Old 05-16-2018, 08:16 AM
AKlowriderZ71's Avatar
AKlowriderZ71 AKlowriderZ71 is offline
Default Soooo tired of replacing upper ball joints
Is there more than one option for upper control arms that will correct the geometry?
2001 ECSB 4x4 2500HD, LB7, Stock Allison, Edge CTS Insight w/backup cam, EFI Live tuned by SS Diesel Tuning(thanks Steve!), 4" exhaust.
2001 ECSB 4x4 1500, Blown 5.3 liter. -Sold & Gone-http://youtu.be/ZM2m1bKC1JY
Old 05-16-2018, 08:25 AM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
I did rough country uppers and have zero complaints
17 GMC all terrain L5P, stock with dark windows
07 crew long classic- stolen
gmc502 gmc502 is offline
stock arms?
I'm trying the cognito's,,hope they hold up,,at least I can change them out quickly.
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
Old 05-16-2018, 01:43 PM
WVRigrat05's Avatar
Wound for sound
I’m curious too, I have a set of cognito arms I still need to stick on that needs ball joints and bushings
Reger
100k miles. Piston eater.
Old 05-16-2018, 06:25 PM
snowman22's Avatar
snowman22 snowman22 is offline
Gearhead
Kibbetech makes a nice set of upper arms for the 2011+ trucks.
https://www.kibbetech.com/collection...r-control-arms
2015.5 LML GMC Denali 3500 SRW 4wd CCLB 90k Miles
MotorOps, Mike L Trans, 4" FlowPro, MBRP Down Pipe, 30" FTE Resonator, S&B Intake, Twin Kennedy Pumps, Bilstein 5100, Edge CTS2
Sold: 2003 LB7 CCLB 350K miles
duramaxtuner.com Tuned, Mike L Trans, ProFab Stuff, and much more...
Old 05-16-2018, 08:29 PM
Burn Down's Avatar
Cognito on the 04 and Kryptonite on the 05. Cognito’s have held just fine so far 20k miles still tight. Not sure on the Kryptonites? Haven’t had the truck that long but they are tight as of now.
04.5í CCSB ole blue, built trans, mpi twins
03í Reg Cab ZF 6
05í CCSB ole crappy, built eng, built trans, mpi twins
Old 05-16-2018, 10:18 PM
1FastBrick 1FastBrick is offline
Get a better mechanic...
Is your truck Lifted, Leveled, Lowered, Stock?
I have only heard good things about Kryptonite Suspension parts.
All Kryptonite suspension components carry a Lifetime Warranty.
(Kryptonite No Fine Print Lifetime warranty)-Kryptonite steering and suspension components are warrantied for life to their original purchaser. This warranty is against any manufacturer defects, premature wear or breakage. Race it, jump it, off road it, sled pull it, wreck it, lift it, level it, lower it, I think you get it? We donít care. If you can break it we will replace it. Kryptonite products must be purchased from an authorized dealer.
Old 05-16-2018, 11:41 PM
scramHD's Avatar
scramHD scramHD is offline
Its only a Baby Ruth
Ive had both Cognito and Kryptonite. Between the two Id choose Kryptonite again. Excellent quality. I installed Kryptonite UCAs, Krytponite front wheel bearings, Kryptonite lower ball joints and sway bar end links at the same time. The ride and handling has no comparison to stock its insane how much better it is. Next will be their tie rods as my PPEs are aging.
Id go with Kryptonite .
02 LB7, cc/sb 2wd
EFI LiveV2/Neens/ATS/SoCal/PPE/SuperDiesel/Industrial Injection/TrentNell/MFrank*rip*/TTS/-McRat--Kat-/Dan
15 LML cc/sb 4wd
Zone 5"/ Fox 2.0 Resi / 4k lb rear leafs
Kryptonite UCA's/WB's/LBJ's
Cognito PISK / SB end links / PPE Stg3 tie rods
63.5mm 6+6 / AD 165 4g / sump by Ohio Diesel
Mishimoto hot & cold intercooler pipes / 4" CAI by me
3" MBRP downpipe / 4" ex / Magnaflow 20"
DEI heat wrapped ex / hand polished factory tip by me
Revmax Billet Triple / vb mods / T87 tuning by me
E86b Ridgerunner / EFIv2 / l25hp / 75hp
Autometer pod / oil temp / boost / CTS2
Bora 1.5" / 18s / 295/70
12 yz450f
polished frame/swingarm by hand by me
GYTR head / Cycra powerflo / Flo motorsports/ Vortex bars / Ascerbis X seat / ASV shorty levers/
Bazzaz Tuning/Logging /SCAR racing / Scorcher SS header /HotCams / Twin Air
  #9
Old 05-17-2018, 09:58 AM
Burn Down's Avatar
What does being tired of replacing upper ball joints have to do with getting a better mechanic?
03í Reg Cab ZF 6
  #10
Old 05-17-2018, 10:56 AM
TheBac's Avatar
TheBac TheBac is offline
Albert, they've known each other for years. Just good natured ribbing. Think "you and Simon" when you read it. Then it's funny.
Tom
  #11
Old 05-17-2018, 12:39 PM
LBZ's Avatar
LBZ LBZ is offline
Not sure why some guys have so much trouble with wheel bearings and ball joints.
My LBZ was lifted with 35ís and I only changed one wheel bearing while still under warranty and never did any ball joints in 180 000 miles. This truck wasnít a pavement princess either. It got run hard. It needed them when I traded it in but still got 180 000 miles out of the factory parts.
  #12
Old 05-17-2018, 08:46 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
I go through a set of wheel bearings every 80-100k on my truck with 35" tires. I think weight and speed do more to wear them out than off-road or track abuse. I'll have the front axle 500+ lbs over gross, then set the cruise control at 80+ for 6 hours.
Wheel offset can play a big part too. I run the H2 rims, which are supposed to be pretty easy on parts compared to most aftermarket stuff.
I went through a couple sets of upper control arms in the last couple years, though. Not sure why the ones I got wouldn't last. Finally switched from the ACDelco to Moog, and they are ok for now. Probably go kryptonite next time, especially if these only last a few years.
As has been mentioned, I've heard good things about the Cognito and Kryptonite. I have a few Kryptonite steering parts that are bulletproof, which is why I'd lean that way.
  #13
Old 05-17-2018, 09:54 PM
Because, I am sure he is doing it wrong...
Just poking fun at him. We Moderate on another forum together.
  #14
Old 05-19-2018, 09:18 AM
Itís true, I have no idea what Iím doing!! 😜
I guess I should check in over on PT, itís been a while.
  #15
Old 05-19-2018, 09:24 AM
For those asking, I tow fairly heavy trailers on & off road, and I run 33x12.50r18’s with no lift. But I did the NorCal fender mod, and turned my torsion bars up one inch. The upper ball joints on these trucks don’t do well to start with, which is why you see different vendors offering their “fixes”. So far I can tell you that the cheapest ball joints last about as long as the high dollar Moog “problem solver” ball joints. About a year and a half. Mostly because the ball joint angles are terrible with the 1” crank up.
I also have to drive 8 miles each way on a horrible road to the plant I work at, dubbed the roller coaster. They take a beating.
