Old 03-09-2018, 01:45 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default Kodiak head gaskets
Anyone ever done a head job on an 06 kodiak regular cab? I've done injectors and it was a pain. Wondering how realistic it is to pull the cab.
It's a roll back and I have the shop space to pull the cab if it's realistic.. last job before I leave this job lol. Go out with a bang
17 GMC all terrain L5P, stock with dark windows
07 crew long classic- stolen
Old 03-09-2018, 03:33 PM
stibuilder's Avatar
stibuilder stibuilder is offline
I've seen it done in the truck, I believe they lowered the engine. We lifted the cab on my 07 to swap injectors. We didn't pull it all the way off but cant imagine its worse than a pickup the wiring is very well laid out on the passenger side.
Good Luck!
2007 Kodiak C4500 (quadcab)
Efi Live, FASS 150, Custom Exhaust, Bunch of Gauges, Tahoe Headlights, Custom Stereo,National Air Seats, Flat bed, Profab Y Bridge, ARP Studs, 12x12x2 Oil cooler, BAT Sandwich adapter, 12x12x2 trans cooler, Oil Pressure/Temp Gauges, Belly mount Onan 5500w Generator. LDS 30% Overs.
28FT Intech Car trailer
@stibuider
Old 03-09-2018, 06:56 PM
clrussell's Avatar
pro-procrastinator
Good Luck!
Oh I know it's possible in truck.. I looked at it a little this evening. I guess I'll see how hard the cab is going to be to pull. If it's on the same level as a dmax cab I'll do it
Old 03-09-2018, 07:05 PM
Tothemax's Avatar
Tothemax Tothemax is offline
xgmtech
when I did Kodiak head gaskets I unbolted the front mounts loosened the rear mounts and tip the cab back and put a 6x6 block in the front between the cab and frame. got me where I needed to be and if I remember right only had to disconnect the steering shaft
2017 l5p cc/sb ltz z71 (stormtrooper edition)
06 lbz ec/sb. stock motor, Danville 4094s2r, built trans by me, limitless 1078 converter, 60% sticks, S&S 12mm pump. dyno tuned by mark @ Danville. 775hp 1383ftlb
best so far. 11.59 @ 116.55 1.707 60ft
06 lbz rc/fb dually work truck. Danville tuned
Old 03-09-2018, 10:08 PM
Dallas S Dallas S is offline
Iíve always just tilted the cab back as well. Never removed the cab entirely.
2006 SLT cc/sb LBZ/Allison/np273c D60 SAS 40x15.5r22
2006 LT RC/SB LBZ 4x4
1980 k1500 lq4/4l80/np205 39.5's on a d44
Old 03-10-2018, 05:47 PM
RPM Motorsports's Avatar
smokinum
We remove the front cooling stack in one piece, then slightly lift the cab at the front mount points
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
Old 03-10-2018, 05:55 PM
clrussell's Avatar
pro-procrastinator
Thanks Russ
Old 03-10-2018, 08:28 PM
bmc1025 bmc1025 is offline
What Russ said. Good thing they are not very heavy because you have to contort yourself to full them out not much room for a hoist even with the cooling stack and hood off.
98 C3500HD 6.5TD
03 Chevy 3500 CC Dually
06 GMC 3500 CC Dually
  #9
Old 03-10-2018, 08:33 PM
Also unbolt the cab leaving the rear bolts in but loose and stick a 4x6 between the cab and frame on both sides. Then jack up and block the frame so you can take off the front tires. It is much easier than reaching over them the whole time.
98 C3500HD 6.5TD
  #10
Old 03-12-2018, 09:58 AM
clrussell's Avatar
pro-procrastinator
3 hours in
  #11
Old 03-12-2018, 01:50 PM
clrussell's Avatar
pro-procrastinator
Two more hours and heads are ready to go to the machine shop. Might take two days to put it back together lol.
  #12
Old 03-12-2018, 03:10 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Damnnnnnn that's pretty neat. What's the time to do this as a 1500/2500
Sent from my Pixel 2 using Tapatalk
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #13
Old 03-12-2018, 03:45 PM
clrussell's Avatar
pro-procrastinator
Pull cab or headgaskets?
  #14
Old 03-12-2018, 07:32 PM
Yngdmax92's Avatar
Pull cab*
  #15
Old 03-12-2018, 07:50 PM
clrussell's Avatar
pro-procrastinator
Pull cab*
Last one I did was probably 3-4 hours. I don't do many gm cabs.. 6.0-6.4 is about an hour and half process now. If my other guy helps me we've done them in 40 min before. But that's busting ass slinging shit.
HTML code is On
