  #241
Old 07-24-2015, 07:07 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Default
Quote:
Originally Posted by JDPlowboy View Post
I wanted to stop by with my new findings with the 02 hybrid conversion. This winter I did the original lly conversion, with a lot of help from this thread. The truck ran "ok" had lots of rattle and was a bear to drive, but made 511hp on dyno and ran out ok... Well after my wife wrecked her 2.5 truck. I decided I'd start playing with this 02 dually. So Monday I got a wild hair and pulled cab and swapped in a set of lbz heads I had on shelf, Tuesday put in some 60% over LMM 6 holes, and a dual fueler kit. Initial start up I noticed an immediate difference in engine noise and how it ran. It sounded and idled like stock lb7!.... Took it to dan clarkes place and we dyno tuned it. He was able to actually able to trash my tune that I worked on for a solid week to make the old setup to work. Copied over stock lly tables and started dyno tuning. Each tune would gain us 30 more hp it seemed. Ended up with 630/1100 the stock ihi was out of breath. Sorry for the rambling. Got an 8hr drive ahead of me. But my point is. Lb7 ficm/ECM will drive LMM injectors like there's nothing funky going on! I officially have parts from 01-15 engine models all stuffed into one engine. Lol
I have been collecting parts to go a different route with mine too...except I'll be using full LBZ electronics this time. Tuning the lly stuff has wasted so much of our time that I just said enough is enough...time to be able to focus on the other details of making it fun and reliable to race.
__________________
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #242
Old 08-17-2015, 07:53 AM
nmband13's Avatar
nmband13 nmband13 is offline
Gearhead
Default
arent glow plugs different from lb7 to lly, one threads in deeper and lb7 takes 15seconds on a cold day while lly take like 3 seconds to light...correct? Don't the lly's take much less voltage at the same time? if you ran on a lb7 glow plug system you would melt them off...or am I missing something?
__________________
'01 Duramax CCSB - daily
'02 Duramax RCLB - LBY
  #243
Old 08-17-2015, 08:50 AM
juddski88's Avatar
Freedom Diesel
Default
Quote:
The glow plugs won't melt, I'll promise you that. Yes they are different, but the worst that has happened with my truck was I shorted out a couple relays because I had it located right on the firewall and it got wet.
__________________
Thank you.
  #244
Old 08-21-2015, 09:29 AM
nmband13's Avatar
Gearhead
Default
Good to hear. Looking at a lly swap as i had a inj go bad and wreck some stuff on my motor...done with lb7 inj's
might delete glow plugs but then its a "race truck" lol
__________________
  #245
Old 12-05-2015, 05:12 PM
Boots2500 Boots2500 is offline
FNG
Default
Just signed up as a member of this forum. My buddy recently informed me of the hybrid conversion so I decided on doing my own research and I have always found these threads to be extremely useful. I have an 01 cclb and injectors are on their way out. Literally read this entire thread and I'm pissed I didn't look into this sooner. Ill be looking into starting the conversion on mine in the spring with the help from everyone's advice I read on here. Thanks
  #246
Old 04-23-2018, 05:52 PM
turbovan turbovan is offline
Too many toys!!!
Default
I need to do this, just lost an injector yesterday and can get a whole LLY top end with good tested injectors for $1500. Just need help with the tune.
__________________
2002 4x4 Crew cab brown/gold 2500HD. Leveled with 275/75R17 10 ply KO2's, 3" exhaust, 3.5" turbo inlet, custom 30 hp tune. Pulling an old 26ft 1998 Prowler Toy Hauler. More mods to come!
  #247
Old 05-16-2018, 10:42 AM
Too many toys!!!
Default
Bit the bullet, local diesel shop friend sold me a LMM top end off a Kodiak, with a CP3, 125,000 km's, for $1500.
I flushed my injectors and the balance rates came down, it runs good now, no miss, so I am going to try and limp this thru the summer and after camping is over, swap the whole shebang over, along with a DP and BD drivers manifold. Going to run the LB7 computer and ficm.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
