  #1
Old 09-16-2017, 03:40 PM
Weisguy Weisguy is offline
Gearhead
Default Issues after rebuild
I've spent a lot of time trying to find what's wrong and can't find anything that fits my problem. I bought a 2001 2500HD duramax with 5 speed allison. It had a leak at the bellhousing and also came with a full transgo kit. So I took it out and decided to take the transmission apart and install the kit. After reinstalling the transmission, it slips really bad and wont move sometimes. When it does get moving, it wont shift out of 1st. I thought it might be the nsbu so I replaced it and it didn't work. I have my own shop and have built several motors before but this was my first transmission. I made sure everything was put back right. I only replaced 1 C1 clutch due to some chipping. The rest of them were in perfect shape and checked with a micrometer. I figured I would see if anyone knew anything. I was hoping for some advice from Mike L. as I understand he is the expert in these trannys. Thank you for any help
  #2
Old 09-17-2017, 08:16 AM
Gearhead
Default
Ok. After hooking up an edge cts2 to the truck I found out the torque converter lock is not reading D but it does read PRN. It's showing the transmission is in neutral and don't allow movement. Any ideas?
  #3
Old 09-17-2017, 08:32 AM
catman3126's Avatar
catman3126 catman3126 is offline
Ehhh?.... You don't say?
Default
Oil level good when Idling? Codes? sump filter didn't fall out when you put the pan back up did it?
__________________
2005 2500HD dmax, CCSB, 4" exhaust, Built motor with Carillo's .020 over 16:5.1 piston with .075 reliefs, Socal 6480 alt fire cam, ported LBZ head's, Exergy 10MM pump Stock lly cp3 on the belt, 400% LBZ injectors, S471/87 compounded with a GT5541R 106MM Fleece billet charger Werhli fab S400 install kit with bridge and piping, Merchant Auto Billet push tubes, Socal Valve springs, Socal valve covers, Socal flex plate, Mishimoto black intercooler, DSP5, Air dog 165,
1986 K10 short bed LQ4/4L80E
1984 CJ7 Powered by a 2000' LS1 5.7L
2015 LTZ Z71 LML, CCLB 3500HD.
  #4
Old 09-17-2017, 09:18 AM
Gearhead
Default
The fluid is at the right level. No codes are present except when I'm messing with it and making them appear. I made sure the filter was in all the way and it wouldn't come out. I'm working on a theory about it being the wiring between nsbu and tcm.
  #5
Old 09-17-2017, 09:52 AM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Default
unplug the case connector at the back of the trans, if you have 3rd & reverse it's electrical if not it's internal.
__________________
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #6
Old 09-17-2017, 10:29 AM
Gearhead
Default
Ok. I unplugged it and it didnt change anything other than it made it start grinding when I put it in park. The truck has gotten worse and will only move forward at 1600 rpm and it'll only move a few feet before it stops. I really need to figure out what's going on. It's confusing me so much. I have the atsg guide for the allison and have read every page trying to figure out what could cause this. I'm going to try to include a picture of the monitor that shows its displaying N when I'm all the way in 1 on the shifter.
  #7
Old 09-17-2017, 10:31 AM
catman3126's Avatar
Default
Did it shift and drive fine before you took it apart?
__________________
  #8
Old 09-17-2017, 10:38 AM
Gearhead
Default
Yes. It had a leak so I didn't want to drive far but I did make sure it went through all the gears before buying it. It won't let me upload pictures but my cts2 has a pid for torque converter lock and gear display and it stays in N for all forward gears.
  #9
Old 09-17-2017, 11:03 AM
Gearhead
Default
Ok. I figured out how to force the display to be in a gear I choose. But it still won't go to drive instead of neutral. Could it be the tcm itself? It always thinks it's in neutral so it doesn't apply pressure the the cluthes?
  #10
Old 09-17-2017, 11:18 AM
rcr1978's Avatar
Default
Quote:
Well if you don't have a solid 3rd or reverse with the case connector unplugged it's internal and the trans needs to come out.
__________________
  #11
Old 09-17-2017, 11:22 AM
quinton's Avatar
quinton quinton is offline
Default
You messed something up then if it drove fine before you tore it apart.
__________________
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
  #12
Old 09-17-2017, 11:23 AM
Gearhead
Default
Ok. I can do that. But there are 100 internal parts. I need to know which one to replace.
  #13
Old 09-17-2017, 11:50 AM
quinton's Avatar
Which ever ones you touched, it ran fine before so you installed something wrong.
__________________
  #14
Old 09-17-2017, 11:56 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
No one is there to see what you screwed up nor can we tell through the internet. At this point, it's best you take it to a shop before you really cost yourself some money.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #15
Old 09-17-2017, 11:57 AM
Gearhead
Default
I touched everything for the c1 c2 and c3 clutches. The torque converter, the input shaft, front pump, valve body, solenoids, and a lot of clips. So I need to know which of all those pieces would cause this problem.
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
