  #1
Old 09-14-2017, 10:27 AM
TheDirty06 TheDirty06 is offline
Default Zinc additive
I'm ready for my 500 mile oil change on my built motor. So do I need to put zinc additive in it? If so do I need to do it every change since all this new oil has less zinc in it?
  #2
Old 09-14-2017, 10:37 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
If you are not running racing oil I would put a thing of zinc additive in every change.
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #3
Old 09-14-2017, 10:41 AM
Default
Quote:
Alright I'll see if the parts store has some
  #4
Old 09-14-2017, 10:42 AM
Ne-max's Avatar
I like turtles
Default
O'Reilly's usually carries some. If I remember right it is in a little yellow bottle with a red cap.
__________________
2006 rclb 6.6
  #5
Old 09-14-2017, 12:15 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
I'm not really that educated on built engines, but what's the reasoning ?
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #6
Old 09-14-2017, 12:22 PM
Ne-max's Avatar
I like turtles
Default
The more rpms, looser bearings, and heat a built motor has.
__________________
2006 rclb 6.6
  #7
Old 09-14-2017, 12:28 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
There's no reason to on a Duramax. Guys usually run a zddp additive on flat tappet cams with higher spring pressures, but the Duramax is a roller cam. And even with aftermarket springs the seat pressure still isn't very high.
Depending on the OP's engine build and application, he should just run a high quality racing oil and not bother with additives. If it's a daily driver just put straight oil in it.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #8
Old 09-14-2017, 12:38 PM
Default
The motor should be around 1000hp and it's not really a daily driver. Lucky to see 5000 miles a year on it
  #9
Old 09-14-2017, 12:59 PM
PureHybrid's Avatar
Isuzu Shakes IT
Default
What oil are you running?
__________________
Jesse
  #10
Old 09-14-2017, 01:01 PM
Yngdmax92's Avatar
Default
Seems legit, just Been taught its more of a break in additive
__________________
  #11
Old 09-14-2017, 03:09 PM
Default
I run delo. But can only get the new stuff now
  #12
Old 09-14-2017, 04:08 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Fyi, the motorcraft oils still have high levels of zddp because Ford found the new oils didn't have enough to prevent valvetrain wear in the new powerstroke.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #13
Old 09-14-2017, 04:51 PM
PureHybrid's Avatar
Isuzu Shakes IT
Default
Quote:
For the miles you drive, I'd run a good race oil like Brad Penn or Schaeffer's. Maybe even look into the Lucas Magnum HD oil, zinc is up around 1200ppm.
For people wanting high zinc for wider clearances you should look into running a 20/50 instead of 15/40 anyway.
__________________
Jesse
  #14
Old 02-06-2018, 12:25 PM
Bdsankey Bdsankey is offline
Default
How about Cen-Pe-Co? My new built motor is going to be assembled and ran on 20w50 Cen-Pe-Co.
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp 75R", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #15
Old 02-06-2018, 12:32 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Quote:
very good oil, i would run it more if it could get it easier.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
