  #1
Old 10-15-2016, 09:13 PM
Cknight199's Avatar
Cknight199 Cknight199 is offline
Default Thoughts on CP Carillo's Hybrid Rods/Pistons?
What are your thoughts on these? Are there benefits (other than weight savings) to running a setup like this?
http://www.cp-carrillo.com/n-12064-h...ow-availa.html
__________________
"Relentless" 2007 LBZ CC/SB
Plenty of Air and Fuel
Huge thanks to Custom Auto, and Starlite Diesel
  #2
Old 10-16-2016, 09:05 AM
akdmaxx akdmaxx is offline
FNG
Default
Finger's oval's are designed to keep more material above the pin to makenthem more resistant to cracking in that area. It would seem that making a shorter piston would take material away from that. That being said they are forged but only available in 16.5:1. Kind of a high comp ratio for a piston and rod going after the racing crowd. Forged is not a good choice for a DD.
  #3
Old 10-16-2016, 10:35 AM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
I like the longer rod.
I like the weight savings.
I'm not fond of the smaller pin diameter for a daily driver or forged for that matter.
The latest rev of the Mahle forged with taper cut pins puts you in this same weight ballpark as these, but with the stock rod length and pin diameter.
__________________
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #4
Old 10-16-2016, 01:41 PM
Dave c Dave c is offline
Default
Ngm diesel race engines now has a new forged aluminum piston with steel ring land available. Drop in replacement.
Carrillo, and fingers both have nice products as well.
  #5
Old 10-16-2016, 04:54 PM
Cknight199's Avatar
Default
That's cool but has nothing to do with his thread??? You didn't even provide any input.
__________________
  #6
Old 10-16-2016, 05:13 PM
TheBac's Avatar
TheBac TheBac is offline
Default
I think its interesting that Dmax rods are going to the offset cap design.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #7
Old 10-16-2016, 05:27 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
Weight savings is cool, I think the pin will be fine. And if you aren't spinning serious RPM the stock rod length is plenty.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #8
Old 10-16-2016, 08:38 PM
DaveB's Avatar
DaveB DaveB is offline
Default
Diamond has the new steel ring land piston coming out that will be available through mulitple sources. If all goes well I should have a set in November.
I like the idea of their package deal, however I'd still want to go to the narrow rod end and Callie's crank setup.
  #9
Old 10-17-2016, 02:58 AM
gmc502 gmc502 is offline
Default
what are we talking cost wise?
__________________
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
  #10
Old 10-17-2016, 04:47 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
Quote:
Are you sure that's not a Cummins assembly in the pic? Or did you see it somewhere else?
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #11
Old 10-17-2016, 04:50 AM
TheBac's Avatar
Default
It probably is, Issac. But the new '17 Dmax is offset cap. I wonder if they are backward-compatible?
__________________
Tom
  #12
Old 10-17-2016, 04:56 AM
ikeG's Avatar
Oughta Know Better
Default
I see where u were going Tom. That's a good question
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #13
Old 03-13-2018, 07:53 AM
Bdsankey Bdsankey is offline
Default
The hybrid kit does not use an offset cap design. The L5P rod is offset cap. I know this about the hybrid kit because I have one.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp 75R", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #14
Old 03-13-2018, 10:16 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
Quote:
you realize this is about 1.5 years old and its just cause Tom didnt read that the pic in the article is for cummins, right?
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #15
Old 03-13-2018, 10:31 AM
Default
Quote:
Can it be Monday?
__________________
Current Rides:
Past Rides:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
