Old 01-28-2016, 08:36 PM
The Kansan's Avatar
The Kansan The Kansan is offline
Default Main stud torque sequence and removal
Hey guys the machine shop torqued the main studs to my block with the gorilla girdle for shipping (i know the specs) but i dont have the torque sequence and is there a certain way these need to be untorqued. Thanks
-2003 CCSB Silverado-
-Billet S366
-Spearco Intercooler
-Suncoast Trans-1055 Converter
-ARP Head Studs
-40 Over Injectors
-PPE Manifolds & Up Pipes
-5 Inch Exhaust
-FPE Lock up box
-Kryptonite Center link
and Tie Rods
-Remote Modded CP3
-HSP Pulley
-HSP Intake
-Cognito Traction Bars
-Cognito PISK
-Relocated FICM
-Airdog 200
-Merchant Motor Mounts
-EFi Live by me
Old 01-28-2016, 08:58 PM
Ne-max's Avatar
Ne-max Ne-max is online now
I like turtles
https://youtu.be/nP8P0Gge0bQ
2006 ccsb Lbz Tow rig
2006 rclb 6.6
Old 01-29-2016, 03:15 AM
LtEng5 LtEng5 is offline
Gearhead
Per ARP web site....
156158
2007 Chevy LBZ ECLB 4WD
Old 10-22-2017, 08:58 AM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Bumping this up SoCal said 225, Randy/Industrial on that 7 year old video sais 200, and ARP sais 175 What's everyone doing?
04 LB7 ECSB down with a cracked piston, build in progress- Wagler narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, 2 CP3's, S475/Stock twins fer now more . later
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
Old 10-22-2017, 01:45 PM
Chevy1925's Avatar
Follow What ever the machine shop torqued them to when they honed the mains
James
best time to date: 12.39
Tailgate Crew Member #4
Old 10-22-2017, 03:58 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is online now
Yes, its really me
While the final torque is very critical. The above information is as important as anything!!!
2003 GMC CCSB LLY
Built by me, tuned by me.
Old 10-22-2017, 01:42 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is online now
If you take 225+200+175=600 divided by 3=200 , food for thought .
05 CC/LB DRW LLY Allison
AFE Blade Runner ;DHD Big Air intake;DHD fuel block;DHD pcv reroute;MBRP 4 inch exhaust;DHD 3 inch downpipe; BD driver's side manifold; DHD pass side up pipe ;DHD 3 inch intercooler in and out pipes by Big Foot on & off road shop ; shimmed fprv; FASS fuel system; 5/8 inch pickup; FASS fuel filter delete; EFI live, 5 position switch 250 hp big tune by Crank it up ; built SunCoast Allison 1078 converter by Limitless Diesel; Sulastic shackles;ARP head studs; grade C gaskets; tig-welded water pump ;T stats; by Blackout performance; Merchant t case brace and pump rub kit;drive shaft 1480joints Greensburg machine,BDS Recoil traction bars , 5100s
Chevy1925's Avatar
Seriously......
James
  #9
Old 10-22-2017, 02:07 PM
Ya the difference between 175 and 225 is about half an inch pull on torque wrench , what about stud stretch after hone , and I doubt all machine shops know all three of the suggested torque values mentioned .
  #10
Old 10-22-2017, 02:26 PM
Chevy1925's Avatar
Sometime I think you post just for the sake of increasing your post count
If you think 1/2 is minuscule, look up main bearing clearances. You will see the importance then..... well I hope anyhow
James
  #11
Old 10-22-2017, 03:54 PM
Awenta's Avatar
Awenta Awenta is online now
Well I know who has no business using a torque wrench
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
  #12
Old 10-22-2017, 04:58 PM
We race late models our eng builder does a hone torque as to not stretch studs to excess then after bearings assy lube and crank final torque sequence . Holds together all season ! But thats what is so nice about having you experts to ask questions to . Thanks for all the assistance ! Some of you might remember the old torque wrenches with the rod that you just bent back when it got out of so called calibration ! Funny how those engs still turned 7000 rpm regularly . Torque sequence is much more imp than being within 10lbs of each!
  #13
Old 10-22-2017, 05:26 PM
Chevy1925's Avatar
I had something all written up but its just not worth my time. That apples to oranges comparison does you no favors
James
