  #16
Old 09-14-2017, 01:31 AM
2004LB7's Avatar
2004LB7 2004LB7 is online now
looks like one may be able to shoehorn in a previous a gen injector. good information
from here:http://www.trucktrend.com/how-to/eng...e-duramax-l5p/
"The Denso G4S Gen III solenoid-type injectors (left) are new to the Duramax engine. The top-mounted solenoid and fuel inlet, along with 0.7677-inch (19.5mm) body diameter, make it distinctively different from its counterpart. Denso’s Mini-Sac nozzle provides 830 cc of fuel per minute through seven holes and a 180-degree spray angle. The tip of the nozzle protrudes 0.059 inch (1.5 mm) into the cylinder. The hold-down bracket assembly is redesigned for the new injector."
2008 Chevrolet 3500HD DRW LTZ
  #17
Old 09-14-2017, 08:12 AM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
I do like the look of the bottom end of the L5P
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #18
Old 09-15-2017, 05:35 AM
countrycorey's Avatar
countrycorey countrycorey is offline
Trust Me I'm an Engineer
The heads look really good too
Sent from my SAMSUNG-SM-G930A using Tapatalk
2007 Chevy Classic CCSB LS 4x4 w/ LBZ & 6 Spd Ally
Graystone Metallic
295/70/17 Nitto Trail Grapplers on Chrome H2s w/ LMM Centers
Custom CamLocker Toolbox
Grizzly Nerf Bars
Pioneer 4100 Head Unit
JL Audio Components
Sportsman Max4 Seat Covers
MPI GT4202/Stock
HSP Coolant Tank
Tinted Windows
MBRP 5"
PCV Rerouted
EGR Blocker & Fingerstick
Nicktane 1 Micron Filter & Adapter
Banks Hot Side Intercooler Tube
ProFab Y-Bridge and 3" Cold Side Boost Tube
AutoMeter Phantom II Boost and EGT on A-Pillar
Hammerhead Armor Replacement Front Bumper
EFILive from IdahoRob
Fleece All On Mod
  #19
Old 09-15-2017, 09:42 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
You may be able to swap the timing cover, do some machining, and swap in the reluctor up front and forget about the rear one. Or you can always go external with a reluctor.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
