  #16
Old 02-13-2018, 10:47 AM
Columbus450's Avatar
Columbus450 Columbus450 is offline
Let me rephrase DEF will dose more during a regen ,
NOx is only created under HIGH temp/HIGH pressure. Def should only be injected after both the engine and Exhaust heat up. In very small quantities , 50:1 ratio for every 50 gallons of diesel 1 gallons of DEF is used ,There are several temps sensors in the exhaust ,Def will only react like it is supposed to (with SCR catalyst) under high temps.
The sixth injector is located before the DOC and Will only dose fuel if temps are not high enough
  #17
Old 02-13-2018, 10:49 AM
Default LML white smoke
And no white clouds of smoke is not normal especially while driving
Noticeable smoke while the truck is parked is normal ( during a regen)
  #18
Old 02-13-2018, 12:00 PM
stroke250's Avatar
stroke250 stroke250 is offline
diesel freak
Originally Posted by NC-smokinlmm View Post
You have a cracked DPF...
This does not always indicate a cracked DPF.
Todd
2013 F350
Tuned
  #19
Old 02-13-2018, 12:54 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
Originally Posted by Hoser View Post
This is incorrect. The DEF is always being injected and used while the truck is running, as long as itís not frozen. 9th injector only injects fuel during a regen to heat exhaust and to burn off accumulated mass in the DPF.
You are correct sir. Most of the time you have a Haze during a region is because you have a cracked DPF and it is allowing the particles to escape the exhaust the white smoke you see is also unburnt diesel fuel that escapes through the cracks.
2001 LB7 ECSB SL Built trans, batmo, lbz cp3, everything else, etc... Sold...
2006 LBZ CCSB SLT < My first, Superchips Flashpac... Sold...
2008 LMM CCSB SLT < Blue beast. way too much to list.... Sold...
2015 LML CCSB Denali < Lifted 20's/35's Deleted Airdog ETC. Sold...
2016 LML CCSB Denali < Lifted 22's/35's >I officially need help.
2010 1500 RCSB Denali clone <Lifted 22's/33's, 5.3, 6L80, TVS1900, Mayhem tuned, etc ...
2015 Corvette Stingray LT3 White on Black
  #20
Old 02-13-2018, 04:05 PM
cdbright's Avatar
cdbright cdbright is offline
JUST RENT IT
Perfect, now i have a even better excuse to run my straight 5" and make her LOUD
2015 GMC Denali 4X4 CC/SB 2500 LML
20" MOTOs
Delete/PPEI/5" straight soon to come
2008 GMC 2500 (SOLD)
EFI,all deleted,rode hard,stayed together
2009 Chev 2500 (traded) EFI, all deleted, rode just as hard as her ^^^, stayed together
  #21
Old 02-13-2018, 04:56 PM
Perfect reason to delete
