Old 12-07-2017, 09:15 AM
bluepittsrace's Avatar
bluepittsrace bluepittsrace is offline
bow ties or nothing
Default lost dash
I know these trucks are always having stepper motor problems but I was wondering if it is common to loose everyone at same time feels to me that would be something else that feeds cluster with power or ground ive checked and replaced every fuse and unbolted and cleaned ground beside front cab mount so has anyone else lost everything at once and had it to be something other than dash that I can check before sending dash out the only thing working on the dash is back lighting , turn signal, glow plug light, and check engine light I lost every gauge, and info center at bottom of dash also is there any good recommendation for repair of dash around southern ohio
Old 12-07-2017, 09:46 AM
fc8464 fc8464 is offline
Gearhead
I would pull the cluster loose and wiggle the conection and see if you get any thing from your gauges. If nothing I would verify battery voltage on pin B11, ignition voltage on B9 and then ground on B12. If those are good check class 2 serial data on A6. Fred
Old 12-07-2017, 09:54 AM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is online now
<<<IT WORKS
I had it where my gauges quite all but the tach and speedometer. I unplugged the cluster and plugged it back in and it works fine now. But I still get it where the gauge cluster randomly seems to reboot while driving, this happened about onces every couple months. I would really like to know what is wrong.
2001 2500HD Red on Black.
ATS Dual CP3, ATS intake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
Old 12-07-2017, 10:17 AM
bow ties or nothing
thanks fred heading to garage ill give update
Old 12-07-2017, 12:26 PM
bow ties or nothing
Voltage good but getting nothing at any other pin while running shouldn't there be feed on other pins from sensors
Old 12-07-2017, 03:59 PM
Gearhead
Most of the gauges are getting there information from the class 2 serial data. If power and grounds good check serial data at A6. If you have a scan tool see if you can communicate with IPC.
Old 12-07-2017, 04:02 PM
Gearhead
conector end view to IPC
Old 12-07-2017, 05:18 PM
Whitetail Addict's Avatar
Whitetail Addict Whitetail Addict is online now
Rockin' the stock tune
http://www.duramaxdiesels.com/forum/...ad.php?t=37794
Brandon
'12 LML
'03 LB7
If you feel like everything is under control, you're not going fast enough - Mario Andretti
  #9
Old 12-07-2017, 09:40 PM
bow ties or nothing
dash replaced and working again took mine apart and seen nothing discolored or burnt had buddy use dash and everything lit and worked so it is for sure capable of loosing it all in one shot thanks for the replies I may try figuring mine out if I can keep some hair left getting thin after this past week
