  #91
Old 12-19-2017, 12:00 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Whatís the idea behind oval bowl forged pistons? I understand they make for a much stronger piston which is needed for the cast version. But are people cracking the standard bowl forged pistons? Iím not being critical at all just curious if thereís maybe another advantage to the oval bowl that Iím missing.
Thanks.
2003 GMC CCSB LLY
Built by me, tuned by me.
  #92
Old 12-19-2017, 07:25 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Thanks.
Take a strong piston and make it, well, stronger.
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #93
Old 12-19-2017, 07:43 PM
IOWA LLY's Avatar
Yes, its really me
Cool. I can appreciate that.
Has anyone cracked a forged piston in a Duramax?
Has anyone ever done a back to back dyno of round versus oval bowl at the same compression ratio to see if there is any difference?
2003 GMC CCSB LLY
  #94
Old 12-19-2017, 07:59 PM
Fingers's Avatar
Village Idiot
I don't know that anyone has done back to back for any aftermarket piston design.
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
  #95
Old 12-19-2017, 08:08 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Here is what sold me on the oval design. Many guys had cast pistons break on higher hp applications. So most had to run forged pistons. Now many guys are running cast oval pistons with hardly any failures. My truck has beat on these pistons the last 2 years. This year we was around 1200hp. There is a lot of great info on how and why these pistons hold up on these in older post.
2006 ccsb Lbz Tow rig
2006 rclb 6.6
  #96
Old 12-19-2017, 08:17 PM
IOWA LLY's Avatar
Yes, its really me
Oh believe me Ne-max Iíve read all of those threads that Iíve seen over the years. Iím sure I missed a few though. I am definitely a fan of the oval design for cast pistons. They have certainly proven themselves to be stronger then a round bowl cast piston. My question was simply why do it on the forged pistons also. I guess the answer is simply it works good on one, might as well do it on all of them.
2003 GMC CCSB LLY
