Old 08-03-2017, 01:35 PM
jpowel29's Avatar
jpowel29 jpowel29 is offline
Default OBDII Pass Through
Anyone have any recommendations on a good brand of OBDII pass through connector? I find lots of cheap ones online - not complaining just want something that will work/last. I'm wanting to data log with my V2 and keep the CTS monitor plugged in so I can watch those at the same time while driving.
Trying some new things...
Old 08-03-2017, 01:56 PM
Muff's Avatar
Muff Muff is offline
Just Learning
Somebody needs to make a nice one and sell them if they don't exist.
The Learning Curve
2007 Long body - EFI - Built Transy < She was my first. SOLD
"Vern" 2002 Reg can (with a cap) 300,000 original miles. Lowered, tuned, sold to some jackass who blew it up instantly.
"Vendetta" Nobody knows but she gonna eat
You cant put a price on fun
Old 08-03-2017, 03:18 PM
Novak's Avatar
Novak Novak is offline
SQUIRREL TRYN TO GET A NUT
Also is there an OBD II port for women? I would like to see my wife's DTC's.
2008 LMM
4" MBRP TB AXLE DUMP, EFI IDAHO ROB, PPE RAIL PLUG, S&B AIR, PPE TRANS COOLER, FLEECE TRANS LINES, AIRDOGG 165, EDGE CTS, KRYPTONITE STEERING RODS AND KRYPTONITE IDLER, COGNITO STEREING BRACES, COGNITO DIFF MOUNT, BARS TURNED DOWN AND DROP SHACKLES ON REAR, ALL OTHER PM (REROUTES AND DELETES) PAINT PAINT PAINT
2004.5 LLY :SOLD
5" TB EXHAUST, FASS LIFT PUMP, PPE TUNE, PUMP RUB, MOUTHPIECE, PAINT PAINT AND PAINT
Old 08-03-2017, 03:24 PM
Novak's Avatar
Amp research makes one and if it is anything like they running boards then it is probably good quality!
Would you be able to have both devices active at the same time? Would the ECU only respond to one device?
2008 LMM
2004.5 LLY :SOLD
Old 08-04-2017, 05:35 AM
jpowel29's Avatar
I've not tried it yet so I'll let you know once I get the pass through.
Old 08-04-2017, 06:40 AM
rcr1978's Avatar
rcr1978 rcr1978 is offline
What about just adding a second OBD2 connector that's what i'm going to do on mine, I want the EFILive cord out of the drivers area anyways.
04 LB7 ECSB Built motor, Wagler narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
Old 08-04-2017, 06:45 AM
rcr1978's Avatar
There these I saw, kinda big though.
http://www.ebay.com/itm/OBD2-OBD-II-...YAAOSwCU1YyXVe
Old 08-04-2017, 06:48 AM
M.A.M.'s Avatar
M.A.M. M.A.M. is offline
I've tried the cheap eBay splitters and they don't work... it won't communicate well with either device...
Sent from my HTCD160LVWPP using Tapatalk
  #9
Old 08-04-2017, 07:00 AM
rcr1978's Avatar
Will the second connector even work then? Kinda the same as a splitter basically.
http://www.ebay.com/itm/401248273660
  #10
Old 08-04-2017, 07:32 PM
M.A.M.'s Avatar
I doubt it... I think it's more a communication issue, rather than a defective splitter... I don't think it likes talking in 2 directions at once...
  #11
Old 08-04-2017, 07:39 PM
TheBac's Avatar
TheBac TheBac is offline
Then explain how Ben used to run two devices on his truck wayyyy back when. He spliced in a second OBD port and it worked fine, IIRC.
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- in progress
From mufflerguy on yb,
  #12
Old 08-04-2017, 07:44 PM
M.A.M.'s Avatar
No idea, just my experience... I tried 2 from the same eBay seller, could've been just plain crappy.... There was a fellow trying to splice three of four connectors into his wiring on a '15 in a build I saw somewhere, never heard if it worked or not...
  #13
Old 08-04-2017, 10:43 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
Could have sworn he said he had some pid display issues if he was logging the same pid on both devices.
  #14
Old 08-12-2017, 06:17 AM
jpowel29's Avatar
I ended up send the splitter cable back.
