  #1
Old 05-16-2018, 07:16 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default CV Boot Squeak
My Suburban recently developed a squeak in the front end that matches vehicle speed. Jacked it up, and it was coming from the passenger CV boot. I put some silicon spray on the boot, but that made it much worse. Cleaned that off and sprayed it with WD-40, and it was silent! For 2 days.
The boot looks to be in perfect condition, no cracks or tears, still flexible, etc. But if I don't hose it down in WD-40 every couple days, it makes a horrible cyclical squeak noise "eeeeek-eeek-eek", loud enough it drowns out the LB7 as I pull away from a stop. Super annoying inside the vehicle, I can't imagine how painful that must be for pedestrians.
Has anyone else had this happen? Are there any solutions besides replacing the CV (which is in otherwise perfect shape)? Spraying it with WD-40 every other day is not a viable option, as it flings off and makes a mess while I drive.
__________________
  #2
Old 05-16-2018, 09:28 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
flatten out your CV angles
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #3
Old 05-16-2018, 10:12 AM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
Try wiping some 90w on it, it’ll stick better and might soften it up a little.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles. Piston eater.
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #4
Old 05-16-2018, 10:54 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Have you checked to see if the boot and band clamp are still in its proper place? Unless your cv angles are extreme I don't see how they could be rubbing while driving straight.
You can always cut the band and pill the boot out a little further up the shaft and reclamp it so the ribs aren't rubbing
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #5
Old 05-17-2018, 06:13 AM
DAVe3283's Avatar
Default
Rise height is stock, as far as I can tell. When I checked the boots, it was at full droop from being in the air, but it does rub while driving. I can see the area where it touches. Never thought about the boot being in the wrong spot, that's a great suggestion!
I'll measure the boot positions vs. my truck to verify. Especially since it is just the one CV squeaking, I think you're on to something. I wonder how it could have moved to begin with?
I'll try and track down a new clamp (or similar) and move the boot, if that's the issue. Also try some 90W oil, because why not.
Edit: add ride height photo
Sent from my Cat S60 using Tapatalk
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
