  #1
Old 06-29-2017, 08:03 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default Upper control arms
Okay guys so I took my truck in for an alignment today and my passenger ball joint he said had over an inch of play SO. time for something to happen. Right now there is absolutely no way I can afford a set of $500 cognito control arms. The truck has the t bars cranked just a little. Doesn't sit anywhere near level. I'm thinking 1 or no more than 2 inches above flat cv angles. Should I go with stock stuff and just do a cheap replacement or I've saw the new zone control arms. Look like a good piece. Can get them for around 370. Or should I go kryptonite? They have bolt in ball joints and are $437. What do y'all think?
__________________
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #2
Old 06-29-2017, 08:11 AM
Slowmax's Avatar
Slowmax Slowmax is offline
Build what others' won't
Default
Also am do for another set of upper control arm's, but I am lowered. What is everyone running these day's? I had flat cv's and Ac Delco, factory replacements'. I put on didn't make it more then a year.
__________________
02 Silverado 4 inch turbo back exhaust with muff, A.E.M intake with cone filter, EFi live.
  #3
Old 06-29-2017, 08:13 AM
Awenta's Avatar
Awenta Awenta is offline
Default
https://www.amazon.com/Moog-RK620054...ype=automotive
Hard to beat these for the money
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #4
Old 06-29-2017, 08:45 AM
zakkb787's Avatar
<thatís not me...
Default
Do these aftermarket ones make the ride better or anything? Don't they correct the angles for a slightly leveled truck?
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #5
Old 06-29-2017, 08:48 AM
SoCalMike's Avatar
SoCalMike SoCalMike is offline
Default
For a couple dollars more you can get the problem solvers.
https://www.amazon.com/gp/aw/d/B00FJ...ID=61yS5lwMfRL
__________________
  #6
Old 06-29-2017, 08:55 AM
SoCalMike's Avatar
Default
Quote:
All the aftermarket ones (cognito, kryptonite) give you more drop out and correct the angles to get your alignment in spec. That's about it. If you are a stock height or a little above, stick with stock like uca's in my opinion. If you are really cranking up the front or have money to burn go with aftermarket. But even then they are only a bandaid to the problem.
__________________
  #7
Old 06-29-2017, 08:56 AM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
Default
I run the kryptonite arms with keys for now. I wanted the uniball arms but my thing was if it broke i can buy a ball joint at any local parts store in the us and mexico. I have beat on my truck in the Southern California desert and in some washes and trails in AZ. I do about 75 to 100 mile loops with lots of liquid talent enhancers. I havent had a problem with them and they are made in the USA. Just my $.02
  #8
Old 06-29-2017, 09:01 AM
SoCalMike's Avatar
Default
I think the moog problem solvers are even cheaper on Rock auto.
__________________
  #9
Old 06-29-2017, 09:06 AM
zakkb787's Avatar
<thatís not me...
Default
My truck isn't leveled anymore I turned them way way down. Sits about an inch or 2 higher in the back. So just go with the problem solvers? I like the price point. Another off topic question. How can I get my cv angles flat at the height I'm at now. Seems like a 4 inch would lift it too much even turned all the way down. Thinking a diff drop bracket of some sort?
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #10
Old 06-29-2017, 09:13 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
i wouldnt trust those. they more than likely use the junk Moog ball joint that will die in 10-20k.
any of the arms you posted Zack will do what you need them to. you dont need the extra down travel a cognito arm will give and you certainly dont need the stupidly overly built arms some of these places sell. id just throw a set of napa NCP part number UCA on and call it done. Actually, me personally, id jsut replace the ball joint and throw a tack on the joint so it dont pull out of the arm lol
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #11
Old 06-29-2017, 09:18 AM
zakkb787's Avatar
<thatís not me...
Default
Thank you James. I'll call around this evening and see what I can find. Sucks because I'm supposed to take it to the beach tomorrow but thought it needed aligned because the passenger tire is turned a bit more than the driver. Guess that wasn't the issue
Edit: WOAH just called Napa and $130 each. I can almost get a set of upgraded ones for that. Or even a lifetime set of moog. Those are $209. Anyone used the dmaxstore xd series? $159 for both and a 3 year warranty
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #12
Old 06-29-2017, 09:22 AM
Aka Mike Honcho....
Default
^ this is very true.
  #13
Old 06-29-2017, 09:25 AM
SoCalMike's Avatar
Default
Edit: WOAH just called Napa and $130 each. I can almost get a set of upgraded ones for that. Or even a lifetime set of moog for cheaper. Anyone used the dmaxstore xd series? $159 for both and a 2 year warranty
The dmaxstore xds are mevotech upper control arms.
I would do what James said or at least the moog problem solvers
__________________
  #14
Old 06-29-2017, 09:26 AM
zakkb787's Avatar
<thatís not me...
Default
I can get the problem solvers for $68. Why are they so much cheaper than the Napa brand? Is that a quality difference?
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #15
Old 06-29-2017, 09:34 AM
Chevy1925's Avatar
Default
because they are on hand . i also know they use a teflon coating inside to encompass the ball and keep wear to a min when grease is not present or has thinned out. Mood problem solvers are hit and miss. they use to be the good stuff, now some are junk.
If you want to hit the beach tomorrow, go pick one of these up and throw it in
https://www.napaonline.com/en/p/NCZ2...earchIndex=App
looks like they now use a circlip to keep the joint from popping out of the arm like they use to. in that case, i wouldnt even buy a new arm if the bushings are still good in your old arm.
is your other side showing movement as well or is it tight? jsut cause one is bad does not mean both are. im still on a stock original LCA ball joint with 213k, other side died at 190k.
__________________
James
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
