  #1
Old 03-10-2018, 04:13 PM
Dragbear Dragbear is offline
Dragbear
Default S371 to S475 conversion.
Hi my name is Rick Abare.
I have a LMM daily driver that i pull 2.5 workstok in.
I ran a S371/ 83/ .91 all last year with no issues. I wanted to upgrade to the S400s for this year and my son has a
S475 / 91 / .90 so I bought a S400 install kit from HSP and bolted it on.
What a PIG!!!! What a nightmare to drive!!
No power below 2500rpm just a lot of smoke. I have to run 4th gear 80mph to keep it above 2500 to get up any hills.
Wear am I going wrong??? This turbo came off my son's 5.9 Cummins and made 70psi of boost. He was putting 50' on me at the pulls!
My set up is:
Built bottom end 15.8 comp.
Alt fire cam.
150% injectors
Twin CP3s
Fass
Pro fab headers and up pipes
T4 pedestal
Thanks for any help!!
I am about to abort this s400 nightmare!!!
__________________
S&B intake, Fleece 63mm cheetah turbo, Exergy 60% over injectors, Industrial Injection 12mm 85%over CP3, Banks down pipe, Sinister intake tube & egr cooler delete, Diamond turbo down pipe, Cat-DPF delete, Black Cloud stack kit, Grand Rock 6" Aussie stacks, Drop in stack mufflers, Fass titanium 150, Ported fuel rail fitting, Pressure relief block off, EFI Live, Built Trans, Vigilante converter, Trany to transfer case brace, Traction bars, Drive shaft hoops, Eaton front e-locker, Cognito braces, Tie rod sleeves, Edge insight.
  #2
Old 03-10-2018, 04:31 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
Auto or stick ? What tuning system ? What gears ? So are you not going to pull work stock anymore ? Someone with alot more knowledge than me might let us know if you need to change to a T6 pedestal ! Good luck!
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #3
Old 03-10-2018, 04:35 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
What converter?
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #4
Old 03-10-2018, 06:26 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
Did you change tuning for the maf sensor?
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #5
Old 03-10-2018, 06:50 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Quote:
I had this problem when I switched from a garrett 4094 to a 4202. It was a complete pig until the maf tables got changed
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #6
Old 03-10-2018, 11:02 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
It's not as easy as people make it out to be... Trial and error...
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #7
Old 03-11-2018, 05:15 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
If it actually is the 92mm turbine, it is the laziest turbine you could of chosen. The 3 common Borg warner turbines are 83/74, 87/80, & 96/88. They also made a 92/82 that flows less than the smaller wheels and also manages to be super lazy.
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #8
Old 03-11-2018, 05:29 AM
Dragbear
Default
At this point the converter is out of the pitcher because I am on the road over 45mph and the converter is locked. If I can't get it to work work better here there is no reason to go any further.
I had issues with the mass air reading going to 0 a lot so Danville tuned the mass air out of the tuning. It reads 600 all the time now. It has been that way for 2 years and runs great.
I have tuning from Starlight also and he uses the mass air and it runs no better than Danvilles tune.
The mass air goes to 0 above 3000rpm. I have replaced it and it no longer goes to 0.
Still running stock gears with a built Allison Trany. I had to get the torque converter restalled for the S371 and could foot brake it to 2200rpm and 20psi of boost. With this S475 the best I can get is 1800 and 1psi of boost.
I am thinking that I need to get rid of the 91mm turbine and get an 83mm??
Thanks, Rick Abare
__________________
  #9
Old 03-11-2018, 05:35 AM
Dragbear
Default
I didn't buy this turbo it is a spare from my son's dodge truck. It is a 2.5 pulling turbo from Tator. I just wanted to try it before I bought one.
I am still running 2.5 work stock in some places and 2.6 in others. Most places require you to have a stock turbo so i get forced into the 2.6 class a lot.
__________________
  #10
Old 03-11-2018, 08:39 AM
Ne-max's Avatar
I like turtles
Default
Converter is too tight.
__________________
2006 rclb 6.6
  #11
Old 03-11-2018, 08:54 AM
Dragbear
Default
Like I said the converter is out of the problem when it is locked at 65mph.
__________________
  #12
Old 03-11-2018, 09:37 AM
Ne-max's Avatar
I like turtles
Default
Sounds like you already have all the answers. Good luck getting more boost out of the hole. Have a nice day.
__________________
2006 rclb 6.6
  #13
Old 03-11-2018, 09:42 AM
ikeG's Avatar
Oughta Know Better
Default
Did he ask how to get more boost out of the hole?
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #14
Old 03-11-2018, 10:05 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
You need to play with your transmission tune. You keep saying the converter is locked missing what we are all implying: it shouldn't be.
My truck is tuned to unlock the converter as soon as it starts to lug. That lets the RPM come up so it gets some boost, then it locks again.
And it does sound like your converter is too tight too, if you can't build boost on the line. I was in basically your situation with my cam+turbo combo, and I solved it with a re-stall and tuning (both engine and transmission tunes).
Sent from my Cat S60 using Tapatalk
__________________
  #15
Old 03-11-2018, 11:12 AM
quinton's Avatar
quinton quinton is offline
dAVe3283 is correct. Convertor and tuning will fix it. Ran a few different s475ís and each one I had to adjust tuning every time, convertor restalled made a world of difference too. You donít want the convertor locked that low of speed with that turbo setup. These guys telling you answers, like Ne-max, more than likely have been through the same scenario and already have done the trial and error.
__________________
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
