, chromed out shaved tail gate handle, dual exhaust threw roll plan, ram air hood.
'87 chevy 1 ton dually, welding rig
'86 chevy 1/2, project truck
  #10
Old 06-15-2009, 07:45 PM
duramax215's Avatar
duramax215 duramax215 is offline
Team Jacoby
Default
i stick weld almost everyday! i use 7018 on our newer installs (clearer surface) and i use 6011 on the more rusted stuff.
__________________
2004.5 Chevy Duramax
-ML Converter Suncoast GMax5 Built Trans
-AirDog 165
-PPE Race Valve
-AFE Turbo Inlet
-EFI Live Tuned
-12.998 @ 103.4 mph w/ a 1.76 60'
-543.1hp 1240ft trq
  #11
Old 08-06-2009, 10:50 PM
c55asleep c55asleep is offline
Default
That's some great info! Thanks
  #12
Old 08-06-2009, 11:00 PM
durallymax's Avatar
durallymax durallymax is offline
Default
The few times I use it Ive used 7018s 6011s and 6013s.
__________________
Wife:2010 Jetta TDI "Cup Edition" Thunderbunny. Stg 2 Malone, Rawtek Straightpipe
Me:2000 Jetta TDI/5spd VNT-17, DXD S2 Clutch
Sis:2006 Jetta TDI/DSG
Puller:2003 LB7 GMC
Toy:1973 Kenworth W923
Farm:02,11,13 Duramax/Allisons
  #13
Old 10-16-2009, 01:30 PM
steakman's Avatar
steakman steakman is offline
Diesel Nut...
Default
Nice info. Good to see some clarity. am 57, Journeyman welder since 73, Welding Engineering Technologist since 84. CWI since 1991. Been with ESAB for 11 yrs as Tech Sales Rep and am always willing to share my knowledge...Christ knows we need people in our industry.! (North America is short 300,000 qualified welders right now.) Also good to see "brother welder here"..!!
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
As for rusty metals..try to obtain some 7016. It is still a low hydrogen electrode but has a bit less iron powder in it and is a bit more of an active arc...work especially well in dirty or even mildy rusty areas. At the same time will give much higher tensile strengths and ductility as opposed to using a cellulosic electrode such as 6010 or 6011.
Using GMAW (mig with solid wire), clean steel is an absolute must. For dirty or mildly rusty materials - using 100% CO2 is a good choice. As with Flux cored wires though, as you get up into the std types of mixes: 75% Argon - 25% CO2 and higher argon contents (85/15..92/8 etc), the steel must be clean and if possible, sand blasted.
With FCAW or Flux core, a bit of mill scale and mild rust can be tolerated.. again, when using 100% CO2 as a shileding gas. As one goes up higher in Argon content..that ability to tolerate mill scale and rust lessens. Nice thing with most flux cored wires is their all postion capability and that some are available down to .035 diameter. We make one.
Metal Core wire will typically require high argon gas mixtures typically 90/10 or 92-8 to be truly effective but although these wires are extremely fast and have the highest deposition of semi-Auto or full automatically welded cored wires...base material cleanliness is a must and extremely important. Also Metal cored wires are only for flat and horizontal welding.
Direction of welding (with wires), is always a point of contention among many in the industry.
However the rule of thumb is: if it has slag - you drag. I see so many guys pushing flux cored wire..and it should be dragged not pushed. (you'll trap slag if you do and not burn into the root of the weld). With Metal Cored wires you really want to push.
The difference between Metal cored and Flux cored wires is as follows;
Flux cored wires will have typically 50% Iron Powder fill with the rest being slag forming agents and arc stabilizers. Typical deposition efficiency for these wires is 83-85%. The rest of the product goes in sparks, and slag.
Metal cored wires will typically have about 85% Iron Powder fill with the rest being Silica (not Silicone..that goes into breast augmentation eh.!), and arc stabilizers. Typical depsition efficiencies with these wires are up to 99%.
But as I mentioned the position is FLat or Horizontal only.
For AWS Classifications and what they mean on Wires see attachment below:
Cheers,
stk
__________________
"the ghost"
06 GMC LBZ CCSB
...a bit of stuff...
174,035 miles
  #14
Old 10-16-2009, 02:13 PM
<--- slippery roads
Default
Steak you have a PM.
ben
__________________
  #15
Old 10-18-2015, 04:53 AM
baddaddition's Avatar
baddaddition baddaddition is offline
Default
Good Info!! It is crazy how short we are in the Industry! I'm a regional millwright supervisor,and its hard to get someone whom truley values the years of experience from the elders I. The Industry. I'm 27 and have soaked up every bit of knowledge from my superiors over the years. Been in the I dustru for only 8 yrs, but I've learned alot and got alot to learn yet. It's awesome people are willing to share this info above. Thanks again guys! " Turn and Burn Boys"!! I've lived by the saying " you have two ears and one mouth"
Sent from my XT1254 using Tapatalk
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
