  #31
Old 01-12-2018, 08:23 AM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
Well I tried to get the 1P2299 filter, but Cat doesn't make that part number anymore. Anyone have another part number to try?
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #32
Old 01-12-2018, 05:30 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
I would double dose or maybe add a heater to the cat filter. If it doesn't make through the Cat filter it won't make it through the stocker. I'm just not sure that a less efficient filter would keep you from gelling.
Is your truck even starting or is it gelling while driving?
06 GMC 2500 CCSB SLT LBZ 4X4
  #33
Old 01-12-2018, 09:59 PM
Burn Down's Avatar
Originally Posted by MAXX IT OUT View Post
Well second time this year and below Zero and she gelled up pretty good this go round. I am beginning to lean towards it being too small of a filter. This time i was using howes on a single dose. I currently am using a cat filter 1r-0750 which is a 2 micron filter, Should I step down to a CAT Filter IP2299 which is a 6 micron filter for winter uses or always double dose on the Howes?
It's not the filters... It's your fuel blend. I lived in Alaska for 14 years in the interior, -50+. Never gelled but one time, I still had summer fuel in the truck and it hadn't been driven in a month, that happened last winter. I have run Cat water sep and 1r0749 filters for years and currently run a Cat synthetic media for high pressure common rails, much tighter with no gelling issues.
If your unsure of the quality or blend of the fuel then use plenty of your favorite fuel treatment...
  #34
Old 01-13-2018, 09:36 AM
PureHybrid's Avatar
Isuzu Shakes IT
+1
For the $10 a bottle I'd double or triple dose. Well worth not screwing around pulling filters off.
Jesse
  #35
Old 01-13-2018, 01:08 PM
<<<IT WORKS
Normally it would be while driving, but this go round it was about 5 minutes after a cold start.
Originally Posted by PureHybrid View Post
+1
Can extra doses hurt anything? Last time I fueled up, about a week ago it was 20, then was up to 40 for a couple days then temp dropped like a stone back to around zero.
  #36
Old 01-13-2018, 01:55 PM
oscyjack's Avatar
oscyjack oscyjack is offline
No you won't hurt anything.
'08 LMM CCSB
Limitless trans
EFIlive - PPEI
Built front end
All the bolt ons
33x11.5 on 17x9 -12
HB/brake upgrades
  #37
Old 01-13-2018, 02:24 PM
PureHybrid's Avatar
Isuzu Shakes IT
Some cleaners / additives yes, but Howes states on the bottle that overuse is not harmful.
Jesse
  #38
Old 01-13-2018, 03:11 PM
Dozerboy's Avatar
The emergency anti gels are the ones you really don't want to overdose on.
  #39
Old 01-13-2018, 04:06 PM
Novak's Avatar
Novak Novak is offline
SQUIRREL TRYN TO GET A NUT
Iíve seen guys do a 1:1 on their filters when they gel up, in my opinion itís on the same level as ether as far as harmful.
2008 LMM :SOLD 2/18
4" MBRP TB AXLE DUMP, EFI IDAHO ROB, PPE RAIL PLUG, S&B AIR, PPE TRANS COOLER, FLEECE TRANS LINES, AIRDOGG 165, EDGE CTS, KRYPTONITE STEERING RODS AND KRYPTONITE IDLER, COGNITO STEERING BRACES, COGNITO DIFF MOUNT, BARS TURNED DOWN AND DROP SHACKLES ON REAR, ALL OTHER PM (REROUTES AND DELETES) PAINT PAINT PAINT
2004.5 LLY :SOLD 2/15
5" TB EXHAUST, FASS LIFT PUMP, PPE TUNE, PUMP RUB, MOUTHPIECE, PAINT PAINT AND PAINT
  #40
Old 01-13-2018, 05:55 PM
Dozerboy's Avatar
We use to mix in up to 40% gas in our diesel tank on the farm in emergencies in the winter. Never had fuel system issues, but we didn't make a habit of it.
  #41
Old 01-13-2018, 11:20 PM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
Glad I don't have to deal with this shit. It gets cold in Washington but not cold enough to do this stuff.
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Tuned by Aaron Wiebe
Custom 80" Trac Bars by MBS Diesel
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to: Scott@ SDP, Aaron Wiebe @ All In Truck Performance
Best time to date: 12.08 @ 112.58
  #42
Old 01-15-2018, 04:23 PM
chevor's Avatar
chevor chevor is offline
Highway hauler.
And you use the block heater.
2010 Gmc 2500 Duramax over 845,000 Odometer miles
50% towing miles,Counteract balancing beads,Rancho 9000 shocks,89 Gallon RDS in box tank, 1 ton rear leaf springs,Curt 20k Fifth Wheel,Curt 18K Rear Mount hitch,Firestone ride-rite air bags,NUC Motorsports Bypass oil Filtration,Edge Insight CTS,Fass 95HD
New 2013 LT CCSB bought with 508,000 miles
2013 LT CC & Chassis with 9' Hillsboro Aluminum flatbed - over 80,000 miles
chevor-2010-gmc-2500-maintenance-log
Dually Flatbed
Favorite book : The Richest Man in Babylon
  #43
Old 01-15-2018, 04:56 PM
1TRIKHD's Avatar
Country boy Limo.
I do
Sent from my VS985 4G using Tapatalk
ADII 165
  #44
Old 01-15-2018, 06:25 PM
jlawles2 jlawles2 is offline
I use the block heater south of houston. Its not for the benefit of the truck. Creature comfort to help me stay warm on the way to work since its only a 15 minute drive on back roads.
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
