  #1
Old 03-19-2018, 12:26 PM
MADD*MAX MADD*MAX is offline
Gearhead
Default Mega fuse
Yesterday moring when I went to use the factory remote start the main mega fuse blew. I replaced it and my truck started no problem with the key. Obviously I have a short but don't know where to start looking.
__________________
2013 LML-Wherli S475 over stock twin kit, Cp3 conversion with fleece pro flow 750, AD 165, cognito 4-6" NTBD, PISK, 5' flo pro exhaust, ARP head studs tuned by Kory
  #2
Old 03-19-2018, 01:09 PM
2004LB7's Avatar
2004LB7 2004LB7 is online now
Default
What temps are you at? Maybe a grid heater or glow plugs. Also check out the alternator
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #3
Old 03-19-2018, 02:08 PM
Gearhead
Default
No grid heater and the glow plugs are good. They are brand new acdelco glow plugs. Temps are about 32. Alternator definitely works good. I borrowed the alterantor mega fuse to restore power and start it up with the key and the voltage dropped to around 12V while idling and it said service charging system. Then I shut the truck off and borrowed the glow plug mega fuse for the alternator circuit and restarted the truck. Voltage started out and 12V and quickly climbed to 15V so I know its charging.
__________________
  #4
Old 03-25-2018, 07:20 PM
Gearhead
Default
Anyone have an ideas where to look. Obviously there is a short in the remote start wiring but don't know where to look. I can't find any diagrams online of the remote start wiring specifically. I did switch tuners but highly doubt this is a tuning issue. I did lose my fast idle option with the new tuning which I had with the old tuner.
__________________
  #5
Old 03-27-2018, 06:21 PM
Ron Nielson Ron Nielson is offline
Gearhead
Default
Wiring diagrams can be found here: http://www.bbbind.com/tsb-wiring-diagrams/
__________________
Ron Nielson
2008 Chevy Silverado LT, SRW, Crew Cab, LB, LMM/Allison, Rear lowered 2": otherwise, fully stock at this point. Edge Insight CTS
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
