  #1
Old 09-05-2017, 12:48 AM
Moneywellspent's Avatar
Moneywellspent Moneywellspent is offline
Default Cryo heat?
So not to long ago I came across this company called cyroheat. A lot of their work consists of cryo treatment and micro polishing. They're claiming that it extends service life, reduces friction and heat and so forth. The finished product looks amazing but if you ask me the claims are kinda far fetched or over the top.
Has anybody actually heard of or have any experience with treating bilet parts? Just being curious is all...
__________________
Low and slow built LBZ | Big single| SSDT Dsp5
  #2
Old 09-05-2017, 03:05 AM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
Isn't that the process they do to alot of standard transmissions for pulling to hold more power? I really thought that process was used on crankshafts and camshafts too for a hardening process
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #3
Old 09-05-2017, 09:31 AM
Default
Quote:
Yes it is. This company does a lot of different stuff. I was just curious if anybody is doing this to input shafts and planetarys and so forth as well.
__________________
  #4
Old 09-05-2017, 06:59 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
knife makers use cryo treatment quite extensively. there is likely more information floating around the knife forums about this than any other area of the web
here is a good article: http://www.blademag.com/knife-collec...treated-blades
and a relevant excerpt:
“Most tool steels actually develop their hardened structure, or martensite, during the quench,” he continued. “For various reasons, however, in some cases transformation to martensite may not be complete even at room temperature. In such cases, some of the high-temperature microstructure, or austenite, may be retained after normal heat treating.”
A2 and D2, as well as other high-alloyed tool and specialty steels, may contain as much as 20 percent austenite after normal heat treating. Cooling the steel to cryogenic temperatures furthers the conversion to martensite. However, the process is specialized and requires close attention to actual temperature, levels of exposure, and the time intervals involved in raising and lowering the temperatures of the steel itself.
“The newly formed martensite is similar to the original as-quenched structure and must be tempered,” Devanna warned. “Cryogenic treatments should always be followed by tempering. Often the cryogenic treatment is actually performed between normally scheduled multiple tempers. Technically, cryogenic treatments are most effective as an integral part of the original quench, but due to the high risk of cracking, it’s recommended that tempering or a snap temper be performed before any cryogenic treatments.”
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #5
Old 09-06-2017, 03:01 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
We've had 1 rear ring & pinion cryo'd that lasted a good while. We also had the transfer case main shaft cryo'd and its still going strong.
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #6
Old 09-06-2017, 12:05 PM
Default
Quote:
Would you say that the cryo would prove to extend the life of shafts and hard parts of that nature?
__________________
  #7
Old 09-06-2017, 12:20 PM
ikeG's Avatar
Oughta Know Better
Default
Seems like it. Not exactly a scientific test, tho. Those parts we cryod will break no matter what with what we do.
Sent from my XT1585 using Tapatalk
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #8
Old 09-09-2017, 12:56 AM
Default
Very true. But anybit helps ya know. it's just something that caught my eye and got me wondering if that would be an alternative to buying bilet inputs and outputs or if people went the distance and cryo treated billet parts.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
